Results 1 to 30 of 30
    Established Member Two Rings clAudi's Avatar
    Jul 17 2017
    Brooklyn
    Vibration at idle
    Hello,
    I feel like my car vibrates strongly when its in idle, and I wanted to post a video for you guys to tell me what you think it can be? When no one is sitting in the passenger its vibrates pretty badly. I've already changed my plugs I have no codes showing up, I did do a scan and it says I have P2006+P2007 probably due to vacuum leak but theres no CEL light. I believe I found the source of the leak but not sure it would be the culprit, looks like my intake hose coming from the intake box going to the throttle body is seperating right at the point where the secondary air filter is right before it connects to the TB. Any input would be greatly appreciated.
    Thanks,
    https://www.youtube.com/watch?v=Sp7L...ature=youtu.be
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    This engine is notable for rough idle. They all idle rough. So many owners complained about it that there is a TSB for it. (24AS) ECU reprogram . Not sure how rough yours is, but you will never get it to be silky smooth . BTW, your link doesn't work for me.
    Active Member One Ring mel22b's Avatar
    Oct 29 2017
    North Vancouver BC Canada
    Ya I have it too. I wouldnt say rough but the car shakes slightly.
    2014 S4 - S tronic - Phantom Black - Black Optics - Carbon Inlays - Sports Diff - APR Stg 1 - RS Grill
    Jul 17 2017
    Brooklyn
    I know but I think this is a little excessive, btw do you know if the issue I described above with my intake tube could be the culprit of a vacuum leak? Also I made the video public it should work now.
    Jul 17 2017
    Brooklyn
    Quote Originally Posted by Dr GP View Post
    Thanks for the info just fixed it, it was private.
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    Fluidampr crank pulley
    Jul 17 2017
    Brooklyn
    Quote Originally Posted by theweebabyseamus View Post
    Anymore details?
    Nov 12 2009
    2012 S4, 90 VW Corrado
    Louisville, KY
    Quote Originally Posted by clAudi View Post
    Anymore details?
    http://www.vdamper.com/30-V6-TSI-Supercharged_p_42.html
    2005 A4 USP (Gone)
    2012 S4
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Hello,
    Thanks,
    How old is your car? Mileage? Any mods? Is this a recent change?
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Jul 17 2017
    Brooklyn
    Quote Originally Posted by MSq5 View Post
    It's a 2010 just got 90,600 miles. No mods. I'd say it's been like two months since this started happening. Were you able to watch the video?
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Normal. Something I hate and it drives me nuts, but it's normal. Open your driver side door and put your hand on it. It shakes like a mid 60's muscle car with a big cam in it. When I very first started test driving S4's I passed on the first 2 thinking they were having issues.
    IMO if there was a way to bump the idle up to say 950rpm it would be fine. My last MazdaSpeed 3 had a means up upping the idle and I did as the motor mounts would cause it to shake a bit. Not sure why no one has been able to do it or made it so.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Jul 17 2017
    Brooklyn
    Quote Originally Posted by pdqgp View Post
    That's pretty unfortunate considering it's a luxury car. If no one is sitting in that seat it vibrates like crazy. Did you watch the video by any chance ?
    Jun 08 2005
    Lexus RX 350
    SE, PA
    The car was made for driving not idling. The rough idle is what it is. You can either live with it or get another car. To me it is a very minor issue that has no negative ramifications. I don't even notice it anymore. It's like having a supermodel girl friend that wants red hot sex all the time but farts a lot.
    Aug 31 2017
    SouthEast USA
    LMAO
    Veteran Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    RS7
    New Hampshire
    It doesn't sound normal to me, vibration aside. Not sure if that's the video just picking up that frequency better than others or by though. I'm gonna cold start mine in a few, it's below freezing so should be good.
    On another note, if this started two months ago it's not normal.
    Mar 20 2015
    McKinney,TX
    Quote Originally Posted by Ford Prefect View Post
    LOGIC!!!
    At minimum smoke test/check for any vacuum leaks, shouldn't be to expensive at an indy.
    Feb 23 2016
    Chicago
    As soon as you said shaking at idle, I thought of the Engine/Transmission Mounts. Get that looked at.
    Jul 17 2017
    Brooklyn
    Most of the sound is from the chair vibrating you can see when I hold it mostly stops.
    Jul 17 2017
    Brooklyn
    Quote Originally Posted by EIAlfonso View Post
    LOGIC!!!
    I noticed that the place where the secondary air filter is right before the throttle body the tube is actually separated could that be the source of the leak since I don't have any cel lights going off I would think it's somewhere before the MAF but I'm just speculating.
    Jul 17 2017
    Brooklyn
    Quote Originally Posted by PopTart View Post
    Would I have to take it to a shop to do? Or is this something I can do on my own?
    Jan 20 2017
    RS7
    New Hampshire
    Gotcha, I was listening more than watching the first time. So guess the vibration is new and not just the noise then. I’m not sure how a vacuum leak would cause that, honestly, but if you suspect something check it out.
    I would think more along the lines of main damper or the like. With no codes being thrown I would think it’s mechanical like a pulley or mount. If I could figure out how to post a video I’d post mine, over 100k and the seat is solid, no vibration.
    Jul 17 2017
    Brooklyn
    I posted it on YouTube and then just paste the link
    Jul 17 2017
    Brooklyn
    Just got a quote from an Indy shop for replacing left and right motor mounts. They want $1800 parts and labor does that seem reasonable ? Also anyone have any recommendations for shops in NYC /LI area ?
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Good call
    Senior Member Three Rings DufraineMK6's Avatar
    Jan 09 2017
    2014 Monsoon S4 6MT
    Northern VA
    Mine had this as well but it was intermittent or so low I didn't notice it, Since I swapped in the JHM 179 crank I haven't noticed it, or maybe its just super low. Either way its normal, to what degree I do not know. If there isn't already one a thread should be started on all the little things to expect when looking/purchasing an S4. I also noticed when pointed out that one bank of the engine is noisier than the other.
    14 S4 6MT - Sport Diff / H&R Street Performance Coilovers / CW Pro Stage 2 (6-1) 93/E85 Mix / JHM 179mm Crank Pulley (1300mm 7 Rib Belt) / ECS Tuning Flush Kit 10mm F & 12.5mm R / 034 Motorsports Intake Tube W/ AFE Pro Dry Filter / USP Stainless Steel Clutch Line / AWE Touring 102mm Stock Downpipes / Eurocode Trans Mount
    Jul 17 2017
    Brooklyn
    Quote Originally Posted by DufraineMK6 View Post
    Agreed we should add it to the new owners sticky
    Senior Member Three Rings bokiboki's Avatar
    Apr 26 2013
    Bronx, NY
    There's a guy here on the forum, militant-grunt, he's been working on my car for some time now and he is freaking great, real gear-head, there's nothing he can't do. He's from Queens and works for Audi Manhattan, certified Audi tech, PM me for his contact info - I'm sure he'd give you a better deal than this.
    Jul 17 2017
    Brooklyn
    Quote Originally Posted by bokiboki View Post
    Thanks! Pm sent.
    Apr 26 2013
    Bronx, NY
    Replied
    Sent from my SM-N950U using Audizine mobile app
    Jan 09 2017
    2014 Monsoon S4 6MT
    Northern VA
    Maybe that your seat making the rattle. For me my vibration is noticeable only on the dash and maybe the floorboard in dynamic mode and possible my in all modes as well. I only drive dynamic
