Page 4 of 117 FirstFirst ... 234561454104 ... LastLast
Results 121 to 160 of 4665
  1. #121
    Nov 01 2017
    Montevideo, Uruguay
    This picture is from a Q5 right? I want it so badly. Please tell me if it is already available since I don't find it on your site.
    - - - Updated - - -
    Quote Originally Posted by a4android View Post
    Took a look around of the part market, and assembled 8.8 inch one with your Android 6.0 platform.
    How do you like it?
  2. #122
    Account Terminated Two Rings
    Mar 31 2017
    Spanishtan
    Answered by mail.
  3. #123
    Jan 24 2012
    Tucson AZ
    Anthony - thanks for all your hard work on this product! Great to see a fellow Korean succeeding :)
    I have a couple of questions that I hope can be answered:
    1. I have a 2012 Audi A4 - No Nav but B&O: Is the current model the one that will work for me?
    2. How does volume work? Do our native controls either on the console or steering wheel work? If not, what is the process to update when available?
    3. I am using a product called XCarlink that I used to connect my rear-view camera. Will this feed in to your system as well if it is already working on my display? I think it should, or should I reconnect the camera directly to a port on the unit
    4. Do you have a SIM card to recommend for use in the US? I would like to have it access Spotify on it’s own network if possible. I have an iPhone but not happy with the limitations of CarPlay (ie cannot use Waze, google maps, etc) In this case could I still use Bluetooth to automatically answer and make telephone calls?
    5. Great work beta user on DashCommand and VAG-COM! Looks like it opens up tons of possibilities!
    6. Is there any advantage in purchasing the 7” over this unit (ie have the bugs been fixed on that unit?)
    Thank you!
  4. #124
    Veteran Member Four Rings a4android's Avatar
    Jun 08 2015
    Montreal, QC
    8.8 is open too. But it will only fit the original LCD frame like this for B8 sedan/avant etc.
    Q5 is all year.
    Daniel Kim
    2010 A4 B8 - My first car ever!
    2012 A7 C7
  5. #125
    Jan 24 2012
    Tucson AZ
    Sorry - meant Daniel, not Anthony!
    Quote Originally Posted by hanyoung View Post
    Aargh - I meant DANIEL! - thanks for all your hard work on this product! Great to see a fellow Korean succeeding :)
    Thank you!
  6. #126
    Jun 08 2015
    Montreal, QC
    Thank you!
    I guess Anthony you are referring is me.
    1. Yes, go for concert/symphony model
    2. Both. on radio knob it's the amp that increase the volume, and steering button is active for both Android volume and system volume.
    3. You need to remove xcarlink and connect camera directly to our unit.
    4. AT&T would have the best connection with the unit and then Verizon = T-mobile, and not working on Sprint
    5. I think that's Tim(OP)'s efforts.
    6. 7" had rapid screen flickering issue that is sensitive to temperature, but we found a fix. So all 7" will receive this fix sooner or later.
    Daniel Kim
    2012 A7 C7
  7. #127
    Jan 24 2012
    Tucson AZ
    Thanks Daniel - Just ordered the 10.25" with the cybermonday discount! can't wait!
  8. #128
    Active Member Two Rings Nofind's Avatar
    Jun 09 2014
    United States
    Just placed my order for the 8.8 mmi unit. I had been deliberating over which model to get since I wanted as close to stock look, but the ergonomics of the 10.25 so this seems to split the difference.
    Hopefully now that there's a 3g mmi option Daniel does well on sales today
    Sent from my Pixel using Audizine mobile app
  9. #129
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Quote Originally Posted by Nofind View Post
    how much was it?
  10. #130
    Jun 09 2014
    United States
    Quote Originally Posted by Spawne32 View Post
    how much was it?
    Pm sent
  11. #131
    Oct 10 2016
    Madrid, Spain
    Order placed!!! OMG OMG!!!
    I just cannot wait to receive it!!!
    Sent from my SM-G935F using Tapatalk
  12. #132
    Senior Member Two Rings frameshift18's Avatar
    Oct 15 2009
    NE, Ohio
    Is there an image of the 8.8" for the A4 B8 yet? Just curious how it will look and how much of the trim will be replaced. Also, does the 8.8" work with A5 trim at all? Thanks!
    02 S4
    11 A4
    01.5 A4
  13. #133
    Jun 09 2014
    United States
    Quote Originally Posted by frameshift18 View Post
    This was uploaded in another thread. If you Google image search this you can find a few more but they're about the same quality of photo.
  14. #134
    Apr 11 2016
    just pre-ordered the 10.2" 3G for my Q5. Thanks Daniel for your hard work and dedication.
  15. #135
    Jul 15 2017
    B5 A4 2.8
    Fl
    Just ordered as well, it will be worth the wait.
  16. #136
    Senior Member Three Rings kpykng1's Avatar
    Feb 17 2016
    Ventura, CA
    So for Andriod Auto/CarPlay to work with the new 10.25" unit this needs to be purchased also? If so, can I add it to my order?
    2014 SQ5 Glacier White - 22" Touren TF01 - AWE Touring w/resonated downpipes - KW SC Coilovers - 034 Motorsports Rear Swaybar w/ endlinks, RSNAV System
    2017 MINI Cooper Countryman S
  17. #137
    Dec 04 2005
    chicago
    My 10.25 just came in the mail today!! Cant wait to put in.. Daniel, did you have instructions for the a4/a5 as I have an a5 and the instructions that came with my unit were for the q5!!
    Also, for manuals, do you have the wiring to put in a relay to trigger the reverse camera?? Im sure people that drive stick would appreciate!
    Thanks!!
    Jeff
  18. #138
    Senior Member Two Rings Jmstrag's Avatar
    Aug 15 2010
    Quote Originally Posted by vbittnv View Post
    For the relay, the easiest way is to pick up a ground and add a 12v source with a 5A fuse from the trunk fuse block.
    When using a typical automotive relay......
    (30) is your new 12v source from the fuse block
    (85) is your ground which you can pick up off one of the grounding lugs in the trunk
    (86) is your switched 12v source. This is the wire you're gonna tap from your reverse lights. I don't remember the colour but you can test it out with a multimeter at the connector.
    (87) is the wire going to the camera
    Sent from my STV100-3 using Tapatalk
  19. #139
    Jun 08 2015
    Montreal, QC
    I am sorry.
    I am travelling 1200Km with my A4, for next 3~4 days.
    I will respond questions when I get to a motel or something.
    Daniel Kim
    2012 A7 C7
  20. #140
    Veteran Member Four Rings Zach L's Avatar
    Feb 23 2010
    Austin, TX
    More pics of the 8.8" in this eBay listing: https://www.ebay.com/itm/Audi-A4-A5-...-/202106888791
    Do NOT buy the eBay one as it's an inferior product using older version of Android. Pics for reference only.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
  21. #141
    Jun 08 2015
    Montreal, QC
    Quote Originally Posted by Zach L View Post
    This isn't our stuff but our stuff looks the same. But this one is running on android 4.4. 5.1 is fake.
    Daniel Kim
    2012 A7 C7
  22. #142
    Feb 23 2010
    Austin, TX
    Yes, people do not buy the one from eBay. It's an inferior product. Older version of Android and lower specs all around.
    I posted just for reference for people to see how it will fit in the dash.
  23. #143
    Veteran Member Three Rings cybernet99's Avatar
    Sep 06 2014
    2010 A4 S-Line, 2013 MB GLK350, 2004 Yamaha R1 @AlterdA4
    Ottawa, Canada
    Quote Originally Posted by kpykng1 View Post
    Yes, that looks like the same device that I installed with my unit. Daniel has those available as well.
    Follow my build on IG - https://www.instagram.com/AlterdA4
    Integrated Engineering (Sport Short Block | Sport Head Assy | Intake Manifold w 4 x 890cc Injectors), BW EFR8474 Turbo, Custom 4.5" FMIC, Custom 3.5" SS Turbo back Exhaust, Tilton Racing Twin Disc clutch/PP & LWFW, 034 Billet Motor Mounts, AP Racing BBK 380(F)/330(R) floating rotors
  24. #144
    Jun 08 2015
    Montreal, QC
    Daniel Kim
    2012 A7 C7
  25. #145
    Jun 08 2015
    Montreal, QC
    Thanks!!
    Jeff
    https://cdn.shopify.com/s/files/1/19...33366749333167
    Daniel Kim
    2012 A7 C7
  26. #146
    Dec 04 2005
    chicago
    Daniel,
    Thanks, those instructions are perfect for the reverse camera...
    Any instructions for the a5 installation of the head unit?
    Thanks!!
  27. #147
    Jun 08 2015
    Montreal, QC
    Daniel,
    Thanks!!
    Oh well, I need to write up 10.25" instruction again.. but I was too busy. Try to write in next few days. But it's nearly the same as Q5.
    Just using pryer tool take out the LCD frame, and there is total 10 screws for the glove compartment.
    Daniel Kim
    2012 A7 C7
  28. #148
    Dec 04 2005
    chicago
    Quote Originally Posted by cybernet99 View Post
    Daniel,
    Wait, what?? When did these units lose the ability to connect with android auto? There was a video in the previous post that got deleted showing it working fine....
    So I have to add this adapter before I can use Android auto or apple car play? If so, that really sucks.
  29. #149
    Jun 08 2015
    Montreal, QC
    Daniel,
    Well, it will still connect to android auto if you purchase 'head unit reloaded emulator' from playstore, but since it wasn't so stable, i went for the dongle.
    At least, android auto will work with that 10$ app, but don't blame me if it's unstable.
    Daniel Kim
    2012 A7 C7
  30. #150
    Jun 08 2015
    Montreal, QC
    Btw, apple carplay needs that dongle for sure. it's authentication key usb.
    Daniel Kim
    2012 A7 C7
  31. #151
    Jan 24 2012
    Tucson AZ
    Daniel - it was not clear that we needed the dongle from the website. I have already placed my order - is there anyway I can add this to my order to avoid further shipping costs? Or is this dongle available elsewhere for purchase in the states?
    Thank you
  32. #152
    Mar 31 2017
    Spanishtan
    Thank you
    You can find this banner in every single product in the RSNAV website:
    At least it was clear for me.
  33. #153
    Jun 08 2015
    Montreal, QC
    Still on road trip, made over 2000km in two days.
    Crashed today. Don't know if I have to take a day off or what.
    BTW, mmi button and steering support...
    Now I see a reason to bring that shitty UI again.
    The voice is the head engineer Mr. Li keep saying 'this does that this does that and this does that.'
    Daniel Kim
    2012 A7 C7
  34. #154
    Oct 10 2016
    Madrid, Spain
    Yessssss
    The gap between us and the RSA-12305 is finally closing!!!
  35. #155
    Established Member Two Rings steviesteves's Avatar
    Nov 13 2016
    Westchester NY
    So for anyone that has this product was it hard to reprogram through vag com? Just got mine in the mail and waiting for my friend to let me borrow his vag com and install
  36. #156
    Veteran Member Three Rings Fastbke170's Avatar
    May 01 2015
    2003 Silver GSXR1000, Mazda 3S 2006
    Northport
    Quote Originally Posted by steviesteves View Post
    Would that be to enable aux in menu? I was wondering that my self. I have vag cable but my concert system does not allow access to green menu
    2012 A4 Moonlight Blue Metallic : Premium +: RS6 18" GUNMETAL WHEELS: AEM PRO DRY INTAKE: FRANKENTURBO F23L : TopGear UK HFC : TopGear UK 3"Stainless Steel Turbo Back Full Dual Exhaust: TopGear UK Eurodyne Custom Tune:Eurocode FMIC :3 Spoke S4 Black Steering Wheel w/DSG Paddle shifter : S-Tronic Shifter Knob w/Black Boot : LED White Interior: LED Red Footwell Conversion : Hoen White XEON Match Fog Bulbs :R8 Coil Packs: Puddle Projection Lamps with Audi Rings
  37. #157
    Dec 01 2011
    it should be pretty simple if you have the vagcom cable. the instructions are included with it as well, you just go into one of the modules and change a value and you get the aux option enabled.
    IG @theshawon
  38. #158
    Sep 06 2014
    Ottawa, Canada
    Quote Originally Posted by Fastbke170 View Post
    It takes less than a minute with the vag-com cable. Super simple, just follow the instructions. I have concert and non-mmi (no green menu etc) ... this was actually the first coding change I did after getting my vag-com cable and it is super easy. Just follow the directions. :) Oh, and this only needs to be done if you have the AMI and don't already have AUX listed in your available media types.
  39. #159
    Active Member Two Rings Enchiladas's Avatar
    Jun 17 2017
    North Carolina, USA
    I ran into problems in my b8.5 install. When the hazard light is plugged into the plastic 10.25" mount, the plastic mount doesn't fit flush to the dash. It's too far away for me to connect the plastic mount to the metal mount with the small screws that are included. If I unplug the hazard light it fits well enough, but that isn't really an option, is it? I've attached some pictures to show what I mean. Am I doing something wrong? There is nothing about this part of the install covered in the instructions.
  40. #160
    Oct 10 2016
    Madrid, Spain
    Quote Originally Posted by Enchiladas View Post
    Can't see the pic...
