Page 25 of 36 FirstFirst ... 15232425262735 ... LastLast
Results 961 to 1,000 of 1433
  1. #961
    Oct 10 2016
    Madrid, Spain
    Quote Originally Posted by a4android View Post
    This is no magic. You can also do like this if you get it installed properly (and, if and only if we send you perfectly working device... I feel sorry for few who got a defective unit)
    BTTF title is played over Android Auto's USB sound transfer so the music quality is much more superior. The smartphone mirrored music video is the Bluetooth music streaming to RSNAV device.
    Any pics of the HUD itself? How oem does it look? How do you chose what to reflect on it?
    What about front cam... any solution yet to get it to turn on for set nb of seconds when you shift from P to D?
    Sent from my SM-G965F using Tapatalk
  2. #962
    Nov 12 2011
    Singapore
    Audi/Android Interface Units
    Hi Daniel, I read the news on the other 10.25” thread.
    How about updated firmware for 7” RSNAV? When is it rolling out? It will be great with fixes for Carinfo and implementation of OBD2 functionslity?
    Sent from my iPhone using Tapatalk Pro
  3. #963
    Dec 23 2017
    Florida
    This is fantastic news Daniel. Were you guys still researching th cupholder as well or is that not a viable option.
  4. #964
    Veteran Member Four Rings Poodini's Avatar
    Oct 26 2015
    2016 Subaru Outback 2.5 Limited
    Fremont, NorCal
    So this is some form of projection onto the front drivers side windshield in order to watch video feed?
    Though I applaud the tech involved, I’m not so sure how that enhances my driving experience. If anything, it serves as a potential secondary distraction.
    I’m just waiting for all the dust/fix it’s to be finalized so that when I do finally place an order for the 8.8” version, it should be a straight up install n play without having to go backdoor as often to redo fix its...
    Just my 2 centavos but great work D!
  5. #965
    Apr 12 2018
    EU
    Do you know how long this will take? I want to order an 8.8" version too.
    Quote Originally Posted by Poodini View Post
  6. #966
    Nov 27 2017
    Odense
    They are looking at the suggestion.
    No feedback besides that? Any chance you could press them for an answer?
    I don't mean to be rude, but whenever I'm talking to friends about the RSNAV I always have to add, "but sadly I can't recommend it as it's still sort of an unfinished product." Because, honestly, it's missing some essential and very basic features, like the ability to change audio tracks without having to operate a hard-to-reach touch screen. The MMI media player may be awful in most ways, but at least it let me do that.
    Even more frustrating is that this feature seems to be missing for no reason at all. The unit already intercepts CANBUS messages from the MMI console, and specifically those two buttons, but then it maps them to the left and right keys, instead of the skip-back and skip-foward keys. But... why?
  7. #967
    Feb 02 2018
    Worcester, MA
    I just installed RSNAV into my 2013 A4 with the Concert Radio. Overall this system is great, but there are some system and documentation improvements that need to be made.
    Issues:
    1. After reconnecting the battery I received an error “Dynamic Steering System Fault” and now the steering feels tight. I checked the canbus and the pins and connections seem fine. Any recommendations on how to fix this?
    2. For the most part, the car info app doesn't work, it only shows open doors, not speed, RPM, or seat belt status.
    Things I've learned:
    1. After you disconnect the battery, do not shut the trunk or you will be unable to re-open it. If your rear seats fold down you can access a latch on the back side of the trunk door to open it. If they do not fold down you will need to connect jumper cables to the positive and negative posts in the engine bay, then you will be able to open the trunk.
    2. I was able to easily pry out the center vents using a
    3. The 3.5mm female must connect to the AMI in the glove box in order for the Bluetooth and System sounds to work. Without having this connected only FM sound will work.
    4. Instead of drilling a hole into the AMI to run the 3.5mm female, I removed the rubber tray by lining up the circle notches and then popping it out. I was then able to run the 3.5mm cable through the back of the AMI where the tray used to be.
    5. There are 10 bolts holding the glove box on. There is also a small plastic panel at the bottom left corner of the glove box that also needs to be removed.
    6. When removing the AMI the notches in the audi keys should face towards each other.
    7. I removed the Audi screen faceplate from the Audi trim surround by using a razor blade to cut the plastic that was melted over. I then used electrical snips to cut away the Audi screen faceplate from the trim surround. I cut near the tabs, but didn’t cut the tabs themselves, the screen faceplate broke away easily. I then cleaned up the tabs so their sides were smooth instead of having a top that overhung the sides.
    8. The screen comes with foam circles and its not very clear on where they go, or how many to use. I used 1 for each of the 4 holes on the screen and attached it to the back side of the hole.
    9. I didn’t glue the new screen faceplate to the Audi trim surround. Instead I installed the screen, popped the faceplate onto the screen, then installed the Audi trim surround. Everything lined up perfectly and I didn’t have to worry about glue running or the trim surround being misaligned.
    10. I disabled “besloudness” in the Android Sound Settings, after doing this the sound is much better. Not surprisingly since a Radio Loudness setting typically causes distortion.
    11. Holding your finger down on an app allows you to select a different app shortcut for the main screen
    12. There is a shift lock override under the ash tray, if you remove the ash tray there is a hole where you can insert a small screwdriver to push a button down that will allow you to move the gear selector without starting the car or even needing the key.
    13. I installed the GPS antenna on the windshield to the immediate right of the rear view mirror with the wire going straight up into the headliner.
    14. The documentation shows removing the drivers a-pillar, but I recommend removing the passenger side a-pillar (same side as glove box) to run the GPS and 4G LTE antennas to the top of the windshield.
    15. When connecting the rear view camera in an vehicle with automatic transmission, you only need to connect the yellow rca to the rsnav reverse camera rca, and the red wire to the brown wire (camera +12v) on the rsnav harness. The red and black wires on the other end of the harness where it connects to the reverse camera are only used for manual transmission vehicles.
    16. When running the rear view camera wire from the trunk lid into the trunk, follow the existing harness on the right hinge and tape the wire to the harness as far as you can into the vehicle. Since the trunk opens and closes you don't want the cable to become damaged. By following the wire you create the same amount of slack needed for the trunk to open and close without damaging the camera wire.
    Recommendations
    1. Add a volume bar showing the current volume level when using the radio knob (currently only working for the steering wheel volume scroll)
    2. Program radio arrows (forward and back) to control bluetooth media (next track and previous track)
    3. Add a 10 band graphic equalizer to customize the sound (maybe an App for this)
    4. The wire for the 4G LTE antenna isn’t long enough to reach the center or the windshield, it should be made the same length as the GPS antenna.
    5. Better documentation especially adding documentation for the rear view camera install
    I'll continue to update this list as I think of more things.
  8. #968
    Veteran Member Four Rings a4android's Avatar
    Jun 08 2015
    Montreal, QC
    Whatever... busy... don't look for me.
    Daniel Kim
    2010 A4 B8 - My first car ever!
    2012 A7 C7
  9. #969
    Jan 03 2013
    Baltimore
    Pretty sweet.
    Sent from my Pixel using Tapatalk
  10. #970
    Account Terminated Two Rings
    Mar 31 2017
    Spanishtan
    New wheel?
  11. #971
    Oct 10 2016
    Madrid, Spain
    Quote Originally Posted by grabie View Post
    New wheel?
    and a very cool one with that... Daniel, pls do something about that TT badge though...
  12. #972
    Oct 26 2015
    Fremont, NorCal
    “Whatever... busy... don't look for me.”
    Did Daniel just throw some shade?!..
  13. #973
    May 27 2018
    🇬🇧 Uk
    Hi guys, I have been lurking for some time here and have just received my 7" unit and registered to the forum. I have a couple of questions related to the install which do not appear to be covered here despite the detailed installation notes from the group. I have read the documentation and seen the wiring diagram etc but am unsure of how to connect the rear cam relay. Also unsure of the mic placement. What have you done with yours?
    Also, to break the ice, I thought I'd share a moment with you. Excitedly, I surgically removed the unit from the outer packaging and quickly opened the box. Carefully, I took out the contents one by one, inspected them and mused over the joy to come. Having emptied the contents it dawned on me - No screen! Bewildered, mind racing and in a momentary panic, I lifted the white box out of the outer, still no screen! A wave of disappointment swept over me. How do I resolve this? How much time will it take? Will it cost more? etc.
    Then, I stopped, took a breath and, as I looked back at the box, realised that the depth of the outer didn't correlate with the box that I had removed.
    I felt really stupid when I lifted the layer of protective foam to reveal the screen in all it's glory.
    I did then laugh quite a lot. Stupid is as stupid does I suppose 🙄
    Anyway, I hope I at least made someone smile and look forward to any help that can be given.
  14. #974
    Jun 08 2015
    Montreal, QC
    OBD II BT thing is tricky. It works with those elm327 dongles that have password 1234. Trying to solve it. That's why it's not released.
    Also, trying to support carplay, android auto steering key command.
    Daniel Kim
    2012 A7 C7
  15. #975
    Jun 08 2015
    Montreal, QC
    Daniel Kim
    2012 A7 C7
  16. #976
    Established Member Two Rings nelsonlye's Avatar
    Feb 26 2018
    Kuala Lumpur
    Is 12pm now however my launcher show 12am. Did I miss out any? All the time and time zone is correct.
    Sent from my SM-N950F using Tapatalk
  17. #977
    Dec 30 2011
    South Africa
    Okay, investigated further about parking brake, TPMS. and lane assist etc.
    Parking brake module 00381 Fault is known to be related to unstable battery power. It may be due to intermittent electric power shortage of the vehicle. Check if there is an accessory that consumes too much electric power beside our device. Our devices draw typically 400mA and 900mA at peak. Also, whity's vehicle's battery seems to low if its motor was running. If you haven't replaced your battery last three to four years, it may be good time to replace.
    - - - Updated - - -
    I don't know the detail yet if it's firmware or hardware. I will confirm when I know more.
    Hi Daniel
    I replaced the battery yesterday and I still have the parking brake problem incl the TPMS error popping up after driving the car for 15min (everytime). Also cleared up all the DTC codes manually but it comes up directly after clearing the code.
    VAGCOM scan results after replacing the battery
    Parking Brake Module
    Monday,28,May,2018,16:10:55:16946
    Address 53: Parking Brake Labels: 8K0-907-801-V1.clb
    Control Module Part Number: 8K0 907 801 E HW: 8K0 907 801 E
    Component and/or Version: EPB Audi B8 H05 0060
    Software Coding:
    Work Shop Code: WSC 00000 000 00000
    VCID: 316973F2686B68CE2E-8064
    1 Fault Found:
    00381 - Databus Instrument Cluster
    004 - No Signal/Communication - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 90
    Mileage: 106958 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:18:54
    Freeze Frame:
    Voltage: 14.00 V
    Count: 81
    Speed: 0.0 km/h
    Hex Value: 0x0263
    Hex Value: 0x0001
    Hex Value: 0x1010
    ABS Brakes Module
    Address 03: ABS Brakes Labels: 8K0-907-379-V1.clb
    Control Module Part Number: 8K0 907 379 AD HW: 8K0 907 379 AD
    Component and/or Version: ESP8 quattro H04 0060
    Software Coding: 114D00
    Work Shop Code: WSC 06325 123 12345
    VCID: 7BF591DAFAA7529EC4-802E
    1 Fault Found:
    00473 - Control Module for Elect. Park/Hand Brake (J540)
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 90
    Mileage: 106958 km
    Time Indication: 0
    Date: 2008.05.27
    Time: 00:20:36
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4782
    Hex Value: 0x0016
    Hex Value: 0x02B2
    Hex Value: 0x00FF
    I understand there is no real fix at the moment, just keeping you posted as we troubleshoot.
    Still like to try and purchase another cable to test it out, because the errors only come up if I use the RSNAV cable in between. OEM cable to CAN-BUS doesn't give me any errors.
  18. #978
    Mar 31 2017
    Spanishtan
    So, is there a new update available in RSNAV.com?
    IMHO, the web should show a "more friendly" record of updates so it would be easier to spot new ones.
  19. #979
    Senior Member Three Rings viceroy1976's Avatar
    Jul 11 2011
    2014 Audi A4 allroad quattro 2.0TDI
    Johannesburg/GA/South Afr
    Hi Daniel, Just moving my query from the B8 S4 forum to here to ensure it's in the correct section.
    Quote Originally Posted by viceroy1976 View Post
    I've searched the forum for this, but didn't find any discussions, so please accept my apologies if this has been discussed previously.
    I'm about to pull the trigger on a 7" RSNav unit that someone local to me recently bought but never installed.
    I've been going through the installation instructions, and have a question on the Aux setup.
    I've installed a few of these types of units before (the crappy WinCE ones as well as a few crappy Android ones) and the Aux signal was always intercepted directly at the quadlock adaptor.
    However on these RSNav units it looks like you either have to run a cable to the AMI or the armrest Aux plug.
    Is there are reason for running this cable through the car, that makes it better than intercepting the Aux directly on the quadlock adaptor?
    I'm thinking of just splicing into the quadlock adaptor supplied with the RSNav unit for the Aux signal. Anyone else done this on the RSNav? Any issues?
    The reason is to prevent any emi noise coming near the quadlock. Somehow unshielded line always catch noises in the back of the radio.
    We added an external noise isolator early this year so it went like that. We could have gone for making it internal, but then again 100s of our customers who bought last year wouldn't get any benefit of this improvement. So ensure to the backward compatibility, it was made so.
    So i would not recommend any alteration but proceed as recommended in the manual.
    I understand you are concerned about noise, but in reality the Aux out from the HU already goes through the quadlock, half way along the car to the aux port. Then needs to be routed back halfway along the car to the RSNav aux female port on the noise isolator.
    I do not see how much more noise could be introduced by taking the Aux out direct from the quadlock to the RSNav aux female on the noise isolator, completely bypassing the armrest aux part of the circuit, and essentially removing over 2m of aux wire.
    2013 Audi S6
    2013 Audi A5 3.0T coupe quattro s-tronic (S5 wannabe)
    2010 Audi S4 6MT
  20. #980
    Jun 08 2015
    Montreal, QC
    You can try, but in most cases it causes some noise problem. i suspect that may have something to do with ground isolation, but that may be not your case.
    I am also interested in the outcome because in most cases it caused a noise problem.
    Daniel Kim
    2012 A7 C7
  21. #981
    Jul 11 2011
    I'll let you know how it goes. Should be getting the unit this week.
    2013 Audi S6
    2010 Audi S4 6MT
  22. #982
    Dec 30 2011
    South Africa
    Hi Daniel
    Tried to do the June update today.
    The version on the wiki shows as M8.1.0.1.05311619 but after the software update my unit shows M8.q5.1.0.1.05311553 (done the MCU and Canbus updates as well)
    Also cannot find any option to pair my serial bluetooth device, tried through the bluetooth settings menu. But no response...
    Is version 619 or 553 (last 3 digits) the correct version?
  23. #983
    Dec 30 2011
    South Africa
    Ok left the "searching for bluetooth devices...." for a while and it popped up with OBDII. I was able to pair it...
    I'm still having a problem pairing my BT-005 media remote. The device doesn't have a pin/password, connect directly (tested with my phone)
  24. #984
    Feb 02 2018
    Worcester, MA
    For those who have updated, do you need to copy the update file to the micro SD that came with the screen (in the GPS slot) or can you remove it and install the updates from another micro SD card?
    I have the 7" screen North America in my 2013 A4.
  25. #985
    Senior Member Two Rings alexdell's Avatar
    Jul 29 2011
    Central NJ
    Quote Originally Posted by boostnma View Post
    You can use any microSD card as long as it's formatted in FAT32.
    IG: @puzoyAlex
    C6.5 A6 Avant Ibis White | KW V3's| H&R F+R Sways| XLR8 Dual Pulleys| EPL Stage 2 tune| S4Matty Ported SC+TB| APR CPS| JHM Downpipes| SkiGuard Roofbox|
    gone ---> B8.5 S4 Sepang Blue (6MT) |APR Stage 2+ UC|
  26. #986
    Feb 02 2018
    Worcester, MA
    1. I assume the Android OS is not installed on the SD card that comes in the GPS slot, it is instead installed on the ROM of the screen, correct?
    2. Should I not use the micro sd that came in the GPS slot to update the system? or can this be used?
    3. If I use a different microsd card to update the system, do I leave that card in after the update completes, or do I put the original card back in ?
    4. What is the SD card that comes in the GPS slot used for? When I put the card into my computer it shows 4 folders
    system_update
    LOST.DIR
    backup
    Android
    5. Also when I put the SD card that comes in the GPS slot into the computer, the computer prompted: "There is a problem with this drive. Scan the drive now and fix it." Is this normal? Should I let the computer fix it?
    6. I first tried to update the Android by using a different SD card in the GPS slot, the Android logo appeared and it began to upgrade, however the upgrade progress bar would get to about 5% and then the screen would flash and the progress would drop down to 0%, then get to 5% again and drop again, it continued to do this about 20-30 times, then the screen would reboot and do the same thing all over again. This lasted for about 1.5 hours. I assumed this may have been due to installing the update file on a different SD card than the one that came in the GPS slot, so I put the update file on the SD card that came in the GPS slot and the next time the screen rebooted I swapped the cards. The update then began to progress further, but then the screen below appeared and I was unable to select any option. The screen then rebooted on its own after a few minutes and booted up with the original android version. I then removed the SD card and re-inserted it to restart the update and again it gave me this same screen. What am I doing wrong?
    7. I am using this update file from the rsnav site
    B8(RSA-10XXX, RSA-70XXX) 1024x600 Resolution, Region North America (LTE BAND 2,4,5,7,41): M8.1.0.1.05281802
    I noticed that this is the same file name used for 2 other applications as well (below), should this file be used for all 3 applications? If so, is this the reason why the screenshot says Q5 ?
    PQ35(RSB-80XXX) 1024x600 Resolution, Region North America (LTE BAND 2,4,5,7,41): M8.1.0.1.05281802
    8V(RSB-70XXX) 1024x600 Resolution, Region North America (LTE BAND 2,4,5,7,41): M8.1.0.1.05281802
    8. Also the CAN BUS update listed on the rsnav site is the same file for Concert/Symphony and 3G MMI Plus, is this correct?
    B8 Concert/Symphony Radio: 2018-06-03,V119
    B8 3G MMI Plus(HN+): from 2013 Facelift 2018-06-03,V119
    9. What types and speeds of micro sd cards does the GPS/TF card slot support?
    https://en.wikipedia.org/wiki/Secure_Digital
  27. #987
    Jul 11 2011
    White plug wiring diagram
    Hi Daniel,
    Is this wiring diagram for the white plug still correct?
    Is the aux signal still sent down the main harness or are those pins now unused?
    I'm asking with respect to my previous questions on the routing of the aux signal.
    2013 Audi S6
    2010 Audi S4 6MT
  28. #988
    Jul 11 2011
    Another question,
    If I connect my phone to the USB port, the charging indicator flashes and keep getting notification that a usb connection has been made over and over.
    Is this normal?
    Finally, I bought my unit from someone who never got chance to install it in their car.
    The unit came with EasyConnected installed, does this mean it's licensed? Plugging my phone into the USB port to try, and it fails on step one, so not sure if thats a sign it's not licensed or is linked to the above USB connection issue I'm having.
    Please advise.
    Thanks.
    2013 Audi S6
    2010 Audi S4 6MT
  29. #989
    Mar 31 2017
    Spanishtan
    Just applied the new update patch and got the menus translated into Spanish.
    I see a new interface at startup but disappears and can´t make it appear again. Any hint?
  30. #990
    Feb 26 2018
    Kuala Lumpur
    That's carinfo only appear when u open your car door
    通过我的 SM-N950F 上的 Tapatalk发言
  31. #991
    Feb 26 2018
    Kuala Lumpur
    system_update
    LOST.DIR
    backup
    Android
    We are in same boat. Tried many times and download few times still same can't flash.
  32. #992
    Feb 26 2018
    Kuala Lumpur
    Quote Originally Posted by nelsonlye View Post
    Problem solved. Copy the update.zip to SD card. Unload and load your USB pen drive, run the upgrade process.
  33. #993
    Feb 26 2018
    Kuala Lumpur
    Upgrade mcu after insert password than reboot become like this. Anyone having same issue ?
  34. #994
    Mar 31 2017
    Spanishtan
    Thanks. Carinfo appears as an app and can be launched anytime you like. I´ll test it today.
  35. #995
    Feb 26 2018
    Kuala Lumpur
    Cool Upgrade Successful
    Upgrade Successful, For 7" which hard to access the Memory Card.
    Below are the step.
    Download the Firmware
    http://wiki.rsnav.com/Help%3ASoftware_Update (Choose your model correctly)
    1. Copy update.zip & AudiA4L_lpc1756_V119 (with car info display rename CAN_update.bin).bin.
    2. Insert the USB Pen Drive, this will bring up the Update Code, Cancel it.
    3. Copy update.zip into Internal Root & SD Card Root.
    4. Unplug and Insert again the USB Pen Drive to bring up the update code, insert the password 888666
    5. Sit back and wait for the update, it will restart 3 to 4 times, total upgrade take about 30mins.
  36. #996
    Feb 26 2018
    Kuala Lumpur
    Tested OBD II with Torque. Not so smooth. Anyone having the same?https://cloud.tapatalk.com/s/5b1ba014...609_151155.mp4
  37. #997
    Dec 18 2017
    italy
    Performing the upgrade using an USB pen drive
    It is possible to perform all the updates using an USB stick instead of SD Card? In this way we can avoid to dismount the plastic and the device each time we need to update...
    I refer to doing Android + CAN + MCU update. Anyone successed?
    Thanks
    G
  38. #998
    Mar 31 2017
    Spanishtan
    Quote Originally Posted by darkeagle View Post
    Thanks
    G
    Once you copy the file in it, try extracting/inserting the SD virtually using android menu. It works for me.
  39. #999
    Feb 26 2018
    Kuala Lumpur
    Thanks
    G
    Mean u didn't read my early post? Which is just 2 post above yours.
  40. #1000
    Jan 03 2013
    Baltimore
    Just applied the latest updates. Running well. I like the changes to the UI. Nice that the navi can change what app to open.
