Originally Posted by
siff
I rebuilt with the JHM kit. Bought the car used and literally one missed shift from me trashed 1st and 2nd gear. Came with a great DVD walk through. Did it all with Harbor Freight tools in about a day. They send new seals also, no problems since. That is besides me putting the input seal on poorly and having to take the whole engine out a second time when it was leaking transmission oil, the fun of learning.
Now that you bring it up, I'm actually curious as to how you put the input shaft seal on anyhow? I assume just lube it up with oil and gently slide over. Also, how fast are you able to shift from 1st and 2nd?
LJS
FWIW- When CHAMPION was racing his S4 he found that the "de-burr" method eliminated the issue with the collar...That was a WHILE ago---
There was a write-up in AUDIWORLD, back when he was racing and was a contributor to that forum, that detailed what "fails", what he did and how it worked...
I'm sure the new technology in synchro materials and better manufacturing methods (attention to tolerances and necessary clearances) make the new stuff a better
"mouse-trap"
From what I've read, the new syncros and collar are made of a stronger material, so I'll more than likely be going that route anyhow.
S4James
OEM replacement collar (updated part) is what I would put in, not a cheap replica.
That's the plan. Updated collar + all new syncros on all of the gears.
jibberjive
My biggest concern is mainly the collar. From what I've read, the updated collar/syncros are made of a stronger material, so I get the feeling that we be the ideal route to take anyhow. Question is, whether or not the JHM collar will be as well made as OEM updated.
