Page 1 of 12 12311 ... LastLast
Results 1 to 40 of 443
    Veteran Member Four Rings AUDacIouS4's Avatar
    Mar 11 2016
    981 Cayman GTS/ 2018 Ford F150 FX4 2.7
    Orange County CA
    "AUDacIouS4" Allroad Prescision Turbo 5558 build
    This thread I hope will serve as both to document the the "Gen2 EA888 big turbo path" as well as my own progress with an Allroad flex fuel setup. I will update this page as I move forward.
    I've been at a crossroads recently, going back and forth over a K04 or a big turbo. The k04 is tried and true, a great DD, and provides long term reliability. However, after seeing a few BT attempts fizzle after coming so close I knew it was just a matter of putting the right pieces together and getting a good tune.
    I was ignorant of the fact the MK6 GTI Gen2 EA888 was almost Identical to our version with the differences being the crank, Audi valve lift, and fueling. Thanks to a few friendly comments from others in the k04 thread about the MK6 I dove deep down the Volkswagen Vortex and emerged with what I feel is a solution to my insatiable appetite for gobs of torque.
    Now with that out of of the way, lets get this show on the road!
    For now I'm going to stay at 400whp as a goal, (and after speaking to Integrated Engineering)and to keep my stock rods from disintegrating.
    Most of this information here will be pertinent for a build with healthy stock internals. I'll give a little info when needed for those who want to build a short block and reach 500whp and beyond.
    MY BIG TURBO HARDWARE BUILD LIST:
    - Precision Dual Ball Bearing 5558 turbo/ 0.62 A/R V-Banded Turbine housing
    - JDL Custom Equal length Tubular manifold with wastegate recirculation
    - Precision 46mm v-band wastegate with 1 Bar spring (15psi)
    - Custom 4" Turbo inlet piping with stock MAF housing/ K&N filter behind passenger fog grille
    - Custom 3" downpipe with 200 Cell Magnaflow cat
    - Custom ECS vacuum operated cutout in mid-pipe
    - Magnaflow Cat-back
    - APR FMIC
    - ECS black wrinkle coated metal charge piping kit
    - Snow VC-50 Water-Meth kit with gauge/ One post intercooler nozzle for IAT cooling
    FUELING
    - Stock Bosch Di flex fuel injectors (730cc)
    - Autotech High Pressure Fuel Pump piston upgrade
    - PORT INJECTION Nostrum 'Black Jack' universal 1000cc KI injector to replace OEM 5th injector in throttle body
    SUSPENSION
    - KW V3 Ground to Fender = 25.75"
    - H&R sways with Moog end links
    - 034 - upper control arms
    - 034 stiffener inserts - transmission/sub-frame/rear diff
    - Eurocode X-Brace
    - CR-15 strut brace
    EXTERIOR
    - Custom RS Grille and fog screens
    - Black vinyl wrapped all chrome
    - Flush mount roof rails
    - Vorsteiner VFF-105 20x10.5" ET 35 Wheels on 285/30/20 Continental Extreme Sport Contact
    BRAKES
    - FRONT
    Q5 Brembo 4 piston front caliper
    345mm Stoptech slotted rotor/ SS brake line
    - REAR
    S4 calipers and 330mm Stoptech slotted rotor/ SS brake line
    Street pads - Stoptech Sport pad
    Race pads - Pagid RST3 - Fronts/ RS19 rears
    [/B]*PRESCISION TURBO GEN2 5558 DUAL BALL BEARING TURBO T3/V-BAND
    55 Trim
    .62 A/R. (.48 , .62, .84 options)
    Air and oil cooled
    v-banded
    Full spool at 4200 RPM
    *PT 39MM EXTERNAL WASTEGATE I switched to a V-Banded turbine housing pictured above and am now using the Precision 46mm V-band style wastegate with a 1 Bar spring (15psi)
    The benefits external wastegates provide are better boost control, quicker response, less prone to sticking shut, faster relief of excess boost pressure which keeps your turbo healthy and happy.
    *Integrated enginnering Oil drain line adapter flange ( oil pan)
    *Treadstone Stealth oil return/supply kit
    *ATP oil feed adapter flange (from block)
    *ATP diverter valve relocation kitNo longer using
    The shop that did my fab work does not like the DV relocater housings as they have been known to leak. Instead they installed a mechanical DV. It's a 710N from a 911 turbo and also used on the older B5 S4.
    *PRESCISION turbo blanket
    I've recently learned that flex fuel model year 13/14 have different injectors
    INJECTORS
    Please read this post before buying injectors.
    Here is an important bit of injector info from Nostrum
    http://www.audizine.com/forum/showth...1#post12322172
    LDK
    Bosch 0 261 500 112
    304 cc/min / 29 lb/hr @ 5bar
    15+ Flex
    Bosch 0 261 500 164 HDEV 5.2
    730 cc/min 16.9 g/s 6 point spray pattern
    15+ Flex 5th injector
    Bosch 0 280 158 235 EV14
    731 cc/min / 66 lb/hr @ 3bar Conical spray pattern
    The MK6 was able to reach 400whp on the stock HPFP (high pressure fuel pump) and these injectors. To get beyond this power level, some added a higher flowing HPFP (we'll get to that in a minute) and plumbed in an additional 5th injector in the throttle body, which coincidentally the flex fuel engines have in place already.
    Here's what I recently discovered. I contacted Bosch in reference to the Injector in my 15' Allroad.
    Audi part # 06H-906-036-N
    Bosch GDI (Gas Direct Injection) injector #62823 (Bosch was not able to give me details as this is an OEM Audi proprietary part but hinted that I could find out more online)
    The Bosch injector number printed on the Injector itself is as pictured: 0261500164
    This injector is the HDEV 5.2 style capable of 730 cc/min @100bar with a max of 200bar
    This injector is ONLY used in 2015 -17 Audi Flex/non-flex fuel L4 2.0TFSI
    HDEV5.2 INJECTORS can be found here
    http://www.bosch-motorsport-shop.com...irect-injector
    High Pressure Fuel Pump (HPFP)
    The mechanical fuel pump is attached to the cam lobes on the rear passenger side top of the engine. It's responsible for pressurizing the fuel into the top rails. The stock pump is a Hitachi pump with Audi part number 06J-127-025-J. I have installed the Autotech HPFP piston upgrade which has allowed me to hold 205 Bar fuel pressure
    LPFP- Low Pressure Fuel Pump or 'lifter pump' located in gas tank - Allroad uses the "N" pump
    For anything around 400whp, an upgraded Low Pressure Fuel Pump (LPFP) is NOT needed as the pump is the same as the B8.5 S4/S5 which are putting out 450whp on Dual Pulley tunes and I confirmed they were able to reach about 425whp on E35 with the Allroad "N" pump
    Veteran Member Four Rings Perry01's Avatar
    Jan 22 2016
    Touareg V8 FSI 8V A3 - B8.5 Q5 - MKVI GTI
    Hawaii and Utah
    Wow, it’s cool you are going to take in this BT build. It seems like you’ve done your homework with researching the MK6 approach. I’m looking forward to your input along the way because this is something I’ve been considering for a while. I have a B8.5 flex fuel so hopefully fueling will not be a problem.
    Where do you plan on getting it tuned? Will you be able to keep your 034 HFC?
    Good luck!
    CPMA / CTS K04-0064 / IE custom tune / Wagner FMIC / Custom ZF8 TCU tune
    Veteran Member Three Rings B8_Dude97's Avatar
    Sep 05 2016
    Antioch, California
    Sub'ed. If you do it right your turbo lag should be comparible to a k04. I don't have research on the precision turbo which is why I'm heading a different but similar direction(twin scroll) but I'm interested in someone shooting for that middle ground between k04 DD and BT race car.
    I'll be interested to see how the fueling holds up as it was reported by slowone that he got fuel cuts with his precision turbo around 420hp dyno runs that's why he tuned for 400 aswell.
    Also those injectors look good to me. I know hyde16 switched out his opels recently cause he said the s3 injectors have a better spray pattern than opels
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    :popcorn:
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
    Veteran Member Three Rings cybernet99's Avatar
    Sep 06 2014
    2010 A4 S-Line, 2013 MB GLK350, 2004 Yamaha R1 @AlterdA4
    Ottawa, Canada
    Subscribed ... Will be following closely, plan to go BT as well.
    Follow my build on IG - https://www.instagram.com/AlterdA4
    Integrated Engineering (Sport Short Block | Sport Head Assy | Intake Manifold w 4 x 890cc Injectors), BW EFR8474 Turbo, Custom 4.5" FMIC, Custom 3.5" SS Turbo back Exhaust, Tilton Racing Twin Disc clutch/PP & LWFW, 034 Billet Motor Mounts, AP Racing BBK 380(F)/330(R) floating rotors
    Veteran Member Four Rings hyperunion's Avatar
    Sep 03 2012
    07 Xterra 4X4 , 02 20V Passat variant.
    Lehigh Valley, PA
    At least we all know the zf8hp55 transmission can hold the torque this turbo will put out... But very curious how it will adapt to the definitive difference in turbo response and drivability!
    Sent from my Nexus 7 using Tapatalk
    B8.5 A4 Premium +, ZF8, APR Stg II+ E85, APR HFC Downpipe, APR Carbon Intake, APR Intercooler, APR T.M. Delete, AWE Quad Exaust, ECS turbo inlet hose, H&R coilovers , H&R F&R Sway Bars, Q5 4 Piston Brembo upgrade, ECS Slotted rotors and stainless lines, OZ Ultraleggeras, Piaa, 3M Crystalline, Xpel Ultimate. IG: "Veritech1"
    RIP: B6 A4 Sport, AWE GIAC rSK04, Bilstein PSS9, OZ SL.
    Senior Member Two Rings Grippy's Avatar
    Feb 01 2016
    2000 Wrangler Sahara
    Littleton, CO
    Subscribed. Happy building
    Fool me once, shame on you. But teach a man to fool me, and I'll be fooled for the rest of my life.
    Mar 11 2016
    Orange County CA
    Quote Originally Posted by Perry01 View Post
    Good luck!
    For tuning, I talked with both United Motorsports and GIAC. They will both tune the car. That was the biggest obstacle in my mind and I'm glad it was easily resolved.
    1: UM would use a MK6 BT base file and do as many revisions as necessary on pump gas to start. They weren't confident the stock fueling would be able to handle a full E85 tune at those power levels(400whp) maybe E30. They also are unaware that the 15/16/17 injectors flow 20% more so we'll see. UM can tune whenever I'm ready.
    2: GIAC would take the car for about a week and dyno tune it. It would be very refined and have a pump MAP as well as an E85 race MAP. It's twice as expensive as the UM tune but arguably better. GIAC doesn't have openings for me until January.
    Both tuners would make a great tune, I just don't want UM to flake out on tuning for E85.
    As for the downpipe, I'm having my exhaust guy weld a v-band flange to a 4 bolt flange(OEM style) that will bolt right up to the 034 downpipe and/or stock downpipe. This way when emission/smog testing time comes for me, I can swap back to stock and pass. Alternatively, I could have a v-band flange welded to both ends of the OEM cat/034 HFC and just swap it in and out when needed. I track my car (road course) once a month and it would be nice to run a test pipe.
    My hardware should arrive early next week so I'll post some pictures then.
    Mar 11 2016
    Orange County CA
    Treadstone "Stealth" oil supply/return kit
    You CAN NOT re-use your OEM oil feed line as it has a built in restrictor. You will starve The turbo of oil. The PRESCISION turbos, and most Garrett turbos, have a built in restrictor in the CHRA so you need a kit like this. I'm missing the oil flange adapter from IE in the picture.
    Jan 22 2016
    Hawaii and Utah
    Quote Originally Posted by AUDacIouS4 View Post
    1: UM would use a MK6 BT base file and do as many revisions as necessary on pump gas to start. They weren't confident the stock fueling would be able to handle a full E85 tune at those power levels(400whp) maybe E30. UM can tune whenever I'm ready.
    It sounds like you have it all planned out. GIAC’s dyno tuning should provide great results. It’s a bummer you’d be without your car for a week though. I assume UM’s would be an e-tune? You would think they could accommodate a full E85 MAP with the stock B8.5 fueling.
    I didn’t realize you were in California where they have smog testing. Your flange fabrication is a good approach.
    Keep posting pictures of your hardware.
    Mar 11 2016
    Orange County CA
    Updated injector info.
    Jan 22 2016
    Hawaii and Utah
    I'm still trying to determine if the pump in the 15+ flex fuel is the ones used in the 4.2l R8.
    The HPFP 06J-127-025-J on the Allroad looks different than the either of the fuel pumps (left or right) on the R8 4.2 V8.
    Here is the Allroad HPFP:
    And the right side HPFP from my car:
    Note the two brass fittings.
    Mar 11 2016
    Orange County CA
    Your right. Thanks for the picture. It's been really hard trying to find out info on that Hitachi mechanical fuel pump. I'll keep digging. My thinking is that Audi was beefing up the 2.0TFSI in preparation for this: which they sadly killed off. 400whp 2.0tfsi, going in the R8 base model
    https://youtu.be/EuHJ4uclAYU
    Maybe, maybe not.
    Either way, the 15/16 flex fuel fueling is different.
    Mar 11 2016
    Orange County CA
    One more thing:
    For Audi/VW part numbers the last 6 digits denote the part itself while the first 3 denote the model and the last letter denotes the part revision.
    For example the HPFP Audi Flex fuel part number is
    06J-127-025-J.
    The 127-025 is what's important because that determines if the part carries over to different platforms.
    Jan 22 2016
    Hawaii and Utah
    One more thing:
    06J-127-025-J.
    Yes, the 6 numbers you mentioned refer to a fuel pump. For VW/Audi parts, the first three digits often refer to the chassis code (like 8K0) but in the case where the part is shared over many different platforms, the first three digits do not restrict the part to just one model alone. In the case of your fuel pump 06J-127-025-J, the first 3 digits do not designate a particular model, but rather which engine the fuel pump was first developed for so it does have significance in this case. The “J” refers to a modification code.
    Mar 11 2016
    Orange County CA
    No affiliations:
    Just wanted to give a shout out to Chris from realstreetperformance.com
    For all the help putting my Precision Turbo kit together.
    They've got some killer deals going on right now if anyone is interested.
    Feb 24 2013
    CA
    Welp, bought a 2014 a4 flex fuel pump to see if it would work on my 2010 a4. Connectors don’t match
    Aug 24 2010
    socal
    Nice I’ve been looking as well gonna keep and eye on your build. Your local as well would love to see it in person one day
    Mar 11 2016
    Orange County CA
    Mar 11 2016
    Orange County CA
    Waiting on the DV relocater and IE oil flange adapter. The only thing I have left to do is design the turbo inlet pipe. I will probably run 4" from the turbo inlet up to the MAF housing and use a reducer there as that is 3".
    Although it seems like it would be easier to run the piping sideways and down from the compressor inlet and make a cold air intake and ditch the ECS setup.
    I've cross shopped the VW TSI inlets but I haven't found any silicone/aluminum pipes that would work or are bent correctly.
    I'll just fab up an inlet pipe center section with DV and PCV ports.
    I've been told by UM that the N75 and OEM DV are good past 30psi.
    GIAC suggested running two in series.
    Not sure if I should get a different DV.
    Jul 02 2016
    Florida
    Holy poop! That is awesome, pretty, jealous, (insert adjective here), etc.
    Mar 11 2016
    Orange County CA
    The downpipe dilemma....
    After getting the turbo and manifold all measured and assessing the clearances, it looks like the exhaust turbine will sit 3" further back towards the firewall than the stock turbo.
    There appears to be enough pipe on the 034 downpipe to remove the 3", slide the cat backwards, and attach the v-band clamp.
    Dec 19 2006
    996TT
    San Antonio, TX
    What would be wrong with moving the cat down the canal that the downpipe is running? Will it get too hot?
    Mar 11 2016
    Orange County CA
    Quote Originally Posted by poweredbyaudi7 View Post
    I was thinking of keeping the cat in the stock location for CA emission/smog check. I'm not due for another year or two but I wanted to avoid a future dilemma now. Relocating the cat is Good idea! I will probably heat wrap the whole downpipe anyway so maybe the visual inspection won't be a problem. Your idea would probably work better because it would make more room for the EWG dump tube up near the connection point. I just don't know if I want to run a test pipe all the time. I had to put a resonator on my MILTEK midpipe because the drone was awful. Maybe this larger turbo will change the exhaust tone a little.
    Something like this ATP GT kit.
    Mar 11 2016
    Orange County CA
    Edited Injector specs, you'll be surprised how much bigger the 15+ Flex fuel injectors are than the LDK "Opel" injectors
    Sep 05 2016
    Antioch, California
    I'd be interested in comparing the Opel to flex to the big hp ones with some data
    Established Member Two Rings Tim11Macc's Avatar
    May 03 2014
    2015 GMC Sierra
    Columbus, OH
    Subd
    Mar 11 2016
    Orange County CA
    Quote Originally Posted by B8_Dude97 View Post
    I pulled the Opel injector data from here
    https://www.injectorrx.com/bosch-fuel-injectors/
    as I think those LDK injectors are discontinued. Any company that cleans or flow tests injectors will have good data. There were 3 other sites that had the same data for the LDK.
    I couldn't find anything on VW vortex about the LDK specs, only that they flowed enough to reach certain power levels.
    I'd be interested to see what these flex fuel injectors can handle. If the 5th injector can be used efficiently I'm hoping this calculator is correct from Deatshwerks site:
    Mar 11 2016
    Orange County CA
    Added this link to the first page. Nostrum Energy chimed in on a B7 A4 thread with some very helpful injector information.
    Sep 05 2016
    Antioch, California
    There injectors are pricey but the best on the block if anyone wants to get serious about injectors. I know of two b8 builds using their injectors.
    Mar 11 2016
    Orange County CA
    Finally got the rest of the parts I've been waiting on. I'll update the first post with part numbers for those interested. I have a T connector silicone hose from Treadstone in the mail and that's it. I need to have a welder fab up some nipples and cut down to size the aluminum pipe for the turbo inlet. I'm probably going to do the install after Christmas.
    Eurodynamic will be tuning my car on the dyno, they are almost done defining all the tables in my ECU.
    And I bent both my drivers side wheels at Buttonwillow this weekend on this section somehow???
    Sent from my SM-N950U using Audizine mobile app
    Mar 11 2016
    Orange County CA
    ECS intercooler aluminum pipe kit went in last week. Way better throttle response.
    Fits pretty good with the APR FMIC.
    You can see the OEM hoses are only 1-ply and very stretchy.
    Oct 20 2017
    Hawaii
    Quote Originally Posted by Slick_B8 View Post
    Hey so what did you end up doing about the connectors on the fuel pump? You gonna swap the connectors or go another route? I was wondering if it would fit as well.
    Feb 26 2008
    washington
    Quote Originally Posted by gainesb2003 View Post
    Swap over the top section from the old pump assembly?
    Veteran Member Four Rings Zach L's Avatar
    Feb 23 2010
    Austin, TX
    That ATP log-style manifold has proved problematic on many BT builds on VW applications due to turbulent flow characteristics. It just doesn't flow well as it's a crude and not very well engineered piece. That said, this is awesome that you're going the BT route on this platform and I wish you ease and success! I'll be following this closely just as I have many other FSI/TSI builds over the last decade.
    I would use UM over GIAC if both were making the same offer, but in this case I think it was wise to go GIAC so long as they make good on their promise.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Mar 11 2016
    Orange County CA
    Quote Originally Posted by audisean1 View Post
    You guys have to determine if the fuel sending unit is the same in the B8 - B8.5. It may not be plug and play even if you swap connectors. The pumps, fuel sending units, and level sensors may require different voltages.
    Mar 11 2016
    Orange County CA
    Quote Originally Posted by Zach L View Post
    Your absolutely right about the ATP manifold. It's design is less than ideal. However, for power levels under 450whp it's design flaws don't seem to be a hindrance for the MK6 guys. That A4 big turbo build in Kenya and the A5 one in the UK used that manifold and made almost 500whp. Certainly a custom equal length tubular manifold would be the best, I just didn't want to drop $1200 on one at this stage in the game. I think 400whp is a modest goal in the grand scheme of things.
    Feb 23 2010
    Austin, TX
    Actually I got an offer from Eurodynamic to dyno tune my setup. They are eager to break into the Euro market and have done some big turbo Mk6 tunes already. I'm confident they can dial in a safe, reliable tune for me.
    I'm getting my downpipe and turbo inlet fabbed up next week so stay tuned.
    I'm really interested in the fueling and tuning aspects of your build, and it looks like you've done the preliminary homework. The hardware stuff is all pretty available and straightforward. If your goal is 400whp WITHOUT the use of water/meth or e85 than that makes me smile. From a hardware perspective, your setup should be able to make 400whp on 93 octane using just the 5 injectors, or possibly even just 4 injectors, but people always want to take a shortcut using w/m or e85. That's all good, but some people don't want to mess with w/m on a daily driver. IMO, an e85 tune should be a "plus" tune over the everyday power goal that can be had using just 93 pump gas.
    Aug 08 2009
    belgium
    Very nice!
    Mar 11 2016
    Orange County CA
    I should easily be able to hit 400whp, even with our CA crap 91. I already have meth, mainly for cooling, and I am definitely going to take advantage of the E85 tuning for the track.
    Here is my mustang dyno from October. I'll be getting tuned on the same dyno so I'll have a good baseline.
    The meth gave me a few hp up top while running 60% Ethanol those runs.
