Page 2 of 13 FirstFirst 123412 ... LastLast
Results 41 to 80 of 504
  1. #41
    Junior Member Two Rings
    Oct 27 2014
    NEPA
  2. #42
    Senior Member Three Rings plim's Avatar
    Oct 24 2010
    Quote Originally Posted by skifreak85353 View Post
    I’m a little higher than that so the 40 sized tire (typo in my original post) should work quite nicely. I assume it will also smooth the ride out slightly over the 35s I’m on now?
    I used this site to figure out tire size. 255/40r19 is really close to stock size so the ride quality should be very similar. Slightly harsher because going from 18 to 19 obviously, but not very noticeable.
    willtheyfit.com
    Build thread: 2014 Audi Allroad
    Instagram: @ridesbypeter
    Previous Audis:
    2004 Audi A4 Avant 3.0
    2003 Audi A3 Avant 1.8T
  3. #43
    Senior Member Two Rings Taylor-S's Avatar
    Feb 19 2016
    2007 Jeep Grand Cherokee
    Colorado Springs, Colorado
    Sneak peak!
    Calipers will be going red, but I do like the black on black.20180313_132224.jpg
    Sent from my SM-G892A using Audizine mobile app
    2017 Q7 Prestige (Pacific German Built!)
    Instagram: @ts_13allroad
    (Sold) B8.5 allroad | APR Stage 2 (e-85) | APR Downpipe | AWE FMIC | Macan/Q5 345mm Brembo Front Brakes Build Thread
  4. #44
    Veteran Member Three Rings sferraro's Avatar
    Jul 19 2011
    2023 RS6 | 2018 Q7
    Golden, CO
    Quote Originally Posted by Taylor-S View Post
    Sneak peak!
    Those calipers! Going to look good, Taylor - can't wait to see the finished product.
    2023 RS6
    CETE | color-matched rear caliper plates
    SOLD
    2013 allroad
    2011 A4 Avant
  5. #45
    Sep 06 2017
    05 Subaru LGT (HTA71)
    MA
    I will be moving to a 20x10.5 wheel in the near future. Trying to figure out tires. I'm thinking about going with a 275/30, 275/35, or a 285/30. Any suggestions or opinions out there? Going to be on air. Moderate drive height. I live in the NE so the roads are terrible, trying to keep a decent amount of sidewall.
    I'm leaning toward MPSS tires; I liked them on my Subaru. In the threads I'm digging through people are claiming they run a little wider than others.
    > S4 Swapped B8 Avant <
    > 2015 Glacier White allroad P+ (RIP) <
  6. #46
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by Allthea View Post
    PSS are great tires, but they are meatier than others. PSS have been replaced by the PS4, which I'm hearing is also fantastic, but I haven't owned a set yet. I'd stick with a 35 sidewall if your roads are especially bad. I'm on 35's, but might swap down to 30's when I need new summer rubber. Roads aren't great around here, especially after winter, but I want to be able to tuck a little bit more than my 35's allow. I'll be back on my 20x10" summer wheels, et25 after 5mm spacers all around.
  7. #47
    Established Member Two Rings Comfy Pursuit's Avatar
    Sep 03 2017
    Audi SQ5
    Portland, OR
    I went 20x10.5 et25 for summer with 255/35/20 PS4’s, thinking that spacers would push me out past the fender. Local shop hasn’t gotten their hands on my car due to wheel issues with the manufacturer, but now wonder if I should order spacers just in case!
  8. #48
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by Comfy Pursuit View Post
    You’ll be perfectly flush at those specs. Scroll up and take a look at my black allroad on CH-R’s to see what 20x10.5 et25 on 255/35/20 PSS looks like.
  9. #49
    Sep 03 2017
    Audi SQ5
    Portland, OR
    Between you and @killerbootsman that’s how I came up with the configuration.
    As of yesterday, I’m also going with CH-R’s (titanium), which is a spoiler alert for the friends on this feed. Vossen screwed up my order/wouldn’t negotiate/gave ECS mis-aligned info; leaving enough of a salty taste to ensure I voice that others stay away from the brand.
  10. #50
    Sep 06 2017
    MA
    I'm being told elsewhere that with 20x10.5 et30 the 285/30 is not going to work and that 275/35 is probably also too much, so I should stick with 275/30 to be safe.
    The picture @BMC2U posted in the mega thread was 20x10.5 et35 on 275/35 and it looked fine, though. Will the extra +5 on the offset really make it not doable for me to run 275/35? It kinda looks like it from the picture.
  11. #51
    Established Member Two Rings BMC2U's Avatar
    Dec 28 2017
    NorCal
    I used the set up Allroad Outfitters recommended and installs on many Allroads. The 35s would probably be too much for bags. I’m on springs and I drive the piss out of this car. After a very light shave to the rear plastic fender lip, hasn’t rubbed at all.
  12. #52
    Dec 28 2017
    NorCal
    Quote Originally Posted by BMC2U View Post
  13. #53
    Sep 06 2017
    MA
    My intended drive height will probably be the same as your drive height. You also look more flush than thought you would for +35.
    So, it's seeming like the 275/30 might have to be the way I go.
  14. #54
    Sep 06 2017
    MA
    Or I guess step down to 265/35 for the extra sidewall but a bit more stretch...
  15. #55
    Veteran Member Three Rings makisupa's Avatar
    Jan 30 2006
    Boston, MA
    So I’m going to run 255/35 on my 20 x 10.5 mpss/4s on my CH-Rs (finally let the cat out of the bag), so if you wanna take a peak at that set up before you move on some times Alex just let me know.
  16. #56
    Veteran Member Three Rings chromedomewooki's Avatar
    Feb 19 2008
    2001.5 nogaro s4, 07 GMC Denali, wife's 13 s4
    hanover, md
    I'm running 255 35 on 10.5 wheels as well. I'll get pictures in a bit.
    Sent from my Pixel XL using Tapatalk
  17. #57
    Established Member Two Rings parkcityxj's Avatar
    Nov 18 2008
    B8.5 Allroad, Mk6 GTI, 07 F-150
    Park City, UT
    I'm running 20X10 ET25 with 275/30s. I only rub when there is signifiant upsetting of the suspension during cornering, probably have rubbed less than a dozen times in two years.
    That being said, I need new tires and 255s are significantly cheaper. I really don't care for the the stretch look and like a chunky sidewall, I can't seem to find any close up of the sidewalls with 255/35s on a 10" wheel, are they stretched or do they have a good sidewall still.
    2013 B8.5 Allroad| 996 911 C4S | 2007 F150 Super Crew (Tow/Camping Rig)
  18. #58
    Feb 19 2008
    hanover, md
    They will have a stretch to them. I'll see if I can get a better picture of them.
  19. #59
    Veteran Member Three Rings skifreak85353's Avatar
    Sep 23 2015
    Arlington, VA
    S4 Peelers with 25mm spacers our back and 20mm up front.
    ____________________
    2014 Audi Allroad Prem+ Moonlight Blue | Neuspeed Power Module | 19" S5 Rotors + 10mm H+R spacers + PS2's | 19" S4 Peelers anthracite + 25mm/30mm H+R spacers + Blizzaks | Stasis RSB | Alu Kreuz | Avant S-Line springs | 20% tint | Vag Com mods | RSNav CarPlay
    2009 Volvo XC90 V8 R-Design
    2013 Subaru WRX Limited (Satin White Pearl) - Gone but not forgotten
    The Instagram the_radifier
  20. #60
    Veteran Member Three Rings djnuge's Avatar
    May 15 2015
    285/30-20 tires on a 20 X 10 wheel with et30.20180129_083359~2.jpg
    Sent from my SM-G955U using Audizine mobile app
  21. #61
    Aug 01 2016
    Pewaukee, WI
    I've been searching for a couple of hours now with no luck, but someone had a set of A8 wheels on either a silver or white Allroad. Does anyone know who? A set popped up locally for a good price and I'm thinking about replacing my RS5 rotors (dad actually wants them for his RS5 as his wheels were trashed by the previous owner and he wants the keep the snow tires on the trashed wheels).
    These are the wheels:
    Daily Driver: 2013 Allroad Premium Plus (OEM+ Build Thread)
    Summer/Fun Car: 2005 Jetta GLI (OEM+ Build Thread)
  22. #62
    Veteran Member Three Rings bluefox280's Avatar
    Jul 03 2005
    Broomfield, CO
    Quote Originally Posted by JettaGetUpandGo View Post
    ... someone had a set of A8 wheels on either a silver or white Allroad.
    I can photos of A8 wheels on standard B8 A4 Avants, but not an Allroad.
    Typically with the A8 wheels being their marginal width (8.5" - 9") and high offset, they would swallowed by the flavored Allroad wheel well arches.
    Typically spacers would be needed to get back to a stance that sit similar or more flush to the arch.
    - Erik
    PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
  23. #63
    Sep 06 2017
    MA
    i like that tire meatiness, djnuge
  24. #64
    Aug 01 2016
    Pewaukee, WI
    Quote Originally Posted by bluefox280 View Post
    - Erik
    Yeah, they're 20x9 ET37, so 10-12mm spacer would be needed. I was happy with where the RS5 rotors sat without spacers.
    I did finally find this picture, but its not the one I was thinking of (https://www.audizine.com/forum/showt...ls-and-tires):
  25. #65
    Sep 06 2017
    MA
    does anyone use any sort of special locking lugs? Or are the Audi OEM locking lugs well received?
  26. #66
    Aug 01 2016
    Pewaukee, WI
    I actually bought extra bolts to replace mine because I hate dealing with them when swapping summer/winter wheels. I also use spacers in winter which would negate the ability to use them.
    Please don't steal my wheels. Haha.
  27. #67
    Veteran Member Three Rings Wagoon's Avatar
    Jan 31 2010
    Stock parts
    Orlando
    Been super lazy and never got around to posting my setup here.
    20x10.5 ET25 BBS CH-R wrapped in Michelin PSS 255/35
    wagoons || corey
    thewagoons.com
    2016 allroad quattro // rsfauxroad // 3p // stg2 e85
    airlift.akebono.apr.bbs.cr..ecs.eurocode.forge.inn o.st
    the wagoons - build thread - instagram
  28. #68
    Sep 06 2017
    MA
    That color mix is great
  29. #69
    Feb 19 2016
    Quote Originally Posted by Layd Dly View Post
    Definitely one of my favorite allroads, the grey, black and mint are perfect!
  30. #70
    Feb 19 2016
    I will get better pictures soon, but finally got my set up complete!
    -Hartmann S5 dual spoke reps(HS5-209), powder-coated satin black.
    -19x8.5 ET25 (5x112)
    -Tires: BFG G-Force Comp 2 A/S
    -255/40r19
    -15mm spacers front and rear (effective ET10)
    -Stock height
    Brakes are the Porsche Macan/ Q5 brembo brakes painted Torando Red (G2 Paint) with 345mm EBC sport rotors. I kept the rear stock calipers, but paint matched along with the 300x12mm sport rotors.
  31. #71
    Sep 03 2017
    Audi SQ5
    Portland, OR
    Official B8.5 allroad Wheel Thread! Information, Inspiration &amp; Ideas
    Summer setup complete.
    • BBS CHR 20x10.5 et25 (5x112) in titanium
    • Michelin PS4 255/35/20
    • Bilstein PSS10 Coilovers set at 26 in front and 26.25 rear FTG with dampeners set at 5
    • H&R Rear Sway
    It’s a tight fit!
  32. #72
    Sep 03 2017
    Audi SQ5
    Portland, OR
    -255/40r19
    -Stock height
    #Beefy
    I love the look, Taylor! Can’t wait to get these Allroads back together for a party 🤙🏻
  33. #73
    Jul 19 2011
    2023 RS6 | 2018 Q7
    Golden, CO
    -255/40r19
    -Stock height
    It’s a tight fit!
    Looking good, fellas. Can't wait to see both in person.
    2023 RS6
    SOLD
    2013 allroad
    2011 A4 Avant
  34. #74
    Feb 19 2016
    Quote Originally Posted by sferraro View Post
    Thanks guys! I still am wanting to set up a CO b8.5 allroad meet here soon and I will be putting a thread out soon: "Calling all B8.5 allroads". We have a ton of great ones in CO and good variety.
    p.s. the titanium BBS looks amazing by the way!
  35. #75
    Aug 09 2011
    calgary, AB, CANADA
    20X10.5" ET27 Niche Carini
    255/35 Continental Extreme DWS 006
    ST coilovers, need to get them down a touch lower.
  36. #76
    Feb 02 2017
    Beaverton, OR
    Are the rears all the way up on those STs?
  37. #77
    Aug 09 2011
    calgary, AB, CANADA
    they are near the top of the ST "spec", but there is a ton of thread left that could probably be used safely. I will likely be buying KW spacers when I go back to winters and bring it up a touch.
  38. #78
    Veteran Member Four Rings JLAllroad's Avatar
    Nov 11 2017
    Denver, Colorado
    • H&R Rear Sway
    It’s a tight fit!
    A couple questions....are the PSS10s maxed out, and are they new (or pre settled)
  39. #79
    Dec 28 2017
    NorCal
    Finally got KW V1s on.
    HRE FF01 20x10.5 et35
    275/35 Toyo Proxes Plus 4
    Had to trim the rear fender lips and “massage” the front metal lips then adjust the height to make it daily driver comfortable.
  40. #80
    Sep 03 2017
    Audi SQ5
    Portland, OR
    Quote Originally Posted by JLAllroad View Post
    Nowhere near maxed out on either end of the spectrum, I could lift it or lower it from this position. They are pre-settled.
