Results 1 to 10 of 10
Hybrid View
    Jan 02 2018
    Deleted
    Can't calibrate suspension after doing VCDS procedure on 'dynamic'. Please help.
    Hey gang, thought I started this thread before, and was posting on my MMI thread. Geez. Didn't think I could get any stupider, but guess I am. And I start a 3rd chemo regimen on Monday. If I make it, will end up barely smarter than a freaking dog at this pace. Ha ha. Oh well.
    Anyway, to make my story short, lowering the suspension while trying to perfectly leveling the car, and it just doesn't work AT ALL, so DO NOT attempt that folks. I tried to adjust 1.6mm, and ended up with 11mm difference; obviously Audi uses some kind of algorithm, not straight up measurements, as it's obvious by the fact you need to ADD to the adaptations in order to lower the car, which makes no sense in terms of it being the measurement from middle of wheel to fender edge. Also worth mentioning, the air suspension system is not that accurate either, so it further makes no sense trying to level it, since the gaps keep changing. I proved this by switching from auto to dynamic, where the differences changed as much as 4mm. At that point decided to forget about leveling the car, and went back to redo the measurements... but forgot to put suspension back to auto. When I got to calibration, it bombed. Tried to repeat the procedure perfectly (in auto, obviously), and this tiime as soon as I clicked on 'calibrate', got an immediate message 'ERROR: Request sequence error'. On the third time, my stupid laptop's touchpad activated 'start up to reference level production', rather than 'start up to reference level', but don't know if it screwed something else, but was getting the same error before, so who knows. At any rate, just posted the (edited) full scan on the following post, where 4 out of the 5 faults on module 34 are typical errors listed on VCDS, including 'no end-of-line programming', which seems to be the main issue in my case (programming got corrupted or something). Everything was done exactly as instructions say the last 2 times, and with a fully charged battery and a 5A charger hooked to it. It took me less than 3 minutes to complete the procedure, so I'm absolutely certain it's not any voltage issue. Have several other 'soft' faults (including an ABS one), due to module not being calibrated, plus the obvious dash ones (red susp error, adaptive headlights/ACC/brake-guard not active, and MMI shock/suspension warning below the grayed out 'raise'). The module lost its coding too, but I already coded it exactly like it was before, and the not coded error still appears. Guess because it's not calibrated. Anyway, had an appt today at dealer, but they canceled me until tomorrow. Hope an expert could help, to avoid spending $300+ I don't have, and avoid any warranty issue. Since I have chemo on Monday, and don't know if I'll get out of it, don't want to potentially leave my wife with another headache, so want to get it fixed tomorrow. Hope somebody knows what could be wrong. At this point, anything other than 'erase all adaptations' couldn't get any worse, right? He he. So I'm willing to experiment if it makes sense. Thanks gang.
    Jan 02 2018
    Deleted
    Had to edit scan, since it doesn't fit, but deleted only modules with no errors. Hope somebody can help.
    Code:
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    13-Auto Dist. Reg -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    1B-Active Steering -- Status: OK 0000
    20-High Beam Assist. -- Status: OK 0000
    22-AWD -- Status: OK 0000
    28-HVAC, Rear -- Status: OK 0000
    34-Level Control -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    85-On Board Cam. -- Status: Malfunction 0010
    8B-Adaptive Cruise 2 -- Status: OK 0000
    8E-Image Processing -- Status: Malfunction 0010
    8F-Pretens. Frt Left -- Status: OK 0000
    90-Pretens. Frt Right -- Status: OK 0000
    A9-Struct. Borne Sound -- Status: OK 0000
    BA-Motor Mounts -- Status: OK 0000
    Address 03: ABS Brakes (J104)       Labels: Redir Fail!
       Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
       Component: ESP9 Premium  H01 0530
       Revision: --------    Serial number: --------------
       Coding: 65BED449A67D2B921B00
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ESP9BOSCHAU57X 004018
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 41DFB818D10F91CF3D6-8014
    2 Faults Found:
    200448 - Function Restriction due to Faults in Other Modules
              U1113 00 [047] - -
              [SCL_LWR_Hoehenwert_HL_Error]
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 3621 km
                        Date: 2018.02.25
                        Time: 16:33:12
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        Uz: 9D
                        Unlearning counter according OBD: 40
    200192 - Function Restriction due to Implausible Message(s)
              U1112 00 [047] - -
              [SCL_LWR_Hoehenwert_HL_Invalid]
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 3621 km
                        Date: 2018.02.25
                        Time: 16:33:10
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        Uz: 9D
    Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
       Part No SW: 4H0 907 063 GM    HW: 4H0 907 063 AM
       Component: BCM1 2.0      H20 0368
       Revision: 2102003S    Serial number: 00001715237202
       Coding: 01058011003C8FF2F90040C7A0003800CF9CD208AE08022180000894F10017020060003D030000
       VCID: 79AF10F8F9DF090F356-802C
       Subsystem 1 - Part No SW: 4G1 955 119     HW: 4G8 955 119   Labels: 1KX-955-119.CLB
       Component: WWS57X 170522  H38 0080
       Serial number:         170622061250
       Coding: 0045F7
       Subsystem 2 - Part No SW: 81A 955 547 A    HW: 81A 955 547
       Component: G397_RLFS  H06 0002
       Serial number: 20338411X81A955547A0
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
       Component: E1 - LDS  H07 0044
       Serial number: 06 07 2017  00000294
       Subsystem 4 - Part No SW: 4G0 907 410 A    HW: 4H0 907 410 A
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z030F96D3
       Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA128226000035191519
       Coding: 020300
       Subsystem 6 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H01 0006
       Serial number: 054017B800PAG0MUFU03
    2 Faults Found:
    00471 - Control Module for Elect. Regulated Dampers (J250)
                013 - Check DTC Memory
                 Freeze Frame:
                        Fault Status: 01101101
                        Fault Priority: 3
                        Fault Frequency: 2
                        Reset counter: 56
                        Mileage: 3621 km
                        Time Indication: 0
                        Date: 2018.02.25
                        Time: 16:33:08
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 2
                        Reset counter: 56
                        Mileage: 3621 km
                        Time Indication: 0
                        Date: 2018.02.25
                        Time: 16:33:08
    Address 13: Auto Dist. Reg (J428)       Labels:| 4H0-907-561.clb
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0055
       Serial number: 00000000000000
       Coding: 7E01010102
       ASAM Dataset: EV_AdaptCruisContrAU57X 002015
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 290F00B8497F798F056-807C
    1 Fault Found:
    93440 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [FAULT_CIS_VIDEO_FAIL]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 56
                        Mileage: 3621 km
                        Date: 2018.02.25
                        Time: 16:33:10
                        Control Module temperature: 20 °C
                        Voltage terminal 15: 12.185 V
                        Velocity_vehicle_reference: -0.01 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
    Address 19: CAN Gateway (J533)       Labels: None
       Part No SW: 4G8 907 468 K    HW: 4G8 907 468
       Component: J533--Gateway H15 0110
       Revision: --------    Serial number: 00000002665750
       Coding: C0ED074814
       ASAM Dataset: EV_GatewPkoUDS 002011
       ROD: EV_GatewPkoUDS_002.rod
       VCID: 40D9BD1CDA0598C7328-8014
       Battery Monitoring Control Module:
       Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
       Component: J367-BDMHella  H10 9070
       Serial number: 9275964504
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663 F
       Component: J532_DCDCStab  H23 0022
       Serial number: 170429000000000007F9
    No fault code found.
    Address 1B: Active Steering (J792)       Labels: None
       Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
       Component: DYNAMIKLENK.  H06 0740
       Revision: 52001005    Serial number: --------------
       Coding: 0E0100
       VCID: 3A2DCFF4BC59C2177CC-806E
    Address 20: High Beam Assist. (J844)       Labels: None
       Part No SW: 4H0 857 511     HW: 4H0 857 511
       Component: FLA           H04 0021
       Revision: AA001002
       Coding: 04018264747464545425363E00
       VCID: 678B46809F6B8FFFD32-8032
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H19 0200
       Serial number: 002806170001025
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
       ROD: EV_AllWheelDiffeQSPFR.rod
       VCID: 280905BC527540871A8-807C
    Address 28: HVAC, Rear (E265)       Labels:* 4G0-919-158.clb
       Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
       Component: KLIMA FOND    H08 0113
       Serial number: 20071700040181
       Coding: 20
       ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
       ROD: EV_ClimaContrUnitRearUDS_003.rod
       VCID: 3D27C4E8ADF7F52F59E-8068
    Address 34: Level Control (J197)       Labels:. 4G0-907-553.clb
       Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
       Component: LUFE-DAEMPFER H19 0783
       Coding: 008006
       ASAM Dataset: EV_AirSuspe 003025
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2F3BEEA0779B17BFDB2-807A
    4 Faults Found:
    403200 - Function Shut-Off Active
              C10C8 00 [009] -  -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 56
                        Mileage: 3621 km
                        Date: 2018.02.25
                        Time: 16:37:13
    367877 - Ride Height Not Learned
              C1044 00 [009] -  -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 56
                        Mileage: 3621 km
                        Date: 2018.02.25
                        Time: 16:33:10
    266752 - Control module not coded
              U1013 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 56
                        Mileage: 3621 km
                        Date: 2018.02.25
                        Time: 16:33:10
    38144 - No End-of-Line Programming
              B2013 00 [009] -  -
              [keine Bandendeprogrammierung erfolgt (Auslieferungszustand)]
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 56
                        Mileage: 3621 km
                        Date: 2018.02.25
                        Time: 16:33:10
    Address 36: Seat Mem. Drvr (J136)       Labels: None
       Part No SW: 4G8 959 760     HW: 4G8 959 760
       Component: MEM-FS        H03 0157
       Revision: AA000000    Serial number: 00000264708827
       Coding: 00581B0000006001000001010101102030303232203232
       VCID: 77AB16C0CFCB1F7F432-8022
    Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
       Part No SW: 4G0 907 637 L    HW: 4G0 907 637 G
       Component: SARA 6D red   H04 0056
       Revision: --------    Serial number: EJ1BPA7E02X9HX
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 372BD6C08FCBDF7F832-8062
    Address 3C: Lane Change (J769)       Labels:| 5Q0-907-566.clb
       Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
       Component: SWA Master    H08 0070
       Serial number: 0447460632
       Coding: 040211
       ASAM Dataset: EV_LaneChangAssis 001028
       ROD: EV_LaneChangAssis_AU21.rod
       VCID: 392FD0F8B9DFC90F756-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
       Component: SWA Slave  H08 0070
       Serial number: 0447830783
       Coding: 040211
    Address 42: Door Elect, Driver (J386)       Labels: None
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0511
       Coding: 011F17015E00628002000013
       VCID: 45D7AC08C5A7BDEF01E-8010
    Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
       Part No SW: 4G0 909 144 T    HW: 4G0 909 144 Q
       Component: RCevo         H54 0202
       Revision: 00000002    Serial number: 0000882256
       Coding: 011001010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: 3A2DCFF4BCD9C2177CC-806E
    Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
       Part No SW: 4H0 907 064 HR    HW: 4H0 907 064 HR
       Component: BCM2 2.0      H61 0825
       Revision: 00002001    Serial number: 0444726645
       Coding: 0106063A00C2408580B0088402070E470000000000000000000000000000
       VCID: 00597D1C9A0558C7728-8054
       Subsystem 1 - Part No SW: 4G0 959 719     HW: 4G0 959 719
       Component: GTO BF  H01 0081
       Serial number: 00000000000000407338
       Subsystem 2 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
       Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS40.402  H03 0004
       Serial number: 0000FST001OVAA400000
       Coding: 101F02
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Component: Dachelektroni  H10 0100
       Serial number: 0000000AP00030640034
       Coding: 010000
       Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Component: GEB.F.Heckoef  H16 0811
       Serial number: 6600<58:
    Address 52: Door Elect, Pass. (J387)       Labels: None
       Part No SW: 4G8 959 792 J    HW: 4G8 959 792 G
       Component: TSG BF        H03 0511
       Coding: 011F17015E00628002000002
       VCID: 46D5AB04F8A1B6F7084-8012
    Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
       Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
       Component: EPB-4         H01 0018
       Revision: --------    Serial number: 00000002250703
       ASAM Dataset: EV_ParkiBrake 001033
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 323DE7D464A93A57B4C-8066
    Address 55: Headlight Range (J745)       Labels:| 4H4-907-357-V2.clb
       Part No SW: 4H4 907 357 E    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0100
       Coding: 04FA0A1122600400
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
       ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
       VCID: 3431E1CC9EBD3467A60-8060
       Led Headlamp Powermodule Left:
       Subsystem 1 - Part No SW: 7PP 941 472 J    HW: 7PP 941 472 J  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 7560
       Coding: E01E00
       Led Headlamp Powermodule Right:
       Subsystem 2 - Part No SW: 7PP 941 472 J    HW: 7PP 941 472 J  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H07 7560
       Coding: E01E00
    Address 5F: Information Electr. (J794)       Labels:* None
       Part No SW: 4G1 035 025 G    HW: 4G1 035 025 C
       Component: MU-H-LNS-US   054 0980
       Serial number: A741G0HS005590
       Coding: 017551020000000013220002041A00102F0007E5F17001047E
       ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
       ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
       VCID: 221D17943449AAD744C-8076
       Data medium:
       Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
       Component: NAR 2018  --- 0063
       Serial number: --------------------
       Display unit 1 for multimedia system:
       Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
       Component: DU8 C7 SV  H63 0007
       Serial number: AUZ8Z9HY808BNX
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
       Component: E380 BDT C7  H20 0250
       Serial number: 90349QGA000ZC
       Compact Disc Database:
       Subsystem 4 - Part No SW: V03 959 800 EG    HW: -----------
       Component: Gracenote2---  --- 3012
    Address 62: Door, Rear Left (J388)       Labels: None
       Part No SW: 4G8 959 795 J    HW: 4G8 959 795 G
       Component: TSG HL        H03 0511
       Coding: 010F17004000628002000002
       VCID: 49CFA038E9BF598FE56-801C
    Address 6C: Back-up Cam. (J772)       Labels:* None
       Part No SW: 4S0 980 556     HW: 4M0 980 556
       Component: RVC Compact   H08 0140
       Coding: 027500010A002003000040
       ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
       ROD: EV_CamSysRVRVCPANAAU57X_001_AU57.rod
       VCID: 78A915FCC25510074A8-802C
    Address 72: Door, Rear Right (J389)       Labels: None
       Component: TSG HR        H03 0511
    Address 85: On Board Cam. (J852)       Labels:* None
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H28 0081
       Revision: --------    Serial number: 262130025421000
       Coding: EA060000
       ASAM Dataset: EV_OnBoardCamerDPC 001007
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C01F9AC468D6CA7FE0-8078
    1 Fault Found:
    0793 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [EGD_Fahrwerk_01_Permanent_Error]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 56
                        Mileage: 3621 km
                        Date: 2018.02.25
                        Time: 16:33:11
                        Outside air temperature: -41.0 °C
                        Voltage terminal 15: 12.1 V
                        Control Module temperature: 29.0 °C
    Address 8B: Adaptive Cruise 2 (J428)       Labels:| 4H0-907-561.clb
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7E01010102
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       VCID: 270B06805F6B4FFF132-8072
    Address 8E: Image Processing (J851)       Labels:| 4H0-907-107-V2.clb
       Part No SW: 4H0 907 107 H    HW: 4H0 907 107
       Component: BV-SG         H34 0090
       Serial number: 005002451805177
       Coding: 04C1BA1B0111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
    1 Fault Found:
    0091 - Function Limitation due to Missing Video Data
              C1108 00 [009] -  -
              [DPC_SystemError]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 56
                        Mileage: 3621 km
                        Date: 2018.02.25
                        Time: 16:33:10
                        Outside air temperature: 18.5 °C
                        Voltage terminal 15: 12.2 V
                        Control Module temperature: 26.0 °C
    Address 8F: Pretens. Frt Left (J854)       Labels:. 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 945 B    HW: 4H0 980 945 C
       Component: RGS-VL        H16 0080
       Coding: 0066E608031F0376070308014240C0010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313FE8D861AF014FCD6-8064
    Address 90: Pretens. Frt Right (J855)       Labels:. 4H0-980-94x-RGS.clb
       Part No SW: 4H0 980 946 B    HW: 4H0 980 946 C
       Component: RGS-VR        H16 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
    Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
       Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0010
       Serial number: 170514200712
       ASAM Dataset: EV_SoundActuaGen2AU64X 003010
       ROD: EV_SoundActuaGen2AU64X.rod
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145 B    HW: 4H0 907 145
       Component: AEM - LEAR    H10 0008
       Revision: 00001001    Serial number: 97813008680901
       ASAM Dataset: EV_AEMLearAU64X 002016
       ROD: EV_AEMLearAU64X.rod
    End----------(Elapsed Time: 03:07, VBatt start/end: 12.2V/12.2V)-----------
    Sep 28 2009
    suburb
    i did it on dynamic once on accident. i just closed vagcom, started over on auto and everything was OK. sorry dont have any other info for you. hope someone knows
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Sep 10 2015
    VA
    Just get it reset by Audi and get lowering links. Mine would give me constant errors using vagcom to lower. Just gave up in the end and done the lowering links. No software conflicts since.
    Jan 02 2018
    Deleted
    Hey Barritia, did you also have all the errors I did? And how much did Audi charge you? Just to know. Salesman told me master tech told him like $300. Seems excessive, but just hope it's not more than that. Curious to have a comparison. Also curious if they flashed your ECU and everything, or just the level control (34) module. Anyway, the first time I did the lowering went well, so although I'll be a bit nervous (especially due to my stupid laptop's touchpad), plan to do it again, but this time just adding 17 to the factory figures. If the tech at Audi changes the numbers, will probably put them back to factory, and just add 17. Will tell him to use those numbers, so he doesn't charge for all the measuring crap, but hope he accepts that.
    Flyfishing, wish it had been the case with mine. Attempted it 3 times, and a 4th after using the car, in case something got reset or something, but it didn't. Same thing: Everything perfect until calibration, when it just craps out. My issue is since calibration doesn't go thru, the adaptation figures get reset to zero every time I attempt it. So all the first steps are for nothing, since they're deleted already. The only step that does something is 'start up to reference level', which puts the car basically at 'raise' height, which is higher than comfort. That's how I had to drive the other day, but although red warning says no more than 35, I drove it at freeway speeds with zero issues. Dealer is like 30 miles away, so will have to drive on highway again, but car rides like a brick; shocks are harder than dynamic. It basically feels like my ex-Cayman GTS with sport suspension. Seems like I'll have to take it to dealer, but will check the forum again. Wish I wasn't that stupid, and posted this 2 days ago, when I did on my MMI thread. Have a great evening, everybody.
    Sep 10 2015
    VA
    My issues were different. I would get everything setup on level ground and it would go great. Then after a hour or at times a few days it would give me errors saying auto breaking and adaptive cruise control will not work. Tried everything I could think off and could never get it to work right. Put lowering links on and zero issues.
    Jan 02 2018
    Deleted
    Thanks man. Leaving to dealer in a bit. Wish me luck. He he. Will report how much and any grief given. Have a great day folks.
    Jan 02 2018
    Deleted
    After a day and $352 wasted, car is back to normal now. Ahole dealer charged me 3 hours instead of the documented 2 that the tech took (and probably with plenty of breaks. Ha ha), but nothing I ccould do... except never to take my car there again unless I absolutely have to, which is what I always do anyway. And yes, won't even take it for the 'free' oil change; much rather do it myself. At any rate, supposedly the module's programming was wiped out somehow, so similar to what happens with 'delete all adaptations', it seems. I'm pretty sure I won't forget to set it to 'auto' next time. Ha ha. Will try shortly to lower it again. Wish me luck. He he. By the way, apparently it was just the suspension module that was flashed, since all my other VCDS settings are still there. Have a great weekend gang.
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    Glad to hear you got it sorted!
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Jan 02 2018
    Deleted
    Thanks man. I had no doubt it could be sorted with just a re-flash, but wasn't expecting it to be that much. Ha ha. But it is what it is. I'm sure it won't happen again. Ha ha. Take care.
