Originally Posted by
fstr n u
http://www.vdamper.com/30-V6-TSI-Supercharged_p_42.html
1. If I was to install a 203 mm crankshaft pulley and leave the supercharger pulley I would need a stage 2 tune...is that correct?
2. What advantages are there to installing a DP (smaller supercharger pulley and a 183mm or 179mm crank pulley) vs just doing a 203mm?
3. If I was to consider the stage 3 option which pushes the stock blower to max Rpms does a stage 2 tune cover things or does a person require special tuning? Are there any other considerations at this stage?
As I'm a 6MT person I know I need a SS line, clutch/flywheel (at some point), cooling upgrade, drivetrain mount upgrades, air intake upgrade and probably a short throw shifter.
Ryan
1. For APR, you just need a stage 2 tune. It's good for all pulley ratios from 2.81 to 3.24. For most other tuners, you need a DP tune that utilizes the extra boost. For example, you'd buy the EPL stage 2 tune and 'add-on' the DP tune like you'd do for a race fuel file.
2. The biggest disadvantage is cost, as most who run 203mm go with the more expensive Fluidampr you linked. You could go with a solid crank from KI though. Otherwise, the crank only is mostly advantages like easier/cheaper install and more belt contact.
3. There isn't a 'stage 3' per se currently. Changing pulley ratio is considered stage 2, and APR is calling the UC (TB) 'stage 2+'. We've generally termed the higher pulley ratios 'DP', and Unitronic uses the '+' to designate 93 over 91 octane. With all that said- the nomenclature gets a little confusing. If you're new to the platform, it's not advisable to go above the typical DP ratios (~3.2). Above that requires 'special tuning' that not everyone supports (or stacking a Chipwerke). In fact, I'd say stay at 2.8x until you really know what's going on. Above that requires experience and knowledge more that anything. You have to be able to properly monitor and access the car's performance and health with the ability to make the necessary adjustments as needed based on ambient conditions, fuel, driving cycles, etc... The main hardware consideration at higher pulley ratios is always cooling though.
