Results 1 to 4 of 4
    Veteran Member Four Rings Andrew149's Avatar
    Apr 19 2009
    Modesto/CA
    Airbag code Driver side 00588 and AC codes
    So i have been getting this code for awhile now and i have cleared it out several times and the code keeps coming back looks to me to be the driver side steering wheel bag? whats the fix a new airbag or clock-spring? tie-wrap the connection possibly?
    Date: 2018-01-26 11:34
    VIN: WAUKF78E78A038554
    Car: Audi A4
    Year: 2008
    Body type: Avant
    Engine: BPY 147 kW (200 HP) 2 l
    Mileage: 271200 KM
    15 Airbag
    System description: Airbag 9.41 H01
    Software number: 8E0959655M
    Software version: 4240
    Hardware number: 8E0959655M
    Serial number: 003CS0G081SA
    Coding: 0032607
    Subsystems:
    System description: BF-Gewichtsens. H03
    Software number: 8E0910339D
    Software version: 0080
    Trouble codes:
    00588 - Driver side airbag igniter Upper limit exceeded
    Intermittent
    Priority: 1
    Frequency counter: 1
    Driving cycle: 255
    Measurement: 1.0 °v.OT
    Also getting these codes with my AC
    Car: Audi A4
    Year: 2008
    Body type: Avant
    Mileage: 271200 KM
    08 Air Conditioning
    System description: A4 Klimaautomat 3233
    Software number: 8E0820043BM
    Coding: 00000
    Trouble codes:
    00601 - Potentiometer - positioning motor for central flap Open circuit/short circuit to B+
    Intermittent
    00716 - Recirculation flap motor locked or has no voltage supply
    Intermittent
    01172 - Temp. sensor, driver seat Open circuit/short circuit to B+
    static
    01171 - Temp. sensor, frt. pass. seat Open circuit/short circuit to B+
    static
    2012 Audi A6 3.0t
    2019 GTi 2.0t 6 speed
    2013 Touareg VR6
    Oct 13 2017
    Kegums/Latvia
    On the B5 this code sometimes meant airbag wiring under the drivers seat had corrosion. Maybe check that!
    Sent from my E5823 using Tapatalk
    Apr 19 2009
    Modesto/CA
    This is what the code comes up as but I’ve seen where people say it’s the steering wheel or the driver side seat.
    I also have B6 S4 seats and the 3 spoke steering wheel.
    2012 Audi A6 3.0t
    2013 Touareg VR6
    Apr 19 2009
    Modesto/CA
    Is this the ac motor part I need the blend door motor? https://www.ecstuning.com/b-genuine-...ue/8e1820511l/
    2012 Audi A6 3.0t
    2013 Touareg VR6
