Results 1 to 16 of 16
    Senior Member Three Rings Sniper260687's Avatar
    Jul 22 2015
    Oklahoma
    A dumb yet reasonable question, regarding tires.
    So i been thinking, day one with the stock tires 255/30-20 the car ride was very stiff and somewhat uncomfortable so i decided to change to 255/35-19 around 6 months in.
    The ride was a bit more comfortable but I've noticed the steering wheel feel felt way softer not as sporty if that makes sense and i missed that ever since. It basically went from dynamic to comfort mode feel.
    Now im not an expert on tires but is this due to the change from 20 to 19 or from 30 to 35?
    I been thinking lately on getting new tires because i want a ''beefy'' look and also get that sporty feeling back, should i get 265/30-19 or just 255/30-19.
    And of course i only drive the TTS during the weekend so i can handle the harsh ride now.
    2017 TTS.
    May 20 2010
    A larger aspect ratio will give your softer tires. 35 is still a pretty small aspect ratio. Were the tires different brands/models? And what kind of load rating difference? Higher load ratings are generally stiffer tires.
    Jul 22 2015
    Oklahoma
    The original tires are:
    Pirelli P ZERO
    Load Range: XL
    Serv. Desc: (92Y)
    Current setup:
    Nitto Invo
    220-AA-A
    Serv Desc: 96 Y
    Senior Member Three Rings chrisngrod's Avatar
    Feb 01 2015
    Des Moines, IA
    These suckers were still pretty stiff because they're RE-71Rs. Obviously sporty as far as traction.
    265/55/19
    2017 Audi R8 V10 Plus
    2017 Alfa Romeo Giulia Quadrifoglio - CCM Brakes
    2017 Audi Q7 Prestige
    2016 Audi TTS (Injen Intake, Burger Motorsports JB4, AP Racing 6 Piston BBK, 19x9.5 wheels with tires for sale, Vehicle Sold)
    2013 Audi S4 Prestige - Milltek Valvesonic Exhaust, Roc Euro Intake - Sold
    2012 Audi A7 Prestige (Stasis Exhaust, Injen Intake) - Sold
    May 20 2010
    A bit strange. Granted 35 aspect ratio will have a slightly softer sidewall than the 30. But the Nittos are also XL load range, so they should be stiff enough for feedback. I feel like something else may be at play (I say this b/c based on a few reviews with Audis, people say the Invos handle very well).
    If you define "beefier" as having more sidewall for a given size, you would want to move to 265/30 over 255/30.
    Jan 09 2018
    Taylorsville, GA
    I think this is one of the areas where Michelin has most folks beat. Not that the Pirelli or the Nitto are a bad tire but every car I have ever put Michelin tires on (and they were mostly sports cars but also some passenger cars and SUV's) has gained improved steering and road feel as a result of the switch. My feeling is it isn't so much the aspect ratio change (because it is so small) that you are feeling but just the difference in tire compound and tread and that you would get most or all of that feeling back with a set of Pilot Sports or 4S or the like.
    Senior Member Three Rings mossback's Avatar
    Feb 01 2015
    2017 Subaru Outback
    United States
    Some of what you are feeling might just be the opposite of what you think is happening, if the Nitto is sticky then you might be feeling the limits of the suspension, ie the car leans more. Have you done any other suspension mods? If the NItto is less sticky then you are possibly sliding more, the stock pirellis are not bad, but not great either, is this winter feel or spring summer temp feel? Rubbers are definitely less grippy in the cold.
    I run 18" wheel on mine for track 265/35 18.
    2016 TTS
    Active Member Two Rings s4 cab's Avatar
    Oct 25 2009
    2009 TT-S, 2015 A7 TDI, 1974 Lotus Europa, 2002 Ford F250 7.3L
    What's the weight difference between the 20" and the 19" wheel/tire combo? If the 19" combo is heavier, that would make the steering feel heavier, possibly interpreted as less sporty.
    2018 TTRS (MSSKits Track Pack)
    2009 Audi TT-S (APR Stg 1, APR DSG, Penske 7500DA, Blackbird Fabworx safety systems)
    2015 Audi A7 TDI (Wife's)
    1974 Lotus Europa TCS
    2002 Ford F-250 7.3L
    Gone: 1998 A4 1.8, 2002 A4 3.2 Q, 2005 S4 Cab, 2009 A4, 2010 S5 Cab, 2015 S3
    Veteran Member Three Rings Huey52's Avatar
    Dec 22 2010
    New England
    Good point. The OEM 20" are forged and therefore actually lighter than the OEM 19" low pressure cast.
    But all other things being equal it comes down to the tire compound. I too swear by Michelin Pilot Sports, as a bit more compliant while still being high performance.
    Quote Originally Posted by s4 cab View Post
    2016 TTS Sepang blue/rotor gray Tech B&O
    Prior: 2013 allroad; 2011 A5
    Mar 31 2005
    Bay Area
    Also keep in mind that new tires will always feel sloppy and loose compared to old tires.
    New tires will have better traction than old tires, but new tires feel sloppy compared to old tires in the handling dept.
    This is because new tires are on full tread and have more tread squirm.
    It takes the average tire between 1,000 to 2,000 miles to fully come in , depending on the tire compound.
    Previous...
    05.5 B7 S4 (Stock)
    07' E90 335i (KW V2's, Sway Bars)
    08' E90 M3 (Stock)
    09' Z06 (DRM Shocks)
    13' TTRS (MSS springs, APR Stage 1)
    02' Z06 (Stock)
    Current: 2016 F80 M3 (Ohlin R/T coilovers), DCT
    Jul 22 2015
    Oklahoma
    Thanks for the replies.
    Just like someone said here, could be the wheels as well.
    So should i even consider 265/30-19 ?
    Or would that look stupid on such a small car?
    Jun 14 2017
    Hopatcong NJ
    Over tireing (new word) was a big deal in my old Miata community. Fat tires rolling around on skinny rims was a big no no. 265s on a 9” rim seems fugazi to me, but I have lots to learn about my 3200lb fatty.
    2017 Ibis TT 11/4/2017 || Austins-Michelin Snows 11/17 || MSS KIT 2/18 || StopTech ST40 BBK 3/22 || REMUS valved axle back exhaust w/black tips 5/1 || Black Optic grill 5/31
    NEUSPEED RSE10 18/9/45 5/31 || Michelin Sport 4S 245/40/18 5/31 || George Smooth lV 6/4 || 034 Motorsport res delete 6/5
    May 20 2010
    Quote Originally Posted by TRZ06 View Post
    This is because new tires still have some of the mold release compound in them and it hasn't been worked out. They firm up usually 500-1000 miles in.
    Dec 22 2010
    New England
    Similarly I wish I had never gone to wider tires on my RX-8. They may have looked beefier but significantly diminished its signature steering response and handling. The design engineers usually know what they’re doing, so ...
    Jun 14 2017
    Hopatcong NJ
    To a point they do but they also have comfort and price point requirements that they need to meet, ergo GTI rims are a super silly 7.5” wide. My 225 snows roll over on my GTI Austin rims like it’s their job. I’ll be shopping for 8.5” snow wheels this summer.
    May 20 2012
    San Jose
    It's sidewall stiffness. Stiffer sidewalls give better steering response and quicker turn in, but a harsher ride. Different tires of the same size have different sidewall construction and varying levels of stiffness. As someone else noted, Michelin PSS have stiffer sidewalls than most. Read some tire rack tests, they talk about this.
