Results 1 to 27 of 27
    Aug 12 2012
    Florida
    S6 Stage 2 / Seems Slow .. question
    Ran my Audi s6 Stage 2 at Audi v world
    Mods:
    EPL and TCU Stage 2
    Apr downpipes
    Stock sport exhaust
    93 octane / stock weight
    Driver 186 lbs (no passenger)
    Some stuff in the back (maybe another 5-10lbs)
    Will post time slip later but ran the following
    60' - 1.631
    330' - 4.787
    1/8 - 7.447
    MPH - 91.91
    1000' - 9.756
    ET - 11.709
    MPH - 115.37
    I did this fairly consistently
    60ft pretty solid but I feel like this should be closed to 11.5 with that 60'
    Trap speed also seems very low
    Any ideas what could be going on? Feel like this more akin to a Stage 1 car.
    Last edited by JBA87; 02-26-2018 at 04:16 AM. Reason: Clarification on Occupant Weight
    Senior Member Three Rings GlacierS5's Avatar
    Jul 27 2017
    San Jose, CA.
    That's not bad especially with Florida climate. There's a lot factors to consider :
    - amount of gas in the tank
    - time in between each run (cool down)
    - tire pressure/rim size
    - running stock intake?
    Sent from my Pixel XL using Audizine mobile app
    2018 Glacier White S5 | Prestige | Sports Pkg | Dynamic Steering | Carbon Fiber Pkg | 034 Motorsports Parts
    2016 Sepang Blue RS7 | Prestige | SRM Intake |EuroCode Sways
    2014 Glacier White S6 - SOLD
    Aug 12 2012
    Florida
    It was hot; about 85 but I feel that the rs7s present were putting down good advertised numbers. Stage 3 s6 on 104 file ran 10.6..
    Fuel about half tank
    Stock intake
    Stock 20" rim
    I had some 20 min breaks and did this farely consistently about 4 times with funds between 11.7-11.80 all similar traps and fairly similar 60' (I can post slips)
    Not sure bout tire pressure
    Registered User Four Rings
    Sep 06 2007
    Take a look at the list.. this is not slow, especially give the DA. Nice runs.
    Aug 12 2012
    Florida
    I just feel like I should be trapping north of 120
    Sep 06 2007
    On a high octane file in a sub 1000 foot da I would agree. Take a minute to review the 1/4 list, you did just fine!
    Aug 12 2012
    Florida
    Do you think the D/A could literally shave 4 tenths of a second off the time? I'm looking at subarusti's time on 93 file with EPL Stage 2. He also had Roc Euro, Milltek DP, Milltek exhaust, and D/A 77, and did 11.34 @ 121.40
    I wouldn't think that those subtle differences would shave that much time..
    Similarly, looking at APRs Stage 2 Slip on the 93 Tune with just DPs posts 11.38 @ 121.81
    And, while saxon's Unitronic Stage 2 did 11.65 on 93 octane (D/A not available). That was fairly comparable to my 11.70, but he trapped 120.81MPH vs. 115.37 and his 60' was 1.755 vs. my 1.631.
    Brian's time was comparable to mine, but we have the same setup. So looks like relative to the above we are both trapping low.
    The final time was Redmax, who was Stage 2 93, but lists no actual downpipe so I view that as simply the same as stage 1. His time was essentially the same as Brian and mines. Hence... why I feel like we are like stage 1.
    Now let's hit he list of stage 1 times one 93 octane only from the list:
    unitronic: Unitronic Stage 1, 93, 11.405 @ 120.77, w/ a 60' of 1.676
    hmuller: APR Stage 1, 93 11.570 @ 117.31 w/ a 60' 1.698
    gk1: APR Stage 1, 93 11.660 @ 114.83 w/ a 60' of 1.607
    hmuller: APR Stage 1, 93 11.67 @ 118.36 w 60' of 1.805
    Gamebreaker: Unitronic 93 11.849 @ 117.30 w 60' of 1.820
    pez81: Revo 93: 11.85@ 114.50 w 60' of 1.755
    mikedwerks: EPL 93 [email protected] w 60' 1.648
    highpsi-s4; EPL 93 12.086 @ 114.21 w 60' 1.728
    Compare this to my Stage 2 EPL 93 w. 11.70 @ 115.37 w 60' of 1.631
    I have one of the best 60 foots of all of the above runs, yet I'm running times smack in the middle of the Stage 1s with the third lowest trap speed.
    Just seems off to me..
    Aug 12 2012
    Florida
    MIght I add that most of the 93 files Stage 1s above are in DA > 1000 from the list.
    Aug 12 2012
    Florida
    If you actually study the times closely it looks like that the "lag" takes place after the 1/8th mile through the end. This is where the car is relatively making poorer time (ranking near the bottom 1/3rd) of Stage 1 and Stage 2 93 Octane File Times. It's like I am have some high-end power loss (hence the lower trap speeds) as well.
    Veteran Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    By any chance do you have any logging data from your run(s)? I would wonder how much heat soak came into play today in the Florida heat, as our stock intercoolers are piss-poor.
    Were any folks besides Mickey running an aftermarket intercooler, whether APR or AMS?
    2016 S6, mythos black, RS7 turbos, MRC inlets |Akrapovic exhaust| AMS downpipes and intercooler |Eventuri intake| Loba HPFPs |Tial wastegates| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights, OEM Euro tails |Sound: Navtv Zen-v preamp, Helix DSP Ultra, JL HD900/5 driving JL10W3 sub and Hybrid Audio speakers.
    Aug 12 2012
    Florida
    Unfortunately, I don't have any logging data..
    Not sure if any other cars were running an intercooler. I was not. Although it was hot, I don't think heat soak was the issue as this was one of my first runs. Even with the heat, I feel like I should have been trapping at least in the high teens (117mph-119mph) and perhaps the low 120s.. Just thought on the first or even the third run I should have been able to break 11.60 with that 60ft. Just look at how my times drops post 1/8th mile.
    Aug 12 2012
    Florida
    I could be wrong.. and, while my time was not a "bad" time.. I was just a little shocked not to hit <11.6 and trap north of 117mph.
    Aug 12 2012
    Florida
    Is it an EPL vs. APR issue possibly? Is EPL tuned a little softer high-end? TCU issue..
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Quote Originally Posted by JBA87 View Post
    My guess is heat or the passenger is actually 480lbs
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Sep 19 2014
    Newcastle
    Did you run at all without a passenger?
    Sent from my SM-G920F using Audizine mobile app
    Audi S6 C7.5 Avant 2016 Sepang Blue APR Stage 2, Custom Downpipes, Revo RS Intake, X-Pipe & Resonator Delete - 441WHP 528WTQ 551BHP 660 LB FT.
    Aug 12 2012
    Florida
    All runs without a passenger. Just me.
    Aug 12 2012
    Florida
    Sorry I see I wrote passenger 186lbs that should say driver. Fixed.
    Perhaps that is why everyone was looking at my with their eyes glazed over. I feel like these times are a little slow for Stage 2 with my 60' and NO passenger.
    Sep 19 2014
    Newcastle
    Oh right thanks mate. Wasn't there so if it was hot then I'd suspect it would reduce your cars performance. Does looks similar to stage 1 times.
    Aug 12 2012
    Florida
    It was 85 in Florida.. but RS7s with 104 Gas were running 10.5/10.6s all day on same track.. so those numbers seem close to advertised. No coolers
    Sep 06 2007
    Again, given the conditions 11.7 is quick. Would i have like to see an 1-2 mph faster...yes, but with out logs I can identify if thats car/tune/conditions.
    This is not a bad showing for the first time to the track with the car.
    Veteran Member Four Rings cobrario's Avatar
    Oct 28 2014
    2015 Q5 3.0T, 2019 Toyota Tundra CM Limited , 87 Buick Grand National
    Northern VA
    Don ran a best of 10.3 @ 133 on 104 but RS7 cooling is far superior to stock S6 and he has a Forge cooler on his car.
    2018 Ara Blue RS3
    IG @cobrario_rs & @audivstheworld
    Aug 12 2012
    Florida
    This page is pretty nifty for driving conditions: http://www.dragtimes.com/da-density-...calculator.php
    Track was palm beach international raceway. February 25 was date. Runs between 3 and 4 pm. I think the specific time I referred was at 3:25 or something like that
    Veteran Member Three Rings GameBreaker's Avatar
    Mar 19 2008
    Phantom Black S6, GONE but Not forgotten: Dolphin Grey B6 S4
    Chicago
    Did you try calculating the DA for the track that day? 85 degrees can make an impact, but odds are it was the humidity that might have had the most impact. It should give more insight into your numbers.
    I must say you have one hell of a 60' though. When I ran, my TCU tune wasn't finished yet so every run I made I ended up spinning through 1st and 2nd or even worse wheel spin when I just tried to mashing the gas. Like everyone else, I'm waiting for the weather to get better so I can make a proper run. It's still possible your car is stumbling on the top end, but either way an 11.7 in 85 degree heat is a good run.
    Aug 12 2012
    Florida
    That website says DA of about 1500
    Oct 28 2014
    Northern VA
    I was looking at http://airdensityonline.com/ and it was saying after 2pm or so the DA was closer to 2000- I've found DA variances between 500-1800 have made little difference in the times my car ran. Only way for you to have known the possible cause of the car's performance (good or bad) was in logging it- you'll just have to go back and try again
    2018 Ara Blue RS3
    Mar 26 2010
    US
    In the list of quarter mile times, did all S6/7 cars use launch control and what rpm launch?
    BMW M3 Competition X-drive
    Aug 12 2012
    Florida
    Quote Originally Posted by cobrario View Post
    As long as we rent the track again I'm game ...
    Let's get a group together .. I think it was $5000 for the day
    20 ppl is $250/each
    I don't think it was the DA.. it was power loss issues pas the 1/8th Mile I think
