Results 1 to 26 of 26
    Feb 20 2010
    2009 Dodge Journey, 1998 Passat AEB, 1999 Passat AEB, 2000 A4 ATW, 2002 A6 3.0/2.7T tiptronic KLR250
    Brighton, MI
    2013 A4 - 10425 low fuel pressure during start AND 2837 Fuel Rail pressure too high
    Suggestions what might be causing the 2 codes?
    Gas mileage 10% down.
    Where to start with troubleshooting?
    40k miles.
    All stock.
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Established Member Two Rings kewe24's Avatar
    Dec 10 2011
    Des Plaines IL
    Chain and tensioner.
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    Owings Mills, Maryland
    All stock at 40k? Any warranty?
    2013 A4 Scuba Blue Metallic | APR stage 2 | AWE | Milltek | GFB+ | Suntek | Solo-Werks | Eurocode | Blesk | 034 | ECStuning | CR-15 Strut brace | Apikol | R8 Coilpacks | NGK | Akebono | Hawk |MRR-GF07 19x9.5 ET38 | 18x8.5 peeler reps ET 40 (winter)
    Nov 20 2016
    are you sure about those codes?
    Feb 20 2010
    Brighton, MI
    As sure as can be. Also erased to check if/that they return:
    Wednesday,10,January,2018,15:23:56:03761
    VCDS Version: Release 17.8.1 (x64) Running on Windows 7 x64
    www.Ross-Tech.com
    Address 01: Engine Labels: 06H-907-115-CDN.clb
    Control Module Part Number: 8K5 907 115 J HW: 8K2 907 115 L
    Component and/or Version: 2.0l R4/4V TF H09 0002
    Software Coding: 4A2A0013242600062000
    Work Shop Code: WSC 64544 001 1048576
    ASAM Dataset: EV_ECM20TFS0118K5907115J 001003 (AU48)
    ROD: EV_ECM20TFS0118K5907115J.rod
    VCID: 3978A003B857238E96-806C
    2 Faults Found:
    10425 - Fuel Pressure too Low during Cold Start
    P053F 00 [096] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 69314 km
    Date: 2018.01.09
    Time: 07:42:46
    Engine speed: 2981.50 /min
    Normed load value: 59.2 %
    Vehicle speed: 53 km/h
    Coolant temperature: 18 °C
    Intake air temperature: 3 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 13.829 V
    Unlearning counter according OBD: 38
    Engine status: COENG_RUNNING
    Engine oil temperature: 7.3 °C
    Engine operating condition-Channel 87: Part. load
    Relative load value: 105.70 %
    Current system status: SYC_DRIVE
    Engine torque: 248.8 Nm
    2837 - Fuel Rail/System Pressure
    P0088 00 [096] - Too High
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 68792 km
    Date: 2018.01.03
    Time: 14:26:16
    Engine speed: 2461.00 /min
    Normed load value: 54.5 %
    Vehicle speed: 64 km/h
    Intake air temperature: 0 °C
    Ambient air pressure: 980 mbar
    Voltage terminal 30: 13.782 V
    Unlearning counter according OBD: 31
    Engine oil temperature: 5.0 °C
    Relative load value: 107.30 %
    Engine torque: 211.2 Nm
    Readiness: 0000 0100
    - - - Updated - - -
    Quote Originally Posted by SleeperCar View Post
    All stock at 40k miles.
    05 Golf TDI
    Nov 20 2016
    If you don't have a high pressure fuel system tester, i'd replace the sensor, they are pretty cheap. BOSCH 0261545050, worst case scenario id suspect the solenoid on the HPFP is having a problem but thats about as far as I can get on that without testing that car with better diagnostic tools, taking actual fuel pressure measurements and not relying on the sensors.
    Jan 03 2012
    Hey OP my question was eluding to... are you covered under any warranty, because then you could just get this looked at by a dealer
    Feb 20 2010
    Brighton, MI
    Can i access the fuel pressure sensor or sensors with VCDS?
    05 Golf TDI
    Nov 20 2016
    Quote Originally Posted by vtraudt View Post
    yes but i dont have a VCDS to tell you which parameter to look at, my scan tool you just search for it by what it is, "fuel pressure actual value"
    Feb 20 2010
    Brighton, MI
    Will check next time I have access to car. At the the 'high pressure' code. The 'low pressure when cold' I may not be able to catch.
    Both are identified as intermittent, and frequency appears to be rather low.
    05 Golf TDI
    Jan 03 2013
    Baltimore
    If you still have warranty, take it to the dealer and let them handle it. Report back here with their conclusion.
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by elscotto80 View Post
    If I can't come up with any ideas for troubleshooting, I have to bite the bullet and bring car to dealer (2 hour round trip, rental car, etc.); pretty much a workday lost.
    Aside from no factory warranty, only extended warranty with co pay ($80).
    05 Golf TDI
    Established Member Three Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    Your dealer won't give you a loaner car while they work on yours?
    2011 A4 Avant Prestige S-Line
    Feb 20 2010
    Brighton, MI
    Not sure if it is part of the extended warranty purchase agreement.
    05 Golf TDI
    Jan 03 2013
    Baltimore
    Call them up and ask. When I had Audi care a laoner was included whenever I took it in.
    Sent from my Pixel using Tapatalk
    Feb 20 2010
    Brighton, MI
    They will come get the car next week and leave a loaner.
    Will see what they determine as the source.
    Also noticed coolant was a bit low (not at min yet); added to the list to check for them.
    05 Golf TDI
    Jan 03 2013
    Baltimore
    Nice. Let us know how it goes and what the issues were.
    Active Member One Ring iesales's Avatar
    Apr 07 2009
    Halifax, NS
    Did the dealer solve the issue? I'm throwing the same codes without any warranty left.
    Feb 20 2010
    Brighton, MI
    Today's update: the cam chain was elongated (also drives high pressure fuel pump). They are putting a new chain and a new chain tensioner on.
    Never heard this before.
    We'll see if that is the fix.
    I assume they have to get approval from Audi USA (based on symptoms, findings) so the verdict must be Audi approved.
    05 Golf TDI
    Nov 20 2016
    interesting....very interesting
    Feb 20 2010
    Brighton, MI
    Drastic measures. I would assume the actions are based on proper analysis and that Audi USA (if they are involved) would have concluded that way prior to approving (if they approve such warranty work; in this case extended warranty purchased from the dealer with the car; $85 per incident co-pay).
    05 Golf TDI
    Aug 04 2013
    Pennsylvania
    Did the chain fix it? I have a car with the same codes at work. I've read a few accounts where these two codes popped up due to a stretched chain but my timing appears to be spot on.
    I'm like a tree. I'm all root
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by Mille Bornes View Post
    Yes, car is fixed.
    05 Golf TDI
    Aug 04 2013
    Pennsylvania
    Thanks for the reply! I double checked my timing and it does appear to be off a bit so I guess I'll be starting there
    Active Member Three Rings
    Jun 17 2018
    Colorado
    Huh. This is indeed super interesting. Can you read the cam phaser adaptation? I’m wondering how far out it needs to be to cause this.
    Jun 17 2018
    Colorado
    ‘Camshaft Adaptation Intake Bank 1, phase position’, as here: https://www.audizine.com/forum/showt...ser-adaptation
