Results 1 to 5 of 5
    Senior Member Two Rings DOBERMAN@UA's Avatar
    Sep 15 2008
    A 4 2.0 TFSI Quattro
    Ukraine, Kiev
    A6c6 3.0 tdi front calliper upgrade
    Previous I had a4b7, brakes were fantastic with ss lines. When I bought a6 was a little disappointed because of brakes compared to a4. My pads wear not evently. External pad wear about 20% meanwhile internal worned out. It means that front calliper not effective as it should be. For winter I use 17 RIMS, and do want to change the front calliper on stock 347mm disk. I tried to match with 18z brembo but not enough space in the rim(volk re30). I'm considering about q5 brembo calliper. Should it be ok with my set up? Any ideas?
    ABT AS4 aero package, ABT AR type 8,5x18 ET 50 rims, F&R 15 mm spacers, ABT rear muffler, RS 4 front and rear sway bars, SuperSprint center exhaust,Cat delete and Down Pipe from Supersprint, GSG FMIC, K&N, KONI shocks with Eibach springs.
    274 HP and 389 N\M
    Sep 15 2008
    Ukraine, Kiev
    Q5 4pot brembo calliper fits directly on 347 mm brake disk. Old lines I replaced with ss. It is night and day difference.
    274 HP and 389 N\M
    Jul 17 2011
    Sin City, USA
    Since the OEM calipers are single pots, the uneven wear would be due to alignment of the caliper in relation to the rotor.
    Sounds like you may have fixed the issue with new calipers. Keep an eye on the wear. Off it continues, you have a bigger issue.
    '09 C6.5 A6
    Oct 06 2015
    St.PetersburgRussianFederation
    будь ласка.
    Sep 15 2008
    Ukraine, Kiev
    Я поставил на стоковый диск(347) все стало без переходников шайб и тд
    274 HP and 389 N\M
