Page 26 of 36 FirstFirst ... 162425262728 ... LastLast
Results 1,001 to 1,040 of 1433
  1. #1001
    Senior Member Three Rings viceroy1976's Avatar
    Jul 11 2011
    2014 Audi A4 allroad quattro 2.0TDI
    Johannesburg/GA/South Afr
    Also just applied the latest updates.
    Now I'm getting the fan control overlay as well as CarInfo popping up randomly, and CarInfo still doesn't work properly. Doesn't recognise doors opening, and is very confused over the seatbelt status, and rarely gets it right.
    2013 Audi S6
    2013 Audi A5 3.0T coupe quattro s-tronic (S5 wannabe)
    2010 Audi S4 6MT
  2. #1002
    Nov 12 2011
    Singapore
    Audi/Android Interface Units
    Agreed and mine is RHD. You can manually set carinfo to “off”. Go to RSNAV settings page, and then set “Overlay display” to “Do not show nothing” (default is 5 sec).
    Quote Originally Posted by viceroy1976 View Post
    Sent from my iPhone using Tapatalk Pro
  3. #1003
    Jul 11 2011
    Quote Originally Posted by soundwave View Post
    Agreed and mine is RHD. You can manually set carinfo to “off”. Go to RSNAV settings page, and then set “Overlay display” to Off or show nothing (default is 5 sec).
    Mine is RHD too.
    Thanks for the tip, I'll turn off the overlay, just wish it would work properly as the semi transparent fan control overlay is a nice touch
    2013 Audi S6
    2010 Audi S4 6MT
  4. #1004
    Nov 12 2011
    Singapore
    The aircon temp display still works though, as that is a different app called “AudiWind”. Luckily...
  5. #1005
    Dec 18 2017
    italy
    Quote Originally Posted by nelsonlye View Post
    Mean u didn't read my early post? Which is just 2 post above yours.
    通过我的 SM-N950F 上的 Tapatalk发言
    Thanks all!
    I confirm that copying the file from the USB to the SD and dismounting/remounting the SD works.
    I performed the update.
    D
  6. #1006
    Dec 18 2017
    italy
    Google Assistant
    Anyone got installed the google assistant app?
    https://play.google.com/store/apps/d...oogleassistant
    I installed it but the app says that the device is not compatible....
    D
  7. #1007
    Dec 18 2017
    italy
    Android auto Dongle - got updated version after june update
    Hi All,
    After applying the june update there is even an update of the dongle software that solved the "usb authorization problem".
    This software even offer the capability of performing "live updates" of both the apk portion and the USB Firmware portion.
    I did the apk live update portion without any problem but with the Dongle firmware update the system says that my USB Dongle current software is too old and I need to perform an "U-Disk" update first.
    Someone know where I can download the firmware of the dongle to perform such as update?
    Many thanks
    D
  8. #1008
    Jul 11 2011
    "AudiWind" is also popping up randomly even though I've not touched any of the fan controls.
    --edit
    After disabling the overlay, the fan control overlay now seems to be behaving.
    2013 Audi S6
    2010 Audi S4 6MT
  9. #1009
    Jan 03 2013
    Baltimore
    So what's the point of "car info" app? It pops up when I start and then goes away. I don't really understand it. There are checks, x's and red X's which don't seem to correlate to anything.
    Also, the temp controls no longer show up when if just the temp.
    Anyone having the same issues?
    Sent from my Pixel using Tapatalk
  10. #1010
    Established Member Two Rings nelsonlye's Avatar
    Feb 26 2018
    Kuala Lumpur
    Quote Originally Posted by elscotto80 View Post
    As far as I know it works on the rpm when I plug in the obdii. But is useless for time being for me. So I just disabled it.
  11. #1011
    Jan 03 2013
    Baltimore
    Interesting. I don't have anything plugged into my OBD port. I see rpm and speedo working, but they seem a bit janky.
  12. #1012
    Feb 26 2018
    Kuala Lumpur
    Is it? Sorry for wrong info. Yes indeed not smooth.
  13. #1013
    Account Terminated Two Rings
    Mar 31 2017
    Spanishtan
    At least you get that info, i just get carinfo short screens at startup and when opening any door.
    - - - Updated - - -
    How did you disable it? Realsun settings?
  14. #1014
    Senior Member Two Rings LGHT's Avatar
    Jun 07 2018
    CA
    Is this setup a separate unit from the stock or an add on to the stock unit? I have a b8 with the non mmi and want to add backup camera and nav and can't seem to find a quick and easy solution.
  15. #1015
    Veteran Member Three Rings cybernet99's Avatar
    Sep 06 2014
    2010 A4 S-Line, 2013 MB GLK350, 2004 Yamaha R1 @AlterdA4
    Ottawa, Canada
    Quote Originally Posted by LGHT View Post
    This would be your easiest solution then. It is an add-on to the factory head unit.
    Follow my build on IG - https://www.instagram.com/AlterdA4
    Integrated Engineering (Sport Short Block | Sport Head Assy | Intake Manifold w 4 x 890cc Injectors), BW EFR8474 Turbo, Custom 4.5" FMIC, Custom 3.5" SS Turbo back Exhaust, Tilton Racing Twin Disc clutch/PP & LWFW, 034 Billet Motor Mounts, AP Racing BBK 380(F)/330(R) floating rotors
  16. #1016
    Jun 07 2018
    CA
    Quote Originally Posted by cybernet99 View Post
    what's it called?
  17. #1017
    Jan 03 2013
    Baltimore
    To elaborate a bit more, this replaces the screen with a touch screen. It is basically an android tablet with all the abilities of using apps for nav and music. Comes with a backup camera as well. You can insert a SIM card for internet, or share your phone's data connection for internet.
    Basically, its pretty sweet. Its come a long way in just about a year since its been available.
    - - - Updated - - -
    what's it called?
    Start at the first post and read this thread. All of the information you need is here.
  18. #1018
    Jun 07 2018
    CA
    I did and it didn't have any info on what the product is, the name, or how to get it. The 2nd post asked for a link to the product, but the reply said it wasn't allowed so I still have no idea what this product is or how I would even go about getting one.
  19. #1019
    Jan 03 2013
    Baltimore
    Check your PM. This thread has a lot of information, please read it.
  20. #1020
    Feb 26 2018
    Kuala Lumpur
    Quote Originally Posted by grabie View Post
    - - - Updated - - -
    https://www.audizine.com/forum/showt...1#post13147260
  21. #1021
    Mar 31 2017
    Spanishtan
    Got it, thanks.
  22. #1022
    Jan 03 2013
    Baltimore
    Anyone confirm that the temp overlay matches what the factory screen indicates? Overlay this morning said 68*, but it's really set to 72. I also had it display 66.444444444. something ain't right...
  23. #1023
    Dec 18 2017
    italy
    Up...
    Daniel can you answer?
    Quote Originally Posted by darkeagle View Post
    D
  24. #1024
    Dec 18 2017
    italy
    Hi All,
    Many thanks
    D
    I'm answering myself.
    To who is even interested to updgrade the box here the informations that I followed (and worked). After this update even the box will update directly from the internet.
    1. Download Auto_Box_Update.img Version: 2018.03.06.1845
    https://www.dropbox.com/s/n01iutzw1e...pdate.img?dl=0
    2. Format USB drive (Udisk) FAT32 then move Auto_Box_Update.img onto Udisk.
    3. Install the new AutoPlay App. Version 2018.03.26.2007
    4. Start the new AutoPlay App. Version 2018.03.26.2007
    5. Insert Udisk into CarPlay dongle first.
    6. Insert CarPlay Dongle into Avin HeadUnit USB.
    7. Select Ok to default USB App popup message.
    8. Wait for firmware update completion message.
    Taken from here: http://www.bimmerfest.com/forums/sho...php?p=12518982
    D
  25. #1025
    Jan 03 2013
    Baltimore
    Anyone else seeing the parking lines stop working (moving with wheel) after the last updates?
    Seems to be ongoing. With each release.
  26. #1026
    Sep 06 2014
    Ottawa, Canada
    I updated to the latest version a couple of weeks ago, and mine is fine.
  27. #1027
    Nov 10 2016
    Melbourne, VIC
    Mine went the opposite after this update. Wasn't working, and now is. Daniel is aware of it and working on it.
  28. #1028
    Feb 26 2018
    Kuala Lumpur
    The best option, is to remove the connection behind your screen to do a reboot, that will fix it. As mention by Daniel previously.
  29. #1029
    Jan 03 2013
    Baltimore
    Yes, I know that's the way to "fix" it but it goes back to not working after a few days. Pulling the trim and screen is a PITA. I'll just have to wait for a permanent fix.
  30. #1030
    Jun 08 2012
    N Massapequa, NY, USA
    Daniel has a warning on the RSNAV site that Android users should not set "Audi Original Interface" as the default startup interface. There is some kind of critical bug that will be resolved in next firmware release.
    I also want to report that I just noticed that in the RealSun settings, you can deactivate certain Audi buttons. I deactivated the volume scroll button. This way the android unit stays at maximum volume output, and the volume is controlled only by the Audi amplifier.
  31. #1031
    Feb 26 2018
    Kuala Lumpur
    Touch wood mine is not working before flash to the latest firmware. Once flash touchwood so far so good.
    Sent from my SM-N950F using Tapatalk
  32. #1032
    Veteran Member Four Rings a4android's Avatar
    Jun 08 2015
    Montreal, QC
    Parking guideline is really has something with AUDI CANBUS itself.
    Mostly and increasingly we are getting more and more stabilization but still, the CANBUS decoder failed to grab the data from time to time and persistent in some cases.
    It's not like we have instruction from Audi for what to catch on the matter of grabbing canbus data, but we set up a some kind of snipping tool in a car and capture the communication which seems to be a specific function.
    That's why sometimes it's hit and miss.
    Daniel Kim
    2010 A4 B8 - My first car ever!
    2012 A7 C7
  33. #1033
    Jun 25 2018
    Moscow/Russia
    Hi, All.
    After installing the device 70201, reset the errors with the VCDS.
    However, errors in block 56 are not reset !!!
    Did anyone have such device errors?
    Address 56: Radio Labels: 8Tx-035-1xx-56.clb
    Control Module Part Number: 8R1 035 186 N HW: 8R1 035 186 N
    Component and/or Version: Concert3 H09 0470
    Software Coding: 0500048004010500015B071000
    Work Shop Code: WSC 06325 000 00000
    VCID: 4088D82FD390643E1D-8014
    2 Faults Found:
    03138 - Input AUX IN
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 133
    Mileage: 39723 km
    Time Indication: 0
    Date: 2018.06.15
    Time: 18:23:05
    02259 - Information Display and Control Head (Front) (J685)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 133
    Mileage: 39723 km
    Time Indication: 0
    Date: 2018.06.15
    Time: 18:23:05
    Below is the status before installing the device.
    Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
    Part No SW: 8R1 035 186 N HW: 8R1 035 186 N
    Component: Concert3 H09 0470
    Revision: 00000002 Serial number: AUZ5Z6M1851311
    Shop #: WSC 06325 000 00000
    Subsystem 1 - Part No SW: 8T0 919 603 G HW: 8T0 919 603 G
    Component: Display
    No fault code found.
  34. #1034
    Jul 11 2011
    Quote Originally Posted by AuNik View Post
    Hi, All.
    I've got that error. Not too worried about it.
    2013 Audi S6
    2010 Audi S4 6MT
  35. #1035
    Nov 12 2011
    Singapore
    Finally I can now launch Android Auto with GPS directly from RSNAV without needing my phone at all.
  36. #1036
    Established Member Two Rings LTopher's Avatar
    Oct 19 2017
    2001 Jeep GC; 2011 Jeep GC
    South Carolina
    So I recently downloaded the latest updates (1) Android system, (2) CAN BUS, and (3) MCU and attempted to install in that order. I copied the 1st update to the root of sdcard, inserted a USB, entered the password and away it went updating successfully. I then deleted the 1st update file and attempted the same process for installing the 2nd update, but it didn't work. It booted into the recovery menu and eventually rebooted without updating.
    I haven't tried the 3rd update as I'm following the instructions on RSNAV and they say to do the updates in order. How can I get the CAN BUS update installed?
  37. #1037
    Feb 26 2018
    Kuala Lumpur
    Quote Originally Posted by LTopher View Post
    Try download again the file.
  38. #1038
    Mar 04 2018
    Germany
    Use a empty sd card.
    Sent from my SM-G955F using Audizine mobile app
  39. #1039
    Nov 12 2011
    Singapore
    Anyone managed to get Google Assistant working?? (It’s not OK.... Google)
  40. #1040
    Jun 08 2015
    Montreal, QC
    was doing this the most of the time recently.
    meanwhile, cut my left hand severely while installing this, so had to rest a few days as well.
    will try to answer emails in the next few days.
    Googlel assistant is reserved to newer androids, and there is no way to support it unless we root it and you tweak it.
    Daniel Kim
    2012 A7 C7
