Hey guys, I've been starting to have the CEL come on for P0171 (lean bank 1) these past few days and trying to figure out the issue. Also have P0411 incorrect SAI flow, but I can't see how that's related.
This is a 1.8T with an APR Stage 1+ which uses TT225 injectors (386cc), only other engine mods are a Forge DV and 034 HFC.
Things I've checked:
1. Vacuum is good, boost gauge is reading -19 to -20 inHg. Checked vacuum lines in engine bay, couldn't hear/find any leaks as well.
2. Did a pull to redline in 2nd and 3rd while logging MAF values (g/s) and got a maximum value of 130 g/s which seems very low considering APR tune is rated at 235hp and rule of thumb is that max g/s value should be 80% of rated HP, or about 188 HP.
3. Logged short term and long term fuel trims. Short term looked normal, but long term slowly creeped up to +24% at cruise, confirming the P0171 code that's being set.
4. Max boost during pulls was about 13 psi. Normally it spikes to about 20 and tapers to 18.
Need to check:
1. Boost leaks. However, I would be running rich and not lean if there was a boost leak, correct?
2. I disconnected the MAF but forgot to reset the fuel trims, didn't notice a difference and boost still seemed low (7 psi).
Does the ECU limit boost if the LTFT are very lean? I would imagine if it is pulling as much fuel as possible, then it would limit boost as well.
When I reset the fuel trims, I noticed that I was able to get about 15psi of boost.
The MAF currently installed is an "OEM" one from an online vendor, but has no Bosch markings or anything on it. I installed it about 2 years ago, after a misdiagnosis that the original was bad.
I'm thinking the current MAF is going bad, but wanted to verify before swapping it out blindly.
