Curious what driveline inserts people have gone with and which seems to be the best bang for the buck.
I'm looking at a few "kits" which have the transmission insert along with four differential inserts. Problem is, I already have the Apikol rear diff mount. http://www.apikol.com/index.php/prod...-mount-b8.html
I'm not sure which mount the Apikol is actually and I'm not sure if "upgrading the other mount(s) is worth it if I have the Apikol. Here's a diagram of how the rear diff mounts in the subframe...
They list it as a "rear" differential mount but I see two mounts in that diagram above (#8 bolt plus the duplicate on other side which is not labeled with a number). Not sure if they're referring to the entire "rear differential" in reference but it looks like #1.
With that said, I'm assuming there are parts of the "kits" which would be redundant given that I have the Apikol but I'm not sure which part. I see three offered, 034 solid, ECS with polyurethane and Forge, which are also solid like the 034's but are about $50 less expensive for the entire kit. If I end up not needing part of the kit, I'd probably just add the rear subframe inserts and buy only what I need (transmission insert plus one of the diff inserts).
With the above options, I'm debating whether to go poly or solid. ECS says no increase in NVH with their kit and I've heard even the solid kits really don't introduce anything either. Poly will eventually wear whereas metal will not. I do not want a significant increase in NVH.
Lastly, since I'm lowered and running H&R sways, I'm debating going with adjustable front swaybar links. I've heard aftermarket units tend to make a lot of noise on our cars but I can't imagine my sways are loaded correctly with the front OEM mount. Passing on the rear adjustable links as no one offers an adjustable version.
Feedback from track or aggressive street/canyon carvers much appreciated.
