Results 1 to 23 of 23
    Feb 21 2018
    Slovakia
    2.0 TFSI Problem
    Hello !
    I have problem with my engine in Audi A4 2.0 TFSI Quattro 155 KW
    Motor code:CDNC Year:2010
    When the engine is cold it gives a strange sound for a while from exhaust and little vibration
    VCDS show nothing
    https://www.youtube.com/watch?v=0ld1yohnEHo
    Senior Member Two Rings NYDCB's Avatar
    Aug 22 2016
    Washington, DC
    You need an engine carbon cleaning. Combine that w/ new coil packs and plugs.
    Senior Member Three Rings Mina08's Avatar
    Apr 30 2014
    Classic Mini, and lots of bikes
    Sweden
    agree
    2011 2.0 TFSI S-Line Avant/S-Tronic/Quattro/Quartz Grey/19"OEM RS5 Rotors/
    CFBSWheel/VCDS+Mods/XCL+Mirracast/LED/R8Coils/3.0FMIC/K&NFilters
    Established Member Two Rings a4efforts's Avatar
    May 15 2017
    '09 A4 B8, '17 PORSCHE MACAN & '08 BMW X5
    Atlanta, GA
    Agree to all of the above. Just had mine cleaned and new coil packs & plugs installed. 136k miles one the clock
    Veteran Member Three Rings keiffr's Avatar
    Feb 19 2014
    2006 Land Rover LR3 SE V8 4.4L
    Fresno/Clovis, CA
    This might be a dumb question, but how do you know if you need carbon cleaning? I have 136K miles (mainly freeway/highway miles) and have no signs of any hesitation, loss of performance, etc.
    I just thought since I have high mileage, I should get it done.
    2011 A4 2.0T TFSI Quattro P+/ Phantom Black
    IE Stage 1 / A5 S-Line Y-Spoke 19x8.5 Wheels Offset: ET32 / 255/35/19 General G-Max AS-05 Tires/ Solowerks S1 Coilovers
    Veteran Member Three Rings APC123's Avatar
    Feb 05 2017
    Wilmington Delaware
    Vaccum leak
    Feb 21 2018
    Slovakia
    rly carbon ??? i have new timing chain,new oil etc...
    and i use texaco cleaner and not help...
    i think its injector
    Nov 23 2009
    NYC, US
    Quote Originally Posted by keiffr View Post
    I have this same question except I don't feel this is a dumb question. :) There is no hard evidence that a dirty intake with heavy strong carbon buildup shows any evidence except maybe contribute to possible poor fuel economy.
    Feb 19 2014
    Fresno/Clovis, CA
    Quote Originally Posted by AutoRacer100 View Post
    Thanks man. I'm glad I'm not alone on this one.
    Feb 21 2018
    Slovakia
    new injectors,coil packs,fuel pump and problem persists
    Active Member Two Rings Gourley's Avatar
    Dec 27 2016
    New Jersey
    Did you do new plugs with your coil packs? Also try replacing your PCV valve. Our motors are know to have bad pcv valves. I had an issue where my pcv valve has a slight vacuum leak which caused rough idle. Replaced it along with the hose going into the intake manifold and solved my issue. I also had a CEL and VCDS showed a fault.
    Feb 21 2018
    Slovakia
    yep new plugs with coil packs :) okey i try now pcv valve change..but when it does not help me to kill myself lul...
    Active Member Two Rings Blitzzer's Avatar
    Mar 05 2018
    Chattanooga, TN USA
    I too would like to know some of the common symptoms of carbon issues.. I've read about the problem but not the symptoms. Based on only general knowledge of the problem.. I just put my foot in the carb and give it the ol' hillbilly tune up everyday I get on the interstate. lol.
    2016 B8.5 A4 2.0TFSI Sline
    Lowered 2"
    Alzor 18x10" Wheels
    255/40/ZR18 Tires
    May 15 2017
    Atlanta, GA
    In my observations from the past few weeks (since I've had my carbon cleaning), I have noticed much better fuel economy (back to when it was new) and the car pulls much better. This is especially noticeable at higher speeds when overtaking vehicles. May not be enough reason for everyone to do a cleaning-- but I really am enjoying the way the car is pulling now.
    so to Blitzzer's question, I would say the common symptoms are lower fuel economy and weaker throttle response. Since this is a gradual buildup of carbon, the loss is also gradual, and goes unnoticed.
    Mar 05 2018
    Chattanooga, TN USA
    Thanks for the info. I just rolled 38k on mine yesterday.. at what point or how often is a cleaning typically recommended?
    Lowered 2"
    Alzor 18x10" Wheels
    255/40/ZR18 Tires
    May 15 2017
    Atlanta, GA
    Quote Originally Posted by Blitzzer View Post
    A couple of shops that I spoke to recommended anywhere between 70k to 100k miles as a good time to do a cleaning. I didn't do mine until 136k miles, so the noticeable difference was huge . You should be good to go for a while!
    Aug 22 2016
    Washington, DC
    I know this because I just bought a 2010 that idled rough, even with new coil packs and spark plugs.
    This was @ 88K:
    Before...
    After...
    Car drove totally different afterwards. Smooth idle, more power and quieter engine...
    Feb 23 2018
    San Antonio
    Quote Originally Posted by NYDCB View Post
    This was @ 88K:
    Before...
    After...
    Man that looks good, what products did you use to clean the valves?
    Aug 22 2016
    Washington, DC
    Walnut blast
    Feb 23 2018
    San Antonio
    @vlad1m1r did you get the issue fixed?
    Aug 17 2015
    California
    This was @ 88K:
    Before...
    After...
    Wow nice work. More low end power (from a stop)??
    Aug 22 2016
    Washington, DC
    Yes! I couldn't understand why it would jerk in 1st and 2nd when you gave it a generous amount of gas. Drives like a new car now.
    Feb 21 2018
    Slovakia
    Guyzzz thanks for help !
    Problem fix PCV Valve
    https://imgur.com/a/aO2nn
    And i have other question...do you think chemical carbon cleaning will help me?
    Again thanks for help !
