Originally Posted by
Pauven
I think I figured out what you meant by ones uploaded on 03.12.18 in the wiki software page. I had to look at the wiki page history to see your individual edit dates, and I see you edited it on Dec 3rd. I think it would be better to reference a value on the web page itself, and not reference an edit date that is hidden from the casual user.
Anyway, I updated to 11231825, and while it is much better, the temperature still isn't right. The amount of the variance varies based upon the temperature being set, so here are some test points:
Audi | RSNav
HI | HI (matches)
84 | 79 (5 degrees low)
73 | 70 (3 degrees low)
64 | 63 (1 degree low)
62 | LOW (mismatch)
LOW| 63 (mismatch)
Also, when I do the seat warmer (0-6), the RSNav shows the current temperature setting (i.e. 70 degrees). Fan speed and vent options look perfect.
Paul
AZ Member stevent76 is a friend of mine, and this weekend I got to check out his install. He has the exact same issue described above, where the temperature shown in Fahrenheit doesn't match the car's climate control display, it is off by a few degrees. He has a 2015 B8.5 S4 with the HN+, while I have the 2012 B8 S4 with the HNav.
Also, I was surprised to see that his engine RPM and vehicle speed (on the Car Info screen) work. Mine doesn't work, and I had assumed that I needed an OBDII reader to get that info. The seatbelt and door open info both work fine on my car, but the speed and RPM are always 0. I have updated to the latest Android System Software for my unit (M8.q5.1.0.1.11231825) and reapplied the latest CAN BUS version (2018-06-03,V201). I had carefully checked for escaped wires during the install, so I don't think that is the issue, but I'm open to any ideas. stevent76 is running the same Android System Software version, but he has the latest CAN BUS V119 since he has HN+, so I'm wondering if this is an issue just with the V201 CAN BUS firmware.
stevent76
Is it possible to change the home screen widget to MPH?
If we can get the car speed to work in my car, I have the same request as stevent76. Here in the USA, MPH is standard. We can't seem to find a setting to change this.
Thanks,
Paul
