Page 67 of 67 FirstFirst ... 1757656667
Results 2,641 to 2,668 of 2668
  1. #2641
    Apr 12 2018
    EU
    I have installed the Update and i am happy.
    My volume control Joystick to switch tracks is working. Thank you so much.
    Regardimg the Center.. I havnt tested.
    How Do i connect Both wires?
    Are the connectors matching the Center speaker connectors?
    Is there a howto i can Follow? Someone already plugged that wires and can guide me through?
    Gesendet von meinem SM-G950F mit Tapatalk
  2. #2642
    Feb 23 2019
    Espaρa
    Quote Originally Posted by jormami View Post
    I dont underestand "6. The main page's car image now can be customized: long press the Setting icon in main page, then there will be a prompt to choose a image. The image must be PNG format, transparent background, 500x375px or below"
    What is the "setting icon"???
    Ok. Just I see the setting icon. I changed my image car. Perfect!!!
  3. #2643
    Sep 08 2010
    SF Bay Area
    If I buy the hw 3.0 upgrade(im on hw1.0 right now), will it come with all of these updates installed?
    Sent from my LM-V350 using Tapatalk
  4. #2644
    Aug 03 2017
    Netherlands
    10.25” Android head unit / display (RSNAV)
    I have the airbag warning light in my console, because i connected the display before cutting ome of the white/purple wires (as i have no airbag button on the original trim). When reading error codes using a simple odb2 connector i get 0 errors. Can that one perhaps only be cleared using a vagcom? Or should my basic odb2 plug be sufficient?
  5. #2645
    Mar 29 2019
    Russia
    Quote Originally Posted by sickday View Post
    good for you :) the track change buttons did not work for me after the update.
  6. #2646
    Apr 12 2018
    EU
    Quote Originally Posted by x666hunter View Post
    I have tested Spotify only. I will try other Apps tomorrow.
  7. #2647
    Feb 08 2018
    Italy
    Quote Originally Posted by Erik83 View Post
    Odb2 can do very little. So, probably you need a vagcom. Buy one, it only costs 30eur on ebay and you can do many things.
    Sent from my SM-G930F using Tapatalk
  8. #2648
    Feb 23 2019
    michaelski
    Daniel write, AUTOPLAY APP,please UPDATE.
    what does he mean, where do I do that, in the playstore?
  9. #2649
    May 03 2018
    Freiburg
    Quote Originally Posted by dariusz0 View Post
    In the settings of the App
    Sent from my Pixel 2 XL using Audizine mobile app
  10. #2650
    Feb 23 2019
    michaelski
    Thank you
  11. #2651
    May 03 2018
    Freiburg
    Daniel please re-upload the hw1.0 Europe 10.25. it is going into Recovery.
  12. #2652
    Aug 03 2017
    Netherlands
    Quote Originally Posted by pakidermo5000 View Post
    Thanks! Had a hunch that might be the case. Ordered a hex-can cable to be sure. Saw cheaper ones but for vagcom 409 (i read that’s really old)
  13. #2653
    Senior Member Four Rings a4android's Avatar
    Jun 08 2015
    Montreal, QC
    all HW1.0 firmware is corrupted and will be uploaded later.
    Daniel Kim
    2010 A4 B8 - My first car ever!
    2012 A7 C7
  14. #2654
    Jul 11 2011
    SF Bay
    I would love to see how the steering wheel controls interact with Spotify.. so does a wheel click up/down change track forward/back? Does the app have to be open?
  15. #2655
    Apr 12 2018
    EU
    Quote Originally Posted by paulmm View Post
    I do not have any track-control button at my steering wheel. My volume-control next to my gearshift can be moved to left and right. These button were not working in the past.
    At the moment i am using the Volume-Control and Voice Control button of my steering wheel only.
    Spotify and DAB+ work fine. The App needs to be launched but not to be opend (i have tested the buttons while using googlemaps)
    I will focus on the echo issue next. Hopefully i will have time next weekend to reconnect the center-speaker. If this is working, all my issues were solved
  16. #2656
    Dec 23 2017
    Florida
    Quote Originally Posted by a4android View Post
    Hey Daniel, Thank you for the update. I just have a quick question regarding the left steering wheel roller and MMI control panel. It seems I lost the ability to freely change tracks through those two options with the update (the only possibility is to now change tracks while in the music player as opposed to being able to freely change it in any app). I did notice an option in RealSun settings to change the default action of the left roller as opposed to the previous method of Holding the MODE button for 2 seconds to switch actions. Is there a way to revert to the previous functionality without downgrading the firmware ? or is this some corruption in the firmware as well?
  17. #2657
    May 03 2018
    Freiburg
    Quote Originally Posted by tekkai View Post
    Did you get the hw1.0 to Install?? My 1.0 goes to Recovery after Reboot...
  18. #2658
    Mar 29 2019
    Russia
    When will update for the CAN A3(2013+)?
  19. #2659
    Dec 23 2017
    Florida
    Quote Originally Posted by boere View Post
    Yea, I was able to get it to install, US/CAN version.
  20. #2660
    Jun 08 2015
    Montreal, QC
    Will check if there was an update.
    Daniel Kim
    2012 A7 C7
  21. #2661
    Jun 08 2015
    Montreal, QC
    TRK control is not available for all apps.
    We tried that last time and it caused system-wide malfunction with MMI consoles. So it's working for limited apps. Will take a look of Spotify in the next update.
    Mode button switching function has been removed due to many saying there steering got malfunctioned.... actually they pressed the button too long so it was changing the function every time and they misunderstood about it. Somebody made a return for that... even though he was explained.
    Daniel Kim
    2012 A7 C7
  22. #2662
    Dec 23 2017
    Florida
    Ah I understand. I was mainly referring to track control mainly for the RSNAV device, as in audio played through Bluetooth, the RSNAV native player. It does work within the app, but it doesn't work when the app interface is not open, as compared to before the update.
  23. #2663
    Feb 08 2018
    Italy
    Hi Daniel, just one question. I have a HW 3.0 with software 2.0 on it and a 2.0 harness with the noise isolator. Currently I get no sound from the rsnav unless I connect the 3.5 jack.I get sound from MMI though.
    Inorder to get sound without the jack
    I need to :
    1- upgrade android firmare to V3. 0 (via usb flashing)
    2- activate aux in green menu (already enabled in my case)
    3- upgrade CANBUS to 202 (via sdcard)
    4- upgrade MCU to HW3. 0 (via sdcard? )
    5- remove noise isolator for higher sound quality
    Is that correct?
  24. #2664
    Jun 08 2015
    Montreal, QC
    RSNAV needs your help.
    For the upcoming Android 7.0 update, we need new translations in your language.
    Please submit your translation.
    http://wiki.rsnav.com/Localization
    Daniel Kim
    2012 A7 C7
  25. #2665
    Established Member Two Rings fanrazy's Avatar
    Dec 31 2017
    Spain
    Daniel, i bought a 8.8 EU Audi a5 concert model with new hardware month ago, I had done the Update and works well, (i am very happy with the next track funcion on my spotify player) but i have a question. It is mandatory to update the canbus.bin? I tried to install but recovery menu appears ...
  26. #2666
    Feb 23 2019
    Espaρa
    Daniel, do you need spanish traduction?
  27. #2667
    Mar 29 2019
    Russia
    Made a translation into Russian
    https://drive.google.com/file/d/1Bch...ew?usp=sharing
  28. #2668
    Oct 10 2016
    Madrid, Spain
    I'll do French if you want...
    Sent from my SM-G965F using Tapatalk
