Results 1 to 6 of 6
Hybrid View
    Jun 09 2017
    Austin, Tx
    Questions: DRC getting KW HAS and Eurocode (Ecode rear sway doesn't fit DRC?)
    Has anyone with DRC personally installed the KW HAS? Did you find a trick to getting the rear springs out? I expected the tension to relieve when I unbolted the upper strut mount. I'm thinking spring compressor now?
    Similar question with the Eurocode sways: The rear bolts I have from my previous airbaged car hit a fluid line near the strut. There weren't lines to hit on the other car so I'm sorting options. I think it's just a different hardware stack up and I'll chat with Eurocode but thought I'd ask here.
    thx
    Sent from my SM-G925V using Tapatalk
    2014 Daytona Gray Pearl / Dynamics Package / Carbon Optics / Carbon Mirrors / Carbon Inlays / B&O / Smoked Tails / Body Color Side Lenses
    Akrapovik/ Mike's catted DPs / Eurocode Sways, Endlinks, Al Kruez, more / KW H.A.S. / HRE P104- Matte Bronze /
    Totaled- 2014 Audi RS7 due to rear end from texting college student
    Jun 09 2017
    Austin, Tx
    Well, I reached out to Eurocode and got anunhelpful reply boarding on "We've never seen this before", so I'm bumping this in the event someone else has run into this. I"ve asked them to confirm if they have every installed their rear bar in the stiff setting on a DRC equipped car.
    Can anyone confirm that they have done this?
    Pic attached shows the supplied Eurocode parts with the bolt head hitting the hydraulic line of my DRC dampers.
    Jun 09 2017
    Austin, Tx
    pic
    Established Member Two Rings warp_ix's Avatar
    Aug 18 2014
    2016 Audi RS7. 2018 BMW M3. 2010 Audi A4.
    I have air suspension, but here are some pics I just took this weekend. Maybe it'll help.
    Sent from my SM-G950U using Tapatalk
    Jun 09 2017
    Austin, Tx
    Thanks. I actually think that does help. When I look at your 2nd and 4th pictures I don't see the hydraulic lines that my bolt heads hit... I'm assuming, but don't know for sure, that these lines on my car are the ones that link the cross corners of the DRC setup.
    Jun 09 2017
    Austin, Tx
    Chris over at Eurocode responded to me again. I may have misunderstood his first message to me, but he has been helpful in letting me know they have not seen a DRC car at their facility nor have they been previously notified of this issue. I'm going to have a few custom spacers made to see if I can correct the issue and will report back in several weeks.
    Side thought for other DRC owners who come across this: The DRC by design is supposed to help reduce body roll. This message is consistent with other DRC owners who have reported less benefit from chassis stiffening products. It may be that we don't need the stiffer setting on the back of the car to achieve the same balance targeted for the air-bagged cars.
