Thread updates with DIY from the A5.
It's a bit confusing cuz the translation was far from.perfect but I did my best and I think there's enough info here to get this done.
Remember not all the parts quantity will be the same.a sedan obviously needs 4 door sensors and plugs for the harnesses
AND,
A lot of these parts and directions in this DIY will change having the harness from Ali it will be a lot easier.
AND the coding might not work, someone else that knows.more about coding can confirm this.
I really thinking having the harness from Ali will help a LOT. And cut out a LOT of steps and parts from this DIY, I w/o t know for sure until I get the harness but I am.guessing you won't need any of the wiring or plugs listed.
Also B8 dude I sent you a.pm asking if you could delete your first post so the thread flows better I know you can't delete the post entirely but at least just remove the text would help it look better. Thanks
Hope this information helps anyone looking to do this.
Sent from my SM-G935T using Tapatalk
