As previously reported, I experienced some issues with my EPL Stage 2 Tune and APR Downpipe Combination. Installed downpipes in November with O2 Spacers. Through CEL on install. Didn't think much of the CEL issue (presumed the O2 Spaces simply did not work considering that without O2 spaces APR downpipes will typical throw a CEL with EPL Tune and considering that oame have reported that the 02 Spacers do not always work).
Over next several months, car began acting unusual (didn't feel right when partially accelerating from moderate speeds) and exhibited progressively more unusual behavior (which was probably on-going cylinder misfires). The CEL would often begin blinking when these symptoms were present. I brought car in to shop and finally received codes today confirming several sensor issues (throwing too lean too rich) and multiple cylinder misfires on cylinders 1,4,5,7, and 8 (I have attached codes below). Technician removed the oxygen sensors and inspected the cats and found cat material to be melted. They also found that the current downpipes and catalytic converters were damaged and need to be replaced. Furthermore, they found that due to the damage to the cat, pieces of the cat had traveled into the exhaust system and believe that even with replacement of the downpipes a "rattle" may be present.
The shop believes that the EPL Tune is the culprit. Although this may not be the case. The original shop that installed the APR downpipes (not shop fixing car) admitted that it was their first time installing APR downpipes with O2 spacers EPL believes a possible cause is that the O2 spacers were improperly installed on the upstream/primary sensor vs. the downstream sensor. Alternatively, EPL believes that the primary sensors could have been damaged on the original install. EPL has only had one other reported incident of something similar happening and, in that case, the 02 spacers were improperly installed on the primary sensor. The shop that originally installed my downpipes does not recall whether they installed them on the primary or secondary sensors. The shop that is currently fixing the problem indicated that they were installed on the correct downstream sensors. If this is the case, then (absent the EPL tune being the issues) the only possible alternative is that the primary sensors were damaged on reinstall.
A visual inspection of the dates of the fault codes show that I threw some fault codes within the first two weeks after originally installing the downpipes and then not again until additional codes were thrown last week.
The issue is now what to do..
The shop is recommending that I get new Oxygen Sensors, Spark Plugs, APR Downpipes, and replace the EPL Tune with APR ECU and TCU Tune. A procedures that will cost a whopping $7,500 est. They will warranty this work and presumably will resolve all issues
The alternative is to simply replace the Oxygen Sensors, Spark Plugs, and APR Downpipes, but keep the EPL Tune. That will cost estimated $4,500ish. This however, takes on the risk of assuming that the cause of the issue was damages primary 02 sensors.
What to do?
Any alternatives?
Recommendations?
JA
Other Notes:
13 Faults Found:
7636 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
P2096 00 [237] - Too Lean
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 12811 km
Date: 2017.11.24
Time: 09:42:19
Engine speed: 2259.00 /min
Normed load value: 20.4 %
Vehicle speed: 132 km/h
Coolant temperature: 96 °C
Intake air temperature: 44 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.900 V
Unlearning counter according OBD: 40
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
15356 - Oxygen (Lambda) Sensor Signal B1 S2
P2270 00 [040] - too Lean
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 43
Mileage: 12191 km
Date: 2017.11.16
Time: 18:39:50
Engine speed: 1378.00 /min
Normed load value: 16.9 %
Vehicle speed: 79 km/h
Coolant temperature: 102 °C
Intake air temperature: 45 °C
Voltage terminal 30: 12.227 V
Unlearning counter according OBD: 35
Rear cat conv temp main cat conv model value: 521.22 °C
O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean: 0.10 s
O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich: 0.16 s
O2 sensor dwnstrm. of cat.: delay time transf. rich -> lean: 0.00 s
O2 sensor dwnstrm. of cat.: delay time transf. lean -> rich: 0.00 s
14790 - Oxygen (Lambda) Sensor B2 S2
P014B 00 [232] - Delayed Response Lean to Rich
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 12191 km
Date: 2017.11.16
Time: 18:40:24
Engine speed: 1463.50 /min
Vehicle speed: 71 km/h
Coolant temperature: 98 °C
Intake air temperature: 51 °C
Voltage terminal 30: 13.805 V
Rear cat conv temp main cat conv bank 2 model value: 514.00 °C
O2 sens. dwnstrm. of cat. bank 2: gradient transf. rich -> lean: 0.09 s
O2 sens. dwnstrm. of cat. bank 2: gradient transf. lean -> rich: 0.15 s
O2 sens.dwnstrm. of cat. bank 2: delay time transf.rich -> lean: 0.00 s
O2 sen dwnstrm. of cat. bank 2: delay time transf. lean -> rich: 1.09 s
14784 - Oxygen (Lambda) Sensor B2 S2
P013D 00 [096] - Response too Slow Lean to Rich
Intermittent - Not Confirmed - Tested Since Memory Clear
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [172] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Mileage: 12921 km
Date: 2017.11.26
Time: 13:16:41
Engine speed: 2857.00 /min
Normed load value: 49.8 %
Vehicle speed: 63 km/h
Coolant temperature: 63 °C
Intake air temperature: 32 °C
Voltage terminal 30: 13.758 V
10591 - Cylinder 1
P0301 00 [172] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 15964 km
Date: 2018.02.07
Time: 18:16:35
Engine speed: 5823.00 /min
Normed load value: 43.9 %
Vehicle speed: 127 km/h
Coolant temperature: 97 °C
Intake air temperature: 57 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 13.452 V
10595 - Cylinder 5
P0305 00 [032] - Misfire Detected
10594 - Cylinder 4
P0304 00 [172] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 15965 km
Date: 2018.02.07
Time: 18:17:07
Engine speed: 5292.50 /min
Normed load value: 50.2 %
Vehicle speed: 157 km/h
Coolant temperature: 100 °C
Intake air temperature: 71 °C
Voltage terminal 30: 13.264 V
10598 - Cylinder 8
P0308 00 [172] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 12991 km
Date: 2017.11.30
Time: 07:44:01
Engine speed: 3889.00 /min
Normed load value: 63.9 %
Vehicle speed: 85 km/h
Coolant temperature: 37 °C
Intake air temperature: 33 °C
Voltage terminal 30: 13.428 V
10597 - Cylinder 7
P0307 00 [172] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 12921 km
Date: 2017.11.26
Time: 13:16:41
4119 - Oxygen (Lambda) Sensor B2 S1
P2197 00 [237] - Signal too Low (Lean)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 12286 km
Date: 2017.11.18
Time: 16:16:40
Engine speed: 2196.00 /min
Normed load value: 23.5 %
Vehicle speed: 128 km/h
Intake air temperature: 42 °C
Voltage terminal 30: 13.782 V
4116 - Oxygen (Lambda) Sensor B1 S1
P2196 00 [237] - Signal too High (Rich)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Mileage: 12022 km
Date: 2017.11.13
Time: 22:36:29
Engine speed: 1973.00 /min
Normed load value: 19.2 %
Vehicle speed: 115 km/h
Coolant temperature: 99 °C
Intake air temperature: 41 °C
Voltage terminal 30: 12.816 V
4201 - Fuel Level too Low
P1250 00 [032] - -
