Results 1 to 11 of 11
    Established Member Two Rings eddie_m's Avatar
    Jul 25 2017
    Chicago
    B8/ b8.5 timing chain Poll (any kinda failure or problem)
    So I’m gonna be the first one here it’s gonna be interesting to see how many people have any issues so far.
    Audi s4 b8.5 2013 75000 miles timing chain stretch complete timing chain replacement including cam adjuster
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    What kind of oil do you run and what intervals?
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Jul 25 2017
    Chicago
    Quote Originally Posted by rtl5009 View Post
    To be honest I got the car on may it had 71000miles on it was good maintained when I checked the car fax. when I got it I didn’t change the oil it was already done by the dealer so I really don’t no what oil they use
    Veteran Member Three Rings P1Racer's Avatar
    Nov 18 2014
    Santa Cruz,California
    When you would cold start the car did you get any sort of chain rattle?
    2011 S4, 034 DP ECU/TCU, AWE Inlet pipe, JHM 187mm Crank pulley, CTS 57mm Supercharger Pulley, AWE Touring Exhaust- 102mm, JHM V2 Test Pipes. @TommyLinebarger
    Jul 25 2017
    Chicago
    Quote Originally Posted by P1Racer View Post
    Not only cold star but even if I would leave my car for 15 min and start it it would rattle.
    to be honest I saw it coming it was doing it so often one day I started the car to go to work and check engine light came on took it to dealer they took both valve cover of and saw both camshaft off. They thought in the beginning my tensioner failed but they said it would be impossible so they took the engine out and determine that chain were stretched no teeth skipping so they had to replace everything
    Senior Member Two Rings The Machine's Avatar
    Aug 08 2017
    Earth, TX
    Jesus, what is the dealer charging you to do all this work?
    Jul 25 2017
    Chicago
    Quote Originally Posted by The Machine View Post
    Complete job without the cam adjuster was around 7000$ parts and labor warranty was paying for it and and since the engine was out I did additional things like one engine mount, thermostat, water pump pcv valve and two cam adjuster for the timing chain weren’t covered by warranty payed out of pocket around 2000$
    Nov 18 2014
    Quote Originally Posted by eddie_m View Post
    Wow! All said and done I’d feel pretty stoked about that. Investing 2k into a car knowing the common problems are fixed. Would feel good to know your car will last another 100k-150k miles!
    Established Member Two Rings Bifffairburn12's Avatar
    Nov 16 2016
    2008 Yamaha Stratoliner 1900cc
    Essex Junction Vermont
    What warranty did you have that covered this?
    Jul 25 2017
    Chicago
    Quote Originally Posted by Bifffairburn12 View Post
    Honda care
    Veteran Member Four Rings quietcropduster's Avatar
    Feb 21 2015
    2014 C7 Corvette 3LT Z51
    Ohio
    Not to thread jack BUT lol. When did it rattle just under cold starts or? Does it in any way mimic the issue mine is having?
    2013 S4 45k miles, (currently) stock tune, intake and x pipe r only modifications.
    Short version of the story...After the VVT TSB was done at dealer (under warranty) now no longer under warranty, I noticed a faint rattle coming from the driver side firewall were the steering stem comes thru. It's only bet roughly 2500-3000 RPM. Sounds like an exhaust leak or chain rattle.
    Only makes the noise under load. When stationary revving in neutral does not make the noise. Even putting car in neutral coasting and free revving motor, noise goes away.
    I replaced the drivers side flex pipe bec the Audi tech claimed it was leaking, but it was not (shocker I know)
    I took a video to help describe the noise:
    https://youtu.be/4NaNoJncGbI
    Sound only link: https://drive.google.com/file/d/1-Pn...w?usp=drivesdk
    Any advice would be greatly appreciated!
    B9 S4 Prestige | Glacier White Metallic | B&O | Sports Diff | CF Inlays | Roc Euro Intake | APR FMIC | ECS Valved catback | 034 tour brace/RSB & trans mount | Forge Motorsports OCC | Michelin PS4s | EPL Stage 2 93 |
