Results 1 to 8 of 8
    Established Member Two Rings fignewton's Avatar
    Dec 08 2012
    2005 Chevy Avalanche Z71
    Broad Run/VA/mid-Atlantic
    VCDS security access codes for B9 Q5/SQ5 needed
    Got my new HEX-NET from Ross-Tech today and went to make some changes, such as display gear, and others. Found that for several of the modules, you cannot go into coding to change without entering the security access code/login for the module. Someone had posted codes for the electrical group and sunroof, but I need them for the 02 auto transmission model and the Central Convenience module. I spent over 2 hours searching sites for these, and the best RT could show me was “they are found in your factory service manual.”. That doesn’t help. Some questions:
    1. does anyone have a list of all the SACs for the modules?
    2. Where can they be sourced?
    3. After running and saving a full scan, I noted that the workshop code on almost all modules was the same. Only lights and a couple of others were different strings. Are these workshop codes related to the security access codes in any way?
    Without the codes to get into the coding blocks to make changes, my VAGCOM is pretty worthless to me.
    All assistance appreciated.
    Current- 2024 Daytona Grey Black Optics SQ5 Prestige, Sport pkg, sport exhaust, 21" wheels, 034 sway bars
    Previous- 2018 Daytona Grey Prestige, 21" wheels
    2014 S4 Monsoon Grey, Premium, Black Optics, sport diff, black napa, B&O, Nav, Alu Kreuz, Michelin AS3s, tint, Eurocode intake
    2010 S4 Ibis White
    2002 TT 225, Aviator Grey, lots of mods
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    I have the RossTech cable and software too. When it requires a code, simply hover the mouse over it and it will display it for you. At least it did for me and they all worked.
    EDIT: Just noticed "B9" in the title. I don't know if the codes are the same, or how the software works. Still. . .worth a try.
    Dec 08 2012
    Tried that on one module, moving the cursor by trackpad over the block, and no balloon with the code popped up. Will try others later this morning
    2010 S4 Ibis White
    Dec 08 2012
    Okay, just went out and was able to make all my changes. I could go directly into "adaptation" and see the pull down menu choices without having to enter the security codes. So, success so far!
    2010 S4 Ibis White
    Established Member Two Rings Haole_Audi's Avatar
    Nov 27 2013
    Honolulu, HI
    using vagcom, have you been able to change the air suspension settings? if so, what were the steps you took?
    Dec 08 2012
    Quote Originally Posted by Haole_Audi View Post
    I didn't dig deep enough in codes to see what was there, but from others that have answered this question, it sounds like VAG-COM won't do it, that a factory programming system is required.
    2010 S4 Ibis White
    Jun 27 2014
    Minneapolis
    What changes were you able to make?
    2018 Audi SQ5 Prestige
    Dec 08 2012
    Many of the changes that are shown here on the first post of this thread on AW with coding:
    https://www.audiworld.com/forums/q5-...018-a-2937291/
    2010 S4 Ibis White
