Results 1 to 19 of 19
    Aug 12 2012
    Florida
    Flashing Check Engine Light w EPL Tune and APR DwnPipe
    I have EPL Stage 2 on 2017 Audi S6 and APR Downpipe on OEM Sport Exhaust. O2 spacers were installed but I still threw a CEL. Recently I noticed some strange issues including:
    1. At WOT usually from a roll power delivery will momentarily stop bear 6000/rpm before resuming and then CEL will start blinking.
    2. When driving around town with moderate throttle car will have trouble accelerating and exhaust will sputter a little. CEl will star blinking.
    Any idea what this could be caused by?
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    sounds like misfiring , not sure if epl uses the flashing check engine light for anything it their tune like knock detection .
    id contact epl and see about using the flashing check engine light for something . if they dont get a scan and see what cylinder is misfiring
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Aug 12 2012
    Florida
    Also I just did a hard acceleration and again maybe in third or fourt gear at around 6300 rpm car was like "stuck" in gear and would not accelerate or shift to next gear for about 10-20seconds .. then it "clicked in" shifting and continued. CEL started blinking again. This was all with accelerator fully pressed down.
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    i would probably stop doing that since you voided your warranty and are possibly damaging your vehicle
    Aug 12 2012
    Florida
    I haven't voided the warranty
    But I am curious what the issue is
    A cylinder mis fire seems to match the symptoms.
    How do I fix
    I'm taking to shop Thursday
    Senior Member Three Rings Welterweight's Avatar
    Sep 22 2017
    Boston
    If you’re tuned you have voided the Audi warranty to my knowledge
    2014 S6 Black on Black
    EPL Stage 1 ECU/TCU
    20" Avante Garde
    Resonator Delete
    Magnaflow Sport
    CETE Lowering
    RS7 Intake
    35% Tint
    Sep 19 2014
    Newcastle
    Quote Originally Posted by Welterweight View Post
    EPL Stage 1 ECU/TCU
    20" Avante Garde
    Resonator Delete
    Magnaflow Sport
    CETE Lowering
    RS7 Intake
    35% Tint
    Only if the car gets flagged with the TD1. Not a guarantees loss of warranty. Enough people here who haven't theirs.
    Sent from my SM-G920F using Audizine mobile app
    Audi S6 C7.5 Avant 2016 Sepang Blue APR Stage 2, Custom Downpipes, Revo RS Intake, X-Pipe & Resonator Delete - 441WHP 528WTQ 551BHP 660 LB FT.
    Aug 12 2012
    Florida
    The car is not flagged
    Nov 18 2014
    2001A6,2013A7 C5 allroad
    Hartford
    Proper spark plugs and gaps?
    Flashing light always meant misfires to me
    Veteran Member Three Rings SubaruSTI8's Avatar
    Jul 12 2010
    NY/NJ
    sounds like a misfire not tune issue.
    either plugs or coils
    2018 C7.5 S6 BBS CH-R II | RS Grille | CF Lip STOCK
    2018 S4 Daytona Grey Pearl Prestige
    SOLD: 2013 S6 | Cold Weather Package| EPL Stage 3 Tune | EPL TCU Tune | Milltek Non-Resonated Down Pipes | Milltek Non-Resonated Exhaust | Roc Euro Intake | BBS CI-R | APR Intercooler | RS Grille
    Senior Member Three Rings GlacierS5's Avatar
    Jul 27 2017
    San Jose, CA.
    EPL Stage 1 ECU/TCU
    20" Avante Garde
    Resonator Delete
    Magnaflow Sport
    CETE Lowering
    RS7 Intake
    35% Tint
    As other stated, TD1 will flag your warranty to be voided. My car has a stage 1 tune (ECU/TCU) and recently flashed it back to oem for a smog the dealership performed. Passed with flying colors. @OP there's a posting by another member who used BD purge oil products that took care of his misfires.
    Sent from my Pixel XL using Audizine mobile app
    2018 Glacier White S5 | Prestige | Sports Pkg | Dynamic Steering | Carbon Fiber Pkg | 034 Motorsports Parts
    2016 Sepang Blue RS7 | Prestige | SRM Intake |EuroCode Sways
    2014 Glacier White S6 - SOLD
    Veteran Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    Quote Originally Posted by JBA87 View Post
    Not sure which spacers you used, but the j-shaped spacer by vibrant, using the the restrictors with the smallest holes seem to work best to keep you from throwing CELS. The errors with CAT inefficiency seem to also have some downstream effects in terms of other errors. Would recommend ensuring that is working first.
    Since you have EPL, you can flash both ECU and TCU back to your stock files and make sure you can drive around without CELs once your spacers are set properly.
    Finally, if you don't have one, DEFINITELY get a VCDS cable from Europaparts.com ($199 for a 3VIN cable), so you can do some diagnostics and clear your codes.
    2016 S6, mythos black, RS7 turbos, MRC inlets |Akrapovic exhaust| AMS downpipes and intercooler |Eventuri intake| Loba HPFPs |Tial wastegates| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights, OEM Euro tails |Sound: Navtv Zen-v preamp, Helix DSP Ultra, JL HD900/5 driving JL10W3 sub and Hybrid Audio speakers.
    Aug 12 2012
    Florida
    If it's a misfire I hope it's something as simple as replacing plugs/coils and not something more serious
    Why would these go out so soon
    I have 10k miles ok car
    Veteran Member Three Rings seandon_792's Avatar
    Aug 12 2015
    Waldorf, MD, US
    Tuning adjusts your air, fuel and spark to create more power. Increasing these things accelerates wear on each of those components. The price we pay to for more performance.
    Established Member Two Rings rhinoboymtl's Avatar
    Jun 20 2017
    Baltimore
    I have been dealing with some similar issues but I’ve finally had a bit of luck resolving it so I figured I’d share. About 1,200 miles or so ago I was due for my 75,000 mile service (which I did myself) which includes spark plugs. Since I was doing the plugs I also decided to change out all of my coil packs and go Stage 1 EPL tune at the same time (why not right?). Even with everything stock I had been feeling stutters and logging misfires since I got the car about a year ago. So I figured now was the time to get it all done.
    So I went with Bosch plugs (IKH24) and gapped them at .024 but admittedly I did not take the time I should have nor did I have the best gap tool at the time so I think they ended up varying between.024 and .026. In any case, in went the plugs and coil packs
    and everything was running much smoother than before. A couple days later I received the stage 1 tune and flashed the car. Went for a drive and almost immediately started with some pretty bad misfires which were audible along with the sputters at low RPM. After the first 100 miles I had quite a few misfires.
    I did let the car adapt for about a week and put 1000 miles on it and it was strong but still missing sporadically at low RPM. Then when I was pulling away from a stop at about 3/4 throttle I got the flashing CEL along with more audible misfires so I checked my OBDEleven and had 3 hard misfires
    The day after that I had another in cylinder 4 that was static and would not clear and was causing some nasty vibration at highway speeds.
    Time to get this fixed.
    I flashed the car back to stock and cleared all the DTCs then drove for about 10 miles and checked the misfire count. Cylinder 4 was definitely a problem.
    Bought another set of all new plugs (this time NGK) and some proper gapping tools and took my time gapping them. But this time I gapped them down to .022 instead of the .024 some are recommending. With the added boost and air density of the stage 1, I don’t think .024-.026 is tight enough. Removed the old plugs and sure enough cylinder 4 insulator was smoked.
    Put everything back together and re-flashed the stage 1 tune. Took it for a spin and WOW! No more sputter, steady low end power, no audible misfires and the oil temp actually showed a couple degrees cooler while driving around. I let it fully warm up and gave her a few WOT runs and the power is smooth and strong. No more hesitation or sputters. This car has never been this smooth since I got it even when bone stock. Got home and checked the log....
    Perfect!
    I know these cars have a lot of smarts and self adjustment in the engine, but I’m pretty convinced that some of these misfire issues may be caused by basic plug gaps that are too big for the amount of boost being generated. I know with a smaller gap you might get a slightly lesser combustion and possibly a little less power, but I’ll take the smooth low end power, no sputters and no fried plugs over that any day.
    Jan 10 2017
    CA
    Great info, thank you for posting. Pretty impressive before/after. How many miles have you logged misfire free?
    How did the plugs look on cylinders 5 and 3? For reference, I have a very similar misfire count per 1k as that would indicate (about 225 per 1k miles on cyl 5 and fewer on the others). I never feel it and from logging they almost exclusively occur in low rpm / low load situations.
    I’m on original stock plugs right now. Planning to switch to the new OEM ngk plugs when I get around to it.
    2016 Daytona Gray S7. Black optics + sport pkg. Stage 3, eurocode stuff, cosmetic stuff.
    Jun 20 2017
    Baltimore
    Quote Originally Posted by kpriv View Post
    I put about 30 miles on last night all over the range of throttle and loads with no misfires. That’s significant for me since I haven’t been able to get even 10 miles of normal driving without a stutter or misfire since I got the car last June.
    The other plugs all looked ok. The only one that had a static fault was #4 which was the bad one.
    Jun 20 2017
    Baltimore
    Just following up after a couple weeks and about 600 miles here are my misfire counts
    The car is still running much better than before since I went with the smaller plug gap, but still getting the occasional shutter. It’s strange... seems to be intermittent and not dependent on engine temp. Some days it’s wonky, some days it’s great! Going to keep looking into this a while.
    Veteran Member Four Rings 1975audi's Avatar
    Nov 15 2012
    2013 ALLROAD B5 S4
    Ancaster Ontario
    Quote Originally Posted by rhinoboymtl View Post
    Subscribed.
    Great info
    Sent from my SM-G955W using Audizine mobile app
    2007 RS4
    2000 B5 S4 stage 3
