Results 1 to 10 of 10
    Jun 05 2012
    Aurora, OH
    Help with Alignment
    Can I get some assistance with Alignment. I have a 2013 on H&R OE Sport springs and had inside tire wear previously. The attached is after an alignment. I was going to take it in again, and wanted advice on what was the correct alignment spec for my car on the OE Sport springs. Thanks!
    Sent from my VS986 using Tapatalk
    Jan 09 2008
    Winnipeg
    Apparently toe is what eats tires. It doesn't look like you have too much though...maybe they can reduce even further to maybe 0.06.
    I had much more aggressive settings but I autocross and my tires last from May to September and at that point they have very little tread left...that was less than 8300 km on a brand new set of RE-71Rs. So long term wear is something I don't have visibility into.
    Apr 30 2010
    San Diego
    I have H&R OE springs and was running about 2 degrees of camber which was killing my front tires on the inside. I just had it realigned to bump up the though a quarter inch which they say should help with the wear. Otherwise the only option is adjustable control arms to get the camber back in spec.
    2011 Audi S4 | 6MT | Ibis/Black Silk Nappa | Nav l B&O | Sport Diff | Carbon Inlays | H&R l Strat Intake l Strat SS l Alu Kreuz l AWE Exhaust l AG M510 20x10 et35 l GIAC Stg II l DTM Lip l Eurocode Diff Mounts l SS Clutch Line
    Oct 10 2016
    1987 Dodge Ram, 2003 Dodge Ram,
    East Coast, USA
    OP. the alignment you received is probably the best you are going to get.
    Toe will cause a tire to have a "choppy" wear on the inside or outside treads near the shoulders of the tire.
    Camber will cause an even wear on the inside shoulder of the tires.
    On B8 Audi's the front camber is considered not adjustable with OEM parts. The only way to realign the front camber is to buy adjustable control arms.
    As our cars are lowered, it caused the camber to increase (become more negative) due to natural laws of physics.
    The reason that it appears that camber was adjusted from old to new can be a result of toe adjustment with the tie-rod tension on the assembly.
    2011 S4 | Phantom Pearl Black | Unitronic Stage 2+ ECU & TCU | Roc-Euro Intake | Airlift 3P Air Ride | ECS Drivetrain mounts, Skid Plate, Boost Gauge, and Carbon Wing | Strafe Design Aero Splitters and Diffuser | 20% Tint | RS4 Grill
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    -2 up front and -1.5 back is fine.
    I’d like to see the toe more even side to side, especially rear..it’s not that hard to make them the same number. Doesn’t look as if they even touched it. ...a little turn on the pass rear and would’ve be good to go.
    I like less toe, but that my preference. I’m basically zero toe up front and a tiny amount of rear toe. My -camber is the same.
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    Jun 05 2012
    Aurora, OH
    Quote Originally Posted by Silver Streakin View Post
    So should I ask them to zero the Toe?
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    Quote Originally Posted by jeguzik View Post
    On AWD/FWD cars you want to keep a little bit of toe-out. Because the front wheels are driven they get pulled forward and toe-in naturally once you are moving getting you closer to zero. Generally, toe-out improves steering response, and toe-in improves straight line stability. Too much toe-out causes the inboard edges to wear out. So it all depends on what you are after, but your main issue is the out of spec negative camber in the front that will give you uneven wear on the inside.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Established Member Two Rings benburgess's Avatar
    Aug 06 2017
    Central CT
    Quote Originally Posted by jdcarnes View Post
    Not trying to be a wise ass here... but by 'natural laws of physics' do you mean gravity? Is it because the car's center of gravity is lower to the ground relative to the wheel hub/center/axel?
    2014 B8.5 S4 P+ 6MT Monsoon Grey
    Avant Garde M590 19x9 | Luft-Technik Intake | AWE Touring Diamond Black | Madico Black Pearl 35% | USP SS CL |
    Oct 10 2016
    East Coast, USA
    Quote Originally Posted by benburgess View Post
    Correct.
    For example, take to drinking glasses and put a ruler across them. So, that the glass at the end of the ruler. Push down on the center of the ruler and you'll see the ends raise. This is essentially what is happening.
    Aug 06 2017
    Central CT
    Correct.
    Great way to describe that. Thank you.
