BETA 8.8-10.25"/Hardware Version 2.0/US/ System Software Beta(Click here)
- Steering wheel left roller and buttons/ Up - Previous track, Down - Next Track function supported only in Ruixun BT app, for now,/ Press 'Mode' button long to switch between 'Track control mode' and 'UI navigating mode(like before).
- Sound Mixing(allowing BT and important android announcement heard in Radio and Sat radio) can be now turn on and off in Settings. Please deactivate this if you have echo or weird speaker issues.
- Now Ruixun BT caller app has integrated volume adjustment bar in case of using sound mixing. In sound mixing, the handsfree volume will respond only to this volume bar.
- Automatic brightness control values have been changed. Brighter in the daytime, darker in the night time
- MMI console navigation is now supported in CarPlay
- MMI console prev/next is now working in Ruixun BT.
- Gapps stability update
- Translation update
- BT sound volumes are regulated and will not produce painfully large sound.
- Introduced main UI right side speedo/date/door and seat belt information.
>>>>>> To be fixed list
Prev/next track feature support in Google play music/Spotify and etc.
Play/Stop function when steering wheel left roller was pressed in track seeking mode.
Instruction
Business as usual.
update.zip file for SD card/USB stick update
and the other zip file for laptop flashing.
DO NOT TRY IF YOU HAVE HARDWARE VERSION 1. (SHIPPED BEFORE JUNE 2018 - BOTH 2GB/16GB AND 3GB/32GB OR NEVER UPGRADED TO 3+32GB IF YOU PURCHASED BEFORE JUNE, 2018)
DO NOT TRY IF YOU HAVE EUROPEAN VERSION OF MODEM
DO NOT TRY IF YOU HAVE 7", 10.1" 1024X600 RESOLUTION SCREEN. THIS IS FOR WIDESCREEN VERSION.
