Results 1 to 16 of 16
    Mar 24 2008
    Sacramento
    delete
    Found
    current stable: 2011 a6 avant 3.0t; 2004 allroad 2.7t; 2000 s4; 1990 corrado g60
    May 09 2012
    Virginia
    Quote Originally Posted by valet View Post
    already have the throttle body boot. looking for the up-pipes 078145683L and 078145686L before I cut my stocks to fit
    I might have some from my B5 S4. Let me see
    Sent from my VK810 4G using Tapatalk
    Mar 24 2008
    Sacramento
    let me know either way
    May 09 2012
    Virginia
    Here’s what I have. Different part number but may be a superseded #
    One of the mounting tabs is broken.
    Mar 24 2008
    Sacramento
    Those are what I have but ending in K. The ones I'm looking for are shorter and the end near the dv nipple is straight rather than curved. Thanks though
    Sent from my SM-G955U using Audizine mobile app
    Veteran Member Four Rings 11o7's Avatar
    Mar 29 2015
    I should have some from my allroad in storage. I'll take a look for you :)
    May 09 2012
    Virginia
    I didn’t realize they are different. Why is that?
    Mar 24 2008
    Sacramento
    Quote Originally Posted by jbain2 View Post
    The metal tbb comes out further than the rubber boot. It negates the turn on the plastic bi-pipes near the dv port
    May 09 2012
    Virginia
    Forgot about the metal TBB on the later years. A coveted item.
    Jul 30 2014
    My baby b6 s4 good wood green pearl, A bunch of b5 a4s, 86 Toyota pickup
    Bellingham,WA
    I got a set pmd
    Mar 24 2008
    Sacramento
    This is why you can't use any other pipe than the ones ending in L. Angle is all wrong. You basically have to cut off the angled flange if you wanna run them.
    Established Member Two Rings B_Fung520's Avatar
    May 20 2017
    Audi c5 allroad
    Bay Area
    I have a set that I’d be will to part with if you’re interested.
    Mar 24 2008
    Sacramento
    The pipes? I already have the left one and need 078145686l. But if the price is right for both...
    Mar 24 2008
    Sacramento
    I finally got a hold of the correct tubes for the 05 allroad metal throttle body boot. Correct ones end in L. Others (C,P,D,K...) don't work and are too long and angled. Included pics show normal ones on top and late 2005 ones on the bottom. Would've had them early last month but shokan coachworks sent me the wrong ones. Ended up going through audi Germany to get the passenger side one.
    For anyone interested, driver side can be still purchased (as of last month off of ebay new). Passenger side is NLA in the US and can only come from audi Germany . I was told that I purchased the last metal tbb in North America so ymmv when going the oem route over apr bipipe
    Established Member Two Rings superdlux's Avatar
    Dec 24 2009
    thanks for the info – very helpful.
    Oct 31 2022
    Prescott AZ
    Bumping this thread.
    I am looking for the bi pipes that go to the metal TTB.
    Any help would be appreciated!
    Thanks guys
