Page 7 of 36 FirstFirst ... 5678917 ... LastLast
Results 241 to 280 of 1433
  1. #241
    Established Member Two Rings pabohoney1's Avatar
    May 03 2017
    Phoenix
    Quote Originally Posted by a4android View Post
    It boots similar like stock mmi. Sorry.
    But it will be stay on for 5 min hop out and in.
    With auxiliary battery it may be possible to keep it alive. But I think I have to figure out which is the best way to doIt boots similar like stock mmi. Sorry.
    With auxiliary battery it may be possible to keep it alive for a long time. But I think I have to figure out which is the best way to do that with charging battert etc.... I think the device was drawing 0.5~6A when working and need to calculate Wh.
    There's some good info about Doze and App Standby here:
    https://www.greenbot.com/article/302...rshmallow.html
    Might be good to test how well that works and if 30 minutes can be tweaked.
    2013 S4 S-tronic, Merc Racing Heat Exchanger, GIAC Stage 1/TCU, DIY Arduino ECA
  2. #242
    Dec 18 2009
    2015 Jeep Wrangler JKU
    Atlanta, GA
    Nope, it does not have any batter, even a coin battery to keep the clock alive. One of the annoying thing is the clock need to be calibrated by itself every boot.(take a minutes to sink).
    A coin battery will do the job of the timer keeps alive, but then it will be impossible to ship it over air. Thanks to terrorists.
    I am examining if there is a always on point that i can tab 3.3v that is feeded from the car battery.
    This stuff usually don't drain yout battery out unless you don't drive at all over two weeks.
    This is pretty good. So does it use capacitor for the 5 minutes? I am not worried as much about the clock of using Android Auto client.
    Sent from my Pixel 2 XL using Tapatalk
    2018 Audi S5 SB - Gotland/Rotor
    Previous Cars █
    2010 Audi A4 2.0TQ 6MT
    2008 Audi TT 2.0T S-Line DSG
    2005 VW Jetta GLI 1.8T 6MT
  3. #243
    Sep 03 2017
    Sweden
    I don't mind the start up time. It's actually quite good for an android device in my opinion. And as some already have mentioned, it starts to boot when you unlock the car. Then it takes a couple of seconds to get into the car, get seated and start the car. The first thing I do then is putting the car in reverse. The backupcamera is displayed (even when the device haven't started yet). I reverse out from my garage, and by the time it returns from the backup camera view when I put it in drive the device has often already booted up or is near booted. So it's not really a problem for me.
    But I would welcome an option to have the RSnav always on/sleep mode if it doesn't drain the battery too much. That would be the icing on the cake. Then I could finish long downloads and other stuff without being near my car.
  4. #244
    Veteran Member Three Rings Fastbke170's Avatar
    May 01 2015
    2003 Silver GSXR1000, Mazda 3S 2006
    Northport
    I noticed in the c7 thread a guy used an HDMI adapter to mount in his cigarette lighter port. He then plugged a fire stick into the port and via hot spot was able to view movies. Very cool but at the same time redundant IMO unless I'm wrong. The device runs android. Install kodi just as I have on my S8 phone, run any build you wish still pulling your signal from hotspot and your fine. If the the devices specs are 8 core with decent ram it will blow away the fire stick. Just my thoughts.
    2012 A4 Moonlight Blue Metallic : Premium +: RS6 18" GUNMETAL WHEELS: AEM PRO DRY INTAKE: FRANKENTURBO F23L : TopGear UK HFC : TopGear UK 3"Stainless Steel Turbo Back Full Dual Exhaust: TopGear UK Eurodyne Custom Tune:Eurocode FMIC :3 Spoke S4 Black Steering Wheel w/DSG Paddle shifter : S-Tronic Shifter Knob w/Black Boot : LED White Interior: LED Red Footwell Conversion : Hoen White XEON Match Fog Bulbs :R8 Coil Packs: Puddle Projection Lamps with Audi Rings
  5. #245
    Dec 01 2011
    ^^ i saw that, and yea seemed redundant. but i don't know what i was even looking at, if it's a separate adapter for the 3G mmi guys, where it just does like carplay/android auto or something without the actual unit like this one, just a display adapter?
    but yea if it's like this full unit, that's definitely not needed, the unit itself can download w/e the firestick can and more, amazon prime video app, apps for w/e else, kodi, etc.
    IG @theshawon
  6. #246
    Veteran Member Four Rings a4android's Avatar
    Jun 08 2015
    Montreal, QC
    Quote Originally Posted by Fastbke170 View Post
    I think you are mixing up stuff here. That one with HDMI is not running on Android OS. This Android interface does not have HDMI input or output.
    Daniel Kim
    2010 A4 B8 - My first car ever!
    2012 A7 C7
  7. #247
    May 01 2015
    Northport
    Ahh sorry, I guess that unit was Apple version.
  8. #248
    Nov 01 2017
    Montevideo, Uruguay
    Daniel HI.
    The fact that you can't ship by air is not a problem. Yo could send the KIT without coin battery and the Buyer should buy one locally.
  9. #249
    Oct 10 2016
    Madrid, Spain
    Quote Originally Posted by bzene View Post
    Daniel HI.
    Yes but you'd have to open the unit and fit the battery on the board...
    Can see quite a few issues arising from this...
    Sent from my SM-G935F using Tapatalk
  10. #250
    Jan 03 2013
    Baltimore
    Quote Originally Posted by briceportier View Post
    I agree, there will be lot of problems with adding this "battery." I do not see the benefit whatsoever. Just a give yourself an extra minute when going somewhere, problem solved!
    Sent from my Pixel using Tapatalk
  11. #251
    Nov 27 2017
    Odense
    It shouldn't be hard to add a battery backup without opening the unit. Just insert a 12V UPS in line with the power supply. Or, if it runs on 5V, a USB power pack.
    Of course how useful that is depends on the power consumption of the unit. Again, detailed specs would be nice. :)
  12. #252
    Nov 27 2017
    Odense
    For me this would be kind of a big deal. I'm hoping it's more like 20s from you unlock the car.
    One of the big annoyances with the MMI(+) and stuff like the RNS-510 from VW is that, quite often, one of the first things you want to do when you get in your car is enter the address of the place you're going. And I just can't find anything to do while I wait. Okay, so I've started the engine, fastened my seat belt... 58 seconds to go before I can start slowly dialing in the address... 57... 56... ah screw it, I'll just use my phone. You know?
    It boggles the mind that this is what you get in an expensive luxury car. Also, it can shift gears in 8 ms, but the infotainment system has 500 ms of input lag. What's up with that!
  13. #253
    Jan 03 2013
    Baltimore
    Quote Originally Posted by rt11 View Post
    To each their own I suppose. I don't expect to change your mind on something fairly trivial in my opinion.
    What do you do when you get to work and wait for your computer to boot? I usually just stare into space and zone out for a bit.
  14. #254
    Established Member Two Rings LTopher's Avatar
    Oct 19 2017
    2001 Jeep GC; 2011 Jeep GC
    South Carolina
    Start up time? Lols--1st world problems haha...
    My 10.1" just shipped and I can't wait! Mainly interested in using Waze and adding a backup camera, never even considered the boot time. I usually let my car finish the warmup cycle and wait for the rpms to drop before driving anyway.
    Do I need to buy an external GPS antenna, or is it included?
  15. #255
    Veteran Member Three Rings cybernet99's Avatar
    Sep 06 2014
    2010 A4 S-Line, 2013 MB GLK350, 2004 Yamaha R1 @AlterdA4
    Ottawa, Canada
    Quote Originally Posted by LTopher View Post
    The gps antenna is included in the box with the unit. You can check out my thread on the 10.25" unit for my approach for installing the gps antenna.
    Follow my build on IG - https://www.instagram.com/AlterdA4
    Integrated Engineering (Sport Short Block | Sport Head Assy | Intake Manifold w 4 x 890cc Injectors), BW EFR8474 Turbo, Custom 4.5" FMIC, Custom 3.5" SS Turbo back Exhaust, Tilton Racing Twin Disc clutch/PP & LWFW, 034 Billet Motor Mounts, AP Racing BBK 380(F)/330(R) floating rotors
  16. #256
    Jun 08 2015
    Montreal, QC
    Ok, what is going on here? I was out of town for several days and trying to follow up the thread, but it is taking sometime for me.
    Just post again or PM me if there is a question that I missed.
    Anyway, a news.
    I tested the steering support update, and it works f.....ine (kind of...)
    The thing is for 3G MMI or 13+ up cars there are more steering buttons, but MY12 or below has limited number of steering buttons.
    The big thing that older audis are missing is 'back button'. So, for MY12 or below, I am figuring out how to support 'back' action..
    (or you may consider swapping your steering wheel for more buttons - JK)
    The Confirm action(left steering roller push) works well with our UI, but in other apps, it doesn't work. I need to see why. scroll up and down works fine with all apps that supports keyboard navigation.
    Apple CarPlay doesn't support the steering wheel control, yet. That is due to the third party device(carplay dongle) and app(phone link, auto link) that is not preventing ACP to access the steering buttons. Negotiating with the third party, but their term for supporting steering wheel in ACP is kinda way too expensive.
    For Android Auto, I will check a bypass.
    Daniel Kim
    2012 A7 C7
  17. #257
    Jan 03 2013
    Baltimore
    Anyway, a news.
    Apparently boot time is a serious issue.
    Looking forward to steering wheel updates. Not sure how it will work, but I do have a b8.5 S4 FBSW with the inav button. Don't have a "back" button though.
  18. #258
    Jun 08 2015
    Montreal, QC
    Quote Originally Posted by elscotto80 View Post
    I meant a button we can assign a 'back' function. I am exploring options for key assignment. The key assignment can be changed later too. it was a matter of capturing signal from the steering and it took like what? 6 months.... jesus. It was long journey. Anyway, since we are capturing all the necessary signals, now we can work on ease.
    For booting time, really, there is nothing much I can do now.
    In order to save the boot time or supporting hibernation etc, I need to work on the kernel, and MTK and SoC dev are not giving me any kernel sources.
    When I go to China in coming January, I am planning to capture whatever the source code available in our factory and will make it open to some developers.
    Anyway, Is boot time really concerns anyone? It takes about 45~60 sec normally, and even longer after some app updates, but it starts up when door is unlocked so usually, you wait like 30 secs. I have to say that isn't terrible wait and something you can live with.
    I'd love to make it better and exploring possibilities, but it's very hard to access to a closed information source and convince our communist friends to open their minds.
    But one by one I am achieving stuff, so let's see.
    Personally, I am exploring integration of this device with Raspberry PI and Arduino. I am wondering if I can make Night Vision system - which wouldn't be 'commercial grade' considering the parts available but I am intending to make something at least give you a warning flash when there is something moving with heat signature in dark nights.
    Daniel Kim
    2012 A7 C7
  19. #259
    Nov 27 2017
    Odense
    I make coffee. ;)
    Or, I would, but I leave my computer on overnight doing backups and stuff anyway.
  20. #260
    Oct 10 2016
    Madrid, Spain
    Night vision, seriously?!?!? WoW
    What about HUD?
  21. #261
    Jun 22 2017
    St. Louis Area
    An aftermarket HUD would be awesome
    Sent from my SM-N950U using Audizine mobile app
  22. #262
    Nov 27 2017
    Odense
    For me at least, this would be amazing. Please please, the more you can open up the better. I generally have no reservations at all buying devices I know are "hackable."
    I'm buying it anyway, just to be clear, but it would still be amazing. ;)
    Boot time does concern me, but it's not a dealbreaker.
    Personally I'd want to experiment a bit. The car already has a big battery, so I could see myself hooking the Android unit directly to that, via a 12V cutoff relay and a 5V (?) regulator, and using the normal MMI power supply as a signal to put the unit in low-power mode when it would otherwise switch off completely.
    But that all depends on hackability: what I can do with the USB ports, if it requires root access on the device, etc. If it isn't feasible, a 30 second wait isn't the end of the world, considering all the other benefits of Android over the MMI.
  23. #263
    Jun 08 2015
    Montreal, QC
    Fu*k DHL Hong Kong!
    Five of you who received the tracking number from me is wondering why the tracking isn't going further.
    I have to blame DHL Hong Kong. This f*cker keeps 5 items in their warehouse and not loading into DHL flights.
    The reason being is there are already too may item delayed about a week, so they are saying they would process the five shipments when it becomes our pallette's turn. .
    I asked the fu*ker then return the item to the factory so that I can at least refund people! But they say 'nay' to that either, because it's practically impossible for them to dismantle a pallette of shipment now. So anything shipped from Hong Kong by DHL is fu*ked up really.
    Why then did I choose DHL HK? because they were offering the best rate that I am charging now for my site.
    I can opt for DHL Shenzhen and they are processing stuff faster, but then again I have to charge 'the prices what you see in DHL.com from Shenzhen to your city'.(over $100 US easily).
    People are already complaining about the shipping fees, so how could I increase further?
    It's a deadlock for me. Maybe I terminate the business relationship with DHL and work with EMS(Postal Service) for the standard delivery of 15~21 days.
    Nevertheless, EMS doesn't want to ship the huge box of 10.1" for A4, S4.
    Shipping is really a headache for me... ah...
    Daniel Kim
    2012 A7 C7
  24. #264
    Junior Member One Ring
    Nov 23 2017
    espain
    any information about integration with with mmi 2g with bang & oulfsen sound sistem?
    regards
  25. #265
    Jun 05 2017
    Norfolk, VA
    Out of the blue, I got a message that DHL was sending my unit. I got it Sunday, so it actually got to me pretty fast all things considered. still haven't gotten it installed, but I will be shortly.
    So can I use the micro SSD slot for music or would I be able to tether the device to my phone as a hotspot to stream music?
    S4 B8 3.0T, Silver: Current - Sports Diff. APR Stage 1
    A4 B8 2.0T, Silver: SOLD - APR: Stage 2
  26. #266
    Jun 08 2015
    Montreal, QC
    RSNAV HDMI output test
    Using Diamond BVU3500H adaptor.
    News
    - DHL is screwing up for everybody. Not doing business with them anymore.
    - 3G MMI is on the schedule.
    - Steering wheel support is almost done. Just changing assigned keys(make 'confirm' action work) and retrofitting our apps for better navigation
    Daniel Kim
    2012 A7 C7
  27. #267
    Jun 08 2015
    Montreal, QC
    Quote Originally Posted by Maz_Audi View Post
    Yes, you can use SD slot for music, and tethering and streaming also works well.
    Daniel Kim
    2012 A7 C7
  28. #268
    Established Member Two Rings Tineo's Avatar
    Jul 08 2013
    Dairy Land, Asturias - Spain
    Using Diamond BVU3500H adaptor........
    superb video output!!
    rsnav USB port supports 3.0 transfer rate?
    2008 A4 B8 3.0tdi Quattro Sedan 6MT EuroSpecs
    Ibisweiss | TLR remap to 301hp | S-Line interior | Rotor 19" rims | S4 front & rear brakes | Depo taillight LEDs w/ fulldynamic LED turn signals | 80mm exhaust tips | S4 blackgloss grill with blackgloss valence | S4 pedals | RSNAV 8.8" ...and more
  29. #269
    Jun 08 2015
    Montreal, QC
    Quote Originally Posted by Tineo View Post
    Nope. USB2.0 HS 480mbps is the maximum. The entire platform was built on USB 2.0 and I think SoC builder has no idea when they would implement usb 3.1.
    What is it? Is the year 2000 now?
    Pew...
    Daniel Kim
    2012 A7 C7
  30. #270
    Jan 03 2013
    Baltimore
    Anyone having issues with the backup camera lines not moving with steering wheel changes? Just started for me they don't move when I turn the wheel.
  31. #271
    Jun 22 2017
    St. Louis Area
    Mine move but I don't have the camera installed yet. I can't get the stock handle off. It is a setting in the Realsun settings, I think.
  32. #272
    May 16 2017
    Reus/Tarragona/Spain
    Hi guys
    I still await information about my order from DHL.
    On the DHL website, they only give this information:
    Thursday, December 07, 2017 Location Time Piece 1
    Shipment information received HONG KONG - HONG KONG 13:36
    I'm worried
  33. #273
    Account Terminated Two Rings
    Mar 31 2017
    Spanishtan
    Quote Originally Posted by Pickart View Post
    Hi guys
    I'm worried
    I hope this helps as a reference of a shipment to Spain: https://www.audisport-iberica.com/fo...quipo-rsnav-7/
  34. #274
    Jan 03 2013
    Baltimore
    Quote Originally Posted by StLght3 View Post
    Yes, the setting in the app is toggled correctly.
  35. #275
    Jun 08 2015
    Montreal, QC
    Randomly that kind of bug(PDG not working) happens... figuring out why.
    It tend to come back few days later... errrrrrr....
    Daniel Kim
    2012 A7 C7
  36. #276
    Active Member Two Rings Enchiladas's Avatar
    Jun 17 2017
    North Carolina, USA
    Mine work well enough, but the blue in the middle is so dark it impairs my view, so I turned them off.
  37. #277
    Jun 17 2017
    North Carolina, USA
    Is anyone else having problems getting music to play directly from the device itself? I can play music from my phone, and Apple Music works well enough. I was hoping to get Amazon Music working on the RSNav, but nothing will play. I'm having the same problem with Google Play Music.
  38. #278
    Oct 10 2016
    Madrid, Spain
    Quote Originally Posted by Enchiladas View Post
    What about Spotify?
  39. #279
    Jun 08 2015
    Montreal, QC
    It seems BT music works but native music play isn't working... interesting. Go and run Volume Adjust APK and play with the sliders.
    Daniel Kim
    2012 A7 C7
  40. #280
    Jun 08 2015
    Montreal, QC
    Hi guys
    I'm worried
    Call you local DHL.
    They will say DHL does not received the item in their 'service centre'.
    Tell him you want 'special investigation team' to track the parcel.
    If the DHL rep says he's 100% sure DHL doesn't received item, ignore and ask again 'So I want a proof in writing from DHL stating it's not with DHL. So ask your special investigators in Hong Kong to confirm that'. Repeat this as many as the CS agent would give up talking to you.
    A day later, 'Magically' the item will be processed and arrive in your home within 3~5 days.
    I saw those special investigators are practicing black magic recently.
    Great Job DHL.
    Daniel Kim
    2012 A7 C7
