Results 1 to 34 of 34
    Feb 18 2013
    Silicon Valley, CA
    Serious: Why would someone build a 1.8t instead of a 2.7tt?
    I have been looking at amateur rallying, and thought a B5 S4 would make a good rally car. The more I looked into it, the more I saw preference for a 1.8t. And beyond that, I saw quite a lot of 1.8t parts to build blocks, and make big HP numbers (600+). As someone who was planning to STK a 6262 on my next B5 S4, and make 600-700 HP, this seems odd.
    The only advantages I see in a B5 1.8t vs a B5 S4 are:
    Initial Price
    - The price is a B5 1.8t is lower than a B5 S4. Not by a ton, but they can be had for cheaper
    Less parts/more empty engine bay
    - 2 less cylinders means less forged pistons/rods/bearings/etc.
    - Mounting the turbo on the top side makes it a hell of a lot easier to work on
    So, I would like to get your feedback on this.
    Veteran Member Four Rings ReggieNoble's Avatar
    Dec 17 2016
    B5 S4 Avant
    Fl
    Bt 1.8t's are nice ( owned 3 of them ) but will never have the low end power of a 2.7t. In rally it's all about low end and maintaining speed. Also in my opinion a single turbo 2.7 would not be as near fun as having a solid k04 car.
    Sent from my R1 HD using Audizine mobile app
    May 20 2010
    1.8t is also lighter than the 2.7t, so that's a factor as well. Lighter=faster, for a given power.
    Jun 07 2005
    Shepherdstown, WV
    1.8t also simpler, even a STK on a 2.7t is a lot more complicated than the 1.8t. That makes it cheaper to run and there is less to go wrong.
    Also check that engine build thread costs. For the costs of building just the engine some people are listing you can do the engine and the turbo setup on the 1.8t.
    80 rabbit pickup, 98 TJ 4bt cummins, 00 180TTQ 6spd, 02 Freelander, 03 Allroad 2.7t 6spd swap now with K04s, 06 A3 2.0T w/GT3071R (2012 JSW TDI and 2015 GSW TDI now in TDI purgatory )
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Cheaper to build, easier to work on, lighter(very important), possibly more reliable but that's kinda iffy when talking both built motors big turbo
    It really depends what kinda racing ur planning to do also and what ur budget is.
    Starting cost for b5 a4 can be as low as 500 vs a few grand or more for a s4.
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    May 20 2010
    Quote Originally Posted by chris86vw View Post
    less to go wrong
    Sounds about right
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    There's also more of them out there.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    May 27 2016
    Westchester, NY
    Driving a stage 2 k04 1.8t B6 now and I can tell you the k03(stock turbos) with stage 2+ tune and open DP and custom exhaust just felt twice as powerful down low and the torque was constant on any gear. From being able to do 60mph in second without an issue to not having to down shift in sixth gear to pass anyone already going 80mph. Just no substitute for displacement and when the twin turbos are working and no leaks it’s a great thing. That said, I would love to see the vrT setup to compare.
    Veteran Member Four Rings ActiveMonkey's Avatar
    Jan 27 2006
    C7.5 A6 3.0T Prestige
    Orange County CA
    I love the was a running 2.7T feels (i have 2) however there is damn near nothing i can't fix on the 1.8T over the course of a night. The repairs on the 1.8T are sooo much easier in every way. When i snapped my 1.8 taming best i threw a new head on it the next day and all was right as rain.
    Current: 2016 Audi A6 3.0t Stage 2+
    Old: 2000 Audi S4 Stage 3 - SOLD | 2000 Audi S4 Stage 3 - Deceased | 2002 Audi S4 Avant - SOLD | 2000 Audi S4 - SOLD | 2003 Audi A4 - SOLD | 2001 Audi A4 Quattro - Deceased | 1998.5 Audi A4 Quattro 5MT - SOLD
    Jun 07 2005
    Shepherdstown, WV
    Quote Originally Posted by ActiveMonkey View Post
    HA I know exactly what you mean there. It was my 2.0T but 800 miles from home (luckily near my parents though) I cracked a spark plug on the dyno and destroyed my head. Grabbed a spare from a friend in the area and swapped it in my parents garage to head home the next day.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Simplicity, ease of maintenance, ease of performance upgrades, etc. as mentioned above.
    I've had a 1.8T in 3 different A4s since 2010. My current B5 A4 has been pretty solid and quick: 277awhp + 309awtq on an older F21 + rods + E85, with all the other supporting mods. In my mind it's faster than a stage 1 B5 S4 on pump gas, possibly faster than a stage 2 S4 (but maybe not on E85). Also more nimble because of less weight.
    Recently I picked up a B5 S4 Avant, and it's my first personal venture into the 2.7T. You still have access to stuff on the 2.7T, but have to allot way more time because of all the "layers" of parts to remove.
    Also 2.7T has way more parts! Two banks means 2 of almost everything; that's double the VCGs to fail/leak, twice as many cams, substantially greater intake tract for leaks, etc. So higher cost and in some cases almost double the labor time when it comes to maintenance.
    2001 Corvette (C5) Z06
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Lake Lanier, GA
    I enjoy building a 1.8T, and done a couple of them. It's so easy, less to go wrong, more room, etc. It's just fun, but not swap worthy into anything else IMO.
    Yep, same. I bought my current b6 with a bad head on craigslist for almost nothing and went to the junkyard and had it running the same day.
    Feb 18 2013
    Silicon Valley, CA
    So based on all of the people in here who have built a 1.8t to high power levels, would that be the way to go instead of a built 2.7tt B5 S4 with a STk+6262 turbo+E85?
    Seems like you can make nearly the same power level on the 1.8t, and its a bit more unique IMO.
    Jun 07 2005
    Shepherdstown, WV
    Quote Originally Posted by aysix View Post
    Sure it is, even a crusty high mileage bone stock 150hp version is worthy of a swap into say a rabbit or hell all the way up to a mk3 golf/jetta. Fined a tuned totaled parts can and you can double your power for under a grand in a weekend.. That is very worth it.
    Feb 06 2012
    Lake Lanier, GA
    Quote Originally Posted by Tumbler510 View Post
    Aint.
    1.8t's will make the power, but the 2.7 will be spooled up and gone by then.
    Dec 17 2016
    B5 S4 Avant
    Fl
    Aint.
    Agreed...I guess non of these guys ever watched group B. The v6 turbos dominated. They were so fast and dangerous that they did away with all the v6 cars. Not saying there wasn't a few 4 and 5 cylinders in group B. Now all you can race in group A is up to a 1.6 with no more than 380bhp. It seems wrc is turning into formula 1. What a shame.
    Apr 07 2011
    Home of the mighty beaver
    To answer the question posed by the original subject:
    A: Because you are poor.
    Feb 06 2012
    Lake Lanier, GA
    Quote Originally Posted by S4James View Post
    lmao
    Feb 18 2013
    Silicon Valley, CA
    Quote Originally Posted by ReggieNoble View Post
    That's actually what started this entire thinking in my head. Rewatching more Group B documentarys and race footage.
    Effing ridiculous even after all this time!
    Dec 15 2015
    Perth Western Australia
    I think the 1.8t would handle better when modified to the max because of less weight in front of the front axel compared to the S4's heavy V6. In rally, turning is more important than out right power.
    Jan 27 2006
    Orange County CA
    1.8 Engine w/ turbos is ~350lbs
    2.7 Engine w/ turbos is ~420lbs
    Really not much weight savings if you ask me. Especially when you're going to have to throw one hell of a large turbo on the 1.8 to match a 2.7 with pjK04s. just my $00.02
    Dec 17 2016
    B5 S4 Avant
    Fl
    Quote Originally Posted by Perth_RS4 View Post
    You'd be surprised how much a lighter car will slide around, the weight in some cases will help. Especially how the grooves will form on the corners, from the other cars. At that point it becomes having the HP wins
    Dec 17 2016
    B5 S4 Avant
    Fl
    Yeah the footage is amazing, and the drivers and co-drivers are even more amazing. Watching in-car video always blows my mind.
    Dec 17 2016
    B5 S4 Avant
    Fl
    I think the biggest killer on the 2.7 would be the heatsoak.
    Dec 17 2016
    B5 S4 Avant
    Fl
    Plus I noticed the 2.7 is way more consistent day to day then my 1.8t's where. I swear one day my 1.8 would feel like 500hp then the next day it would feel like 50hp. It all depended on how it felt that day lol
    May 27 2016
    Westchester, NY
    On a side note, today it has been icy in NY and I missed the weight of the motor in the B6. If you want competitive driving then torque is where it’s at. Hands down. Torque = acceleration.
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    lighter & cheaper as stated. I would consider power targets and turbo lag. Even if you can get the 1.8 as high HP it's just not going to be as fast due to lag (absent anti-lag); but the weight will offset that depending on the track. For a rally car, absent a bunch of high-speed courses, I wouldn't really be focused on peak power so much, so if you're looking to make 300 horse, the 1.8 might be a better choice when you piece in all the different factors.
    I'd also consider things like differentials, starting weight, etc. Like most of what you're paying for in the audi are going to be stripped out anyway, and replacement costs are generally higher. Buying a piece of crap subaru might be a cheaper route if you wanna stick in 4wd classes (granted I'm not the biggest suby fan cause I've had/seen reliability issues). Similar thoughts:
    talon/eclipse
    evo/galant
    E30 IX
    Apr 07 2011
    every 1.8t contender in my town has gone down to my lightly modded 2.7T :)
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Ephry73 View Post
    Lots of good answers here, this is the best.
    I have both in my garage, a BT 1.8t B5 and a 2.7tt. The 1.8 is a ton of fun, it pulls great once spooled, and makes all the sweet riceboi noises. But then I jump in the 2.7, keep it in 3rd around a tight corner, and I can hardly tell it should be in second. Passing on the highway does not require downshifts. In my 1.8t, I'm constantly searching for gears to find the right rev range to make power.
    They are just two different cars. Why can't we have both?
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Feb 18 2013
    Silicon Valley, CA
    Quote Originally Posted by redline380 View Post
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    Cool Bump
    ............. If you want competitive driving then torque is where it’s at. Hands down. Torque = acceleration.
    OK- Will a Cummings Diesel slip into a B5 without to much trouble....
    Only kidding!
    Jun 07 2005
    Shepherdstown, WV
    Quote Originally Posted by LJS View Post
    Only kidding!
    Ha was going to say I once drove a cummins equipped 3500 over 200 miles without shifting out of 6th gear, as slow as about 35 and as fast as about 80.
    4bt might fit lenghtwise, I can measure tomorrow..
    But they are a little tall :)
    May 27 2016
    Westchester, NY
    Only kidding!
    Well another option is a diesel TDI motor. I had a golf Tdi MKIV stage 2 and that thing was a beast!! Bobs of torque from 1,800 rpm all the way to 4,000+. Never had it dyno’ed but definitely had to be in the 240ft/lb+ range. That was a mild tune and open down pipe to magnaflow straight through muffler with stock turbo and nozzles. There’s good tunes and hardware out there to put you in the torque range you need and higher horsepower albeit in a small diesel. But you will need to change your fueling etc. just a thought. A nice diesel Tdi Quattro A4 with a good tune would be a beast.
    E
    Veteran Member Four Rings VR6Bomber's Avatar
    May 13 2009
    XXXX
    I know that this has been touched on already;
    You've seen teams pulling EJ's out of subaru's in between stages, that's not going to happen with a 2.7t without significant resources.
    Rally racing a b5s4 would be a very expensive proposition.
    I would vote 1.8T for any competition motorsport. easy to come by, easier to fix, cheaper all around etc
    Honestly, if this is your first try at rally, you should probably build your skills with a N/A 2wd vehicle waaay waay waay before jumping into turbo awd. Turbo awd will put you against veteran teams and factory backed team cars only put out about 300-400 hp, these guys are pros.
    Mk2 Golf is the 'go to' beginner rally car, Neons and regular ford focus too
    2.5 impreza if you want to jump right into the awd class
    GL
