Results 1 to 11 of 11
Thread: A5 coding help
    May 15 2017
    San Diego
    A5 coding help
    Hello fellow Audizine users
    So I had recently got an oil change done by a garage and they coded it to where the cluster screen now tells me how many miles until I need to change it again. I was wondering if anyone knew how to change that coding so I do not see it every start up.
    Oct 21 2012
    Earth...
    Quote Originally Posted by OVO_Babu View Post
    Go back and let them reset oil service properly. Nothing coding related, just tiny fault they did!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Jun 09 2017
    West LA
    or if you know anyone with a vagcom cable they can reset it for you also.
    May 15 2017
    San Diego
    I do have to do an oil change soon, been 5600 miles since. I also have a obdeleven thing too. maybe ill try to take a picture next time it shows up, I feel like im not explaining it correctly.
    Oct 21 2012
    Earth...
    aaa....ok, your first post was, you had oil change recently :)...you just got this message, it was not there after oilchange, gotcha!
    http://box349.listingfactoryhost.net...290b_large.jpg
    May 15 2017
    San Diego
    yes my bad. so mine does look like the picture, didnt happen until I got the oil change. sorry for misleading. :/
    maybe ill try to ask the guy who did it, but I feel like it must be a coding thing, since it came after it.
    Oct 21 2012
    Earth...
    No problem, ive seen threads for this few times over the years, but this is standard s...t for audis and solution is unknown how disable this...Nobody likes this:(. Not sure, will this start from 1000 miles or more to the service!
    May 15 2017
    San Diego
    Okay, so I got an oil change done today. Did the service thing, and now no more on start up. but now they changed the oil change interval to 3200... I dont know why they did that and realized when I got home. I tried googling and what not to find the coding to change the intervals but no luck. Do you know the coding steps to change that?
    Oct 21 2012
    Earth...
    If my memory correct, oil service distance is under channel 40 on b8!
    May 15 2017
    San Diego
    Thanks, I will take a look tomorrow morning. You my man are an Audi wisdom god
    Oct 21 2012
    Earth...
    Keep in mind that value there is 100x less from real distance figure!
