I'm next inline to do that job. I have a A3 8P with BWA engine code.
It sorts of sound like a potatoe right now at idle, with some occasional vibrations and occasional diesel sound. (though no misfire registered in OBD counters read for smartphone apps. maybe it's loose balance shafts, or the bimass flywheel).
I'm considering that ECS kit here:
https://www.ecstuning.com/b-assemble...06d109229bkt2/
is this kit ok? I'm worried about the INA cam follower. I want a Febi-Bilstein, because the one I have now is INA, and it was lighter than the OEM one I removed. I have a suspicion it's the culprit for part of the noise.
The car inspection garage put oil additive and the sound has improved.
For the chain job change, I'm stressed about
- the polydrive bolt
- the 3 round seals on the control valve conduit
- do I need sealant as well as the gasket for the chain cover?
- how many links are there supposed to be between the cam-phaser notch, and the tiny mark on the intake shaft sprocket? I read the mark is supposed to sit between link 9 and 10.
- do you need a long extension to crank the engine?
- I'd prefer to sit the valve cover gasket with a glue prior to closing, to avoid that it shifts out of seat and pinching it wrong while closing. But don't know what product to buy. My valve cover was already changed a few months ago.
