Originally Posted by
ap83
It was hitting both the inlet manifold and fuel rail. Are you using a stock rail or aftermarket?
Looks like I should have plenty of room for fuel lines
I bought the pb5 oil line kit, with all the slack I have it looks like running the feed around the back would be the cleanest way but it's awfully close to the up pipes. Not sure if that would be a problem or not, maybe some fire sleeve would help?
I've been flip flopping on ceramic coating or not. Containing the heat would be nice but I'm concerned about the pipes cracking.
Also not sure what to do with that power steering line lol. The coolant feed is an easy straight line more or less, the return is going to be more interesting. The oil return is a really tight squeeze, I don't think what came in the pb5 kit is going to work.
