Results 1 to 9 of 9
    Veteran Member Three Rings leftovers's Avatar
    Apr 14 2009
    ottawa, il
    Stasis Exhaust Flex Pipe Repair???
    I have an older Stasis exhaust for a 6MT car that came with the downpipe. The flex joint has now failed and I need to either buy another one or repair this one. I know Europa now basically has the old Stasis exhaust system. I contacted them over the holiday weekend, but understandably haven't heard back. I'm not sure if they will sell the downpipe separate or not.
    Any thoughts on repairing this one? Is it a "universal" part? Can I just buy a stainless 3" flex coupling in a certain length and find someone to tig weld it into place? Any idea where I would find one of those?
    Thanks for the help.
    Pics:
    2004 A4 Ultrasport, 1.8T, 6MT
    Instagram: audi_ute_build
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    Buy a flex which is interlock internal, have a shop weld it in. I’ve built 3 Downpipe myself. Simple job to do for a welder with a bit of skills. Stainless will be fine TIG w some 309L filler I believe should fix it all up and last for awhile longer. If you can see the inside of it snap a pic and post. I’m not sure what style flex stasis used but I have always spent a bit more and used interlock style flex for it IMO should outlast most stuff out there. Vibrant makes some nice stuff but a lot of other stainless stuff I’ve purchased on fleabay has treated me very very well.
    Honestly easy fix. Just find a shop who does custom stainless exhaust and has a good rep for welding skills.
    Veteran Member Three Rings king_j's Avatar
    Sep 09 2009
    Minneapolis
    If it helps, Thermal R&D made the exhaust.
    2006 A4 2.0T Q. S-Line 6MT - Arctic White
    JHM stage 1, 034 hfc, Europaparts exhaust.
    Miro 111 18x8.5 et 35, 034 RSB.
    Aug 09 2012
    Sylvania OH
    As Canadian noted, you should have no problem replacing the flex portion only. I had the same problem on my Techtonics Tuning downpipe and it was easily fixed at a local euro shop.
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by Sylvania A4 View Post
    Same here. I had mine ed twice
    Veteran Member Three Rings A4B7Avant's Avatar
    Jun 07 2017
    PA
    2x huh? Operator error?
    Quote Originally Posted by vce1232000 View Post
    2019 A4 P+ Brilliant Black, Black Optic, Sports Pkg
    2008 A4 Avant SE Ibis White SOLD
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by A4B7Avant View Post
    1st time I blew out the steel woven braiding on the ends. 2nd time I had some scrapes from crossing over the dividers on the highway. Im on my 3rd 1 now. Seams to be holding up this time. This KO4 push's out some seriour exhaust psi when wot
    Established Member Two Rings DoublebassDemon's Avatar
    Dec 07 2018
    St Andrews West/Ontario/Canada
    Any recommendations/links for flex pipe to replace the ones on the Stasis exhaust for my Audi S4 B8 3.0t? Any help would be greatly appreciated! First time I ever look into these and I want to make I sure I get the right ones and best quality. THANKS!
    Sent from my SM-G930W8 using Tapatalk
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    @leftovers Thermal R&D manufactured the exhaust so you might get lucky giving them a call... sent you a PM.
