Results 1 to 14 of 14
    Jan 05 2017
    Long Island NY
    Question/Help on Color Matching Gloss Black RS Grill and Non Gloss RS-style fog light
    Hi guys
    Wonder if anyone has come across this. Just received a new RS style grill in gloss black and also from the same vendor, a set of honeycomb fog light grills that are much less glossy. Before I put this on I was thinking it would make sense to try to color match the fog light grills with some kind of glossy topcoat. Wondering if anyone has any good experience with some relatively high durability spray paint to glossy them up a little?
    Pics below, not the best quality I know, but hopefully shows the difference
    Dec 20 2016
    OC, CA
    To be honest, not sure if you’ll be able to see that much of a difference when on the car.
    Out of curiosity, where did you get the fog grilles? I have ones that look exactly the same I haven’t put on yet. Oddly, I’m in the opposite situation. My grille is matte black and the fogs only came in gloss. So I’m kinda wondering the same thing but in reverse lol
    Jan 05 2017
    Long Island NY
    Quote Originally Posted by jak77 View Post
    I got them off the Walmart website strangely enough. Were about $170 for the pair
    Veteran Member Four Rings GeoJoe's Avatar
    Jun 08 2012
    Q7, Q5, 2016 Porsche GT4, Subaru Sambar, Honda Acty Van and a 2018 Tundra Loooooooong bed
    ATL GA
    I took my glossy mesh to a paint shop and had them matte out the black. A couple of rattle cans would probably do just as good.
    Senior Member Two Rings alexdell's Avatar
    Jul 29 2011
    Central NJ
    I have a similar glossy grill & just installed the same fog light grill. I can’t really tell the difference once installed.
    While I’m assuming the open fog light grill might help w/ better airflow to the intake, I’m actually more concerned that a bunch of debris/rain/snow/salt would go in the area of the now exposed components. It might just be paranoid but don’t know the long term impact. Thoughts?
    Here are some pics as a reference:
    Veteran Member Three Rings 850tgul's Avatar
    Mar 18 2017
    Plymouth, MA
    I sprayed my oem fog light grilles with a glossy black paint to match my gloss black RS4 grille and it came out great. Since it’s gloss black going over flat black when you get a little chip it really isn’t noticeable at all. I forget exactly what I used but really any exterior gloss black meant for plastic will suffice. Depending on the texture of that aftermarket fog grille, you may want to first hit them with some type of adhesion promoter. Wasn’t necessary for the stock grilles.
    Nov 12 2017
    Ahwatukee Az
    Quote Originally Posted by davies0186 View Post
    Can you post a link to these from Walmart, tried searching came up empty
    '14 S4 | misano red | stage.. uhm .. it's just a fast stage...|
    Dragy: 11.27 @ 124.33 & 0-60 3.03 (sub 3’s here I come)
    Dec 20 2016
    OC, CA
    Okay we have the same ones then. I’ll try and look up the link used...don’t have it handy
    Jan 05 2017
    Long Island NY
    Quote Originally Posted by dculber View Post
    Here ya go:
    https://www.walmart.com/ip/2013-2016...mper/468488626
    And a couple of pics with them on:
    I went the route of gloss black spray paint form Home Depot to color match and I’m happy agh how it came out.
    On the Walmart grill only thing I don’t love is the mount for the rings is not honeycomb- just a big chunk of black plastic. I sprayed it gloss too, but I would prefer it to be honeycomb or just the shape of the rings
    Jan 05 2017
    Long Island NY
    Quote Originally Posted by alexdell View Post
    Looks great- I did the same thing with the gloss black spray too. Yes I was also concerned about the openness and bought some wire mesh to mount behind it but didn’t like how it came out so didn’t mount it. I will have to just check on it once a month or so make sure there’s no debris, rocks, squirrels etc lodged in there
    Jan 05 2017
    Long Island NY
    Quote Originally Posted by 850tgul View Post
    Thanks, that’s the route I went with
    Jul 29 2011
    Central NJ
    Alternatively, I bought mine from eBay. It might be the same seller. It shipped from CA & it’s the same price. Here’s the link eBay link
    Dec 14 2017
    Windsor, ON
    Where are you folks getting the gloss black RS4 grille? How is fitment? Seems like everyone is out of stock atm and I don't want a cheap Ebay special.
    Jan 05 2017
    Long Island NY
    Quote Originally Posted by B8S42011 View Post
    Mine was a cheap eBay special that is also available at Walmart which is where I got it:
    https://www.walmart.com/ip/2013-2016...LACK/983587419
    Currently out of stock though. Figment seems
    Fine
