Page 21 of 36 FirstFirst ... 11192021222331 ... LastLast
Results 801 to 840 of 1433
  1. #801
    Junior Member Two Rings
    Dec 24 2017
    Springfield MA
    Any one have an input on this issues I been having since the latest update. My unit does it's own thing from time to time. I posted a video below so you can see what I mean.
    Only way to get it to stop is to reboot the unit. I get this like once every ride.
    Any help would be appreciated.
    https://youtu.be/1NE816jHPS0
    https://youtu.be/TpzHtiCnX-I
    Sent from my SM-G955U using Audizine mobile app
  2. #802
    Active Member One Ring jamz_musik's Avatar
    Mar 14 2018
    Europe
    Quote Originally Posted by chagy8u View Post
    Audizine mobile app
    I have some experience repairing mobile devices. And usually this failure occurs because:
    • The touch screen is dirty, has sweat or humidity. (approximately 90% of cases). The solution is turn off the screen. Then simply clean it properly and turn on the screen again.
    • Defective touch screen. (4% of cases) The solution is obviously to replace the touch module.
    • Software errors / Motherboard (1% of cases) extremely unlikely
    I have not bought the rsnav unity yet, but..
    I'm almost sure you can solve your problem by following the first solution on the list.
  3. #803
    Established Member Two Rings nelsonlye's Avatar
    Feb 26 2018
    Kuala Lumpur
    Quote Originally Posted by elscotto80 View Post
    I don't think the latest software is capable of this yet.
    Sent from my Pixel using Tapatalk
    Yes u are correct... sorry I just keep comparing with my previous android player
    Sent from my SM-N950F using Tapatalk
  4. #804
    Feb 26 2018
    Kuala Lumpur
    Yeah sorry that's what I meant.
    Yeah founded this page..
  5. #805
    Feb 26 2018
    Kuala Lumpur
    Yes you should be able to.
    Go-to the realsun settings for volume.
    There should be a dialer as an app as well.
    Don't think the FM chip is enabled on these units, so no.
    Sound quality seems the same to me.
    Just the sound I just don't feel the sub is working for the rear
  6. #806
    Feb 26 2018
    Kuala Lumpur
    Firmware upgraded successful.
  7. #807
    Jan 03 2013
    Baltimore
    Quote Originally Posted by nelsonlye View Post
    Huh? Not sure I understand.
  8. #808
    Veteran Member Four Rings a4android's Avatar
    Jun 08 2015
    Montreal, QC
    Seems there is EMI noise interfering with I2C Touch interface, could be poor ground or statics.
    To identify the cause, let's do the elimination method
    remove shipping screen protector, wipe with slightly alcohol wet tissue to remove any residual statics.
    Please note that there are two levels of shipping screen protectors - the primary shipping protector which is clearly noticeable with bubble, and beneath it there is another layer of clear protector which is very clear and glaring. This 2nd level has to be carefully picked up by something sharp such as niddle. remove one layer by layer see if it get fixed.
    Please report back after you do this.
    Daniel Kim
    2010 A4 B8 - My first car ever!
    2012 A7 C7
  9. #809
    Jun 08 2015
    Montreal, QC
    Quote Originally Posted by whity View Post
    Daniel I spent some time with an Audi engineer looking at the fault codes in VAGCOM VCDS, we followed your "possible solution" as per your Wiki information. The error comes back directly after resetting the fault code in the control module and not through autoscan clearing of codes.
    Here is the fault code pulled from VCDS
    Address 53: Parking Brake Labels: 8K0-907-801-V1.clb
    Control Module Part Number: 8K0 907 801 E HW: 8K0 907 801 E
    Component and/or Version: EPB Audi B8 H05 0060
    Software Coding:
    Work Shop Code: WSC 00000 000 00000
    VCID: 316973F2686B68CE2E-8064
    1 Fault Found:
    00381 - Databus Instrument Cluster
    004 - No Signal/Communication - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 243
    Mileage: 104904 km
    Time Indication: 0
    Date: 2018.04.05
    Time: 16:24:03
    Freeze Frame:
    Voltage: 12.50 V
    Count: 81
    Speed: 0.0 km/h
    Hex Value: 0x0263
    Hex Value: 0x0001
    Hex Value: 0x1010
    Sorry for the late reply.
    I think you have CANBUS problem. In general, yes, our canbus decoder is erratic, but what you have there is too much.
    Please disconnect the canbus bypass and check if all the connection is rigid. In few posts earlier there was a case that CANBUS bypass pin was maligned.
    Just having conductivity is not sufficient but visually clearly inspect the bypass sockets.
    It may be a good idea to check your parking brake controller 8K0 907 801 E is good.
    We sold about 300 units so far, and only 3~4 had the parking brake related issue.
    If I were your technician, I'd verify CANBUS line that the parking brake is tapping on as well as the PBC and do conductivity test.
    As B8 and B8.5 are getting older, there are so many troubles coming on, for example, for my 2010,
    the parking guideline died all of the sudden like few others and at the same time my driver front, and rear door lock actuators died.
    Well, rear door lock actuator was bizarre for a long time, but two days ago parking guideline died, and the front driver door lock actuator died.
    I also will continue to investigate further on this issue, but we should consider that the car itself could have some problems developing.
    Daniel Kim
    2012 A7 C7
  10. #810
    Feb 26 2018
    Kuala Lumpur
    Hi All, with refer to the Firmware Upgrade.
    http://wiki.rsnav.com/Help%3ASoftwar...AN_BUS_Updates
    My Model is EU and 1024 x 768.
    Do I have update all the following?
    1RSNAV Android System Software Updates
    2RSNAV ANDROID SYSTEM CAN BUS Updates
    3RSNAV ANDROID SYSTEM MCU Updates
    Thanks.
  11. #811
    Jan 03 2013
    Baltimore
    Do we have any timeline for a fix regarding the parking lines? Annoying that it worked at one point and suddenly stops. I'm not sure I agree "the car is old" as being the problem.
  12. #812
    Jun 08 2015
    Montreal, QC
    I am not saying parking line is 'the car is old', but parking brake may be.
    Parking line is, as i said, more frequent problem but yet to identify the cause.
    I see, at least for mine, there is angle sensor issue on the steering.
    We are concerned of everything here and never forget any, but some things are not easy to solve.
    Daniel Kim
    2012 A7 C7
  13. #813
    Dec 24 2017
    Springfield MA
    Quote Originally Posted by a4android View Post
    Drove all day yesterday no issues after removing the second screen protector and cleaning.
    No idea there was a second screen protector never noticed it haha...
    But so far so good
    Thanks for the help
  14. #814
    Feb 15 2018
    Førde/Sogn og Fjordane/Norge
    I'm trying to update my RSA-10205, but it wont work.
    I have copied the update.zip to the root of the TF-Card that followed with the RSNAV and push the TF-Card in and out and get the prompt, I push the password "888666" and it stands "Android rebooting" and then it comes nr.1 just some miliseconds before nr. 2, when nr.2 comes I cant choose anything with the buttons or if I try to touch the display.
    What am I doing wrong? Yes I have download the one with the correct resolution and region(I live in Norway). In case you guys wonder, this is the one: B8(RSA-10XXX, RSA-70XXX) 1024x600 Resolution, Region Europe (LTE BAND 1,3,7,38,39,40,41):*M8.Q5.1.0.1.04021839
    Please help me, I should have got this fixed before i travel, thats 3 days to.
    Sent from my SM-G960F using Audizine mobile app
  15. #815
    Jan 03 2013
    Baltimore
    Quote Originally Posted by HenrikOen View Post
    Do you have the vehicle running while you are applying the update? it needs to be on so the power isn't interrupted.
    This has happened to me a few times, just keep trying till it takes. Try downloading the update file again and put in on the SD card and try again.
  16. #816
    Feb 15 2018
    Yes the car is running in idle. Okey, what will come when its updating correctly then?
  17. #817
    Jan 03 2013
    Baltimore
    You should see an android fella with "android updating". It will also restart a few times. Just let it do its thing till it boots.
  18. #818
    Feb 15 2018
    20180408_180352.jpegI think I found out what the problem is. I use normally a Macbook Pro, and that is what I used to download the zip file and transfer it with.
    But. When the mac is finished downloading, it unzippes the file automatically. So I have to zip it again with the built-in zip program from Apple and then move it to the TF-Card. I tried in every single way, it would not work.
    Now I tried it with a normal Windows 10 Pro machine, and that don't unzip it automatically, so I just moved it to the TF-Card as guided, and now the Android dude is working hard.
    So Mac from Apple was the problem.
    But still, thank you guys for the tips and help.
  19. #819
    Feb 07 2013
    Is the ETA for 2G MMI High for Audi S5 still the same - May?
  20. #820
    Jun 08 2015
    Montreal, QC
    Quote Originally Posted by frostz View Post
    I see a sign of delay, but two months should be enough to make a prototype. Maybe shippable in June.
    Daniel Kim
    2012 A7 C7
  21. #821
    Account Terminated Two Rings
    Mar 31 2017
    Spanishtan
    Interesting. Thanks for sharing.
  22. #822
    Dec 30 2011
    South Africa
    We (myself and Audi technician) confirmed nothing wrong with CANBUS, or PDC when we remove your cable and plug the OEM cable back into the CANBUS. VCDS scan everything perfect no errors.
    Only when I plug in your cable in between the CANBUS and the RSNAV unit I have these issues. Problem is even if I decide not to use all the CANBUS info, lines etc on the car it won't work because there is no way for the unit to switch on?
  23. #823
    Dec 30 2011
    South Africa
    The only logical problem here is the cable as the CANBUS software on the RSNAV unit wont control the info going into the CANBUS if I'm correct. It only reads the info and then converts it into what ever app needs it.
    I'm getting to a point where I would try anything, even purchasing a new cable, but I noticed its not listed on your website anymore?
  24. #824
    Jun 08 2015
    Montreal, QC
    There is such.
    Daniel Kim
    2012 A7 C7
  25. #825
    Dec 30 2011
    South Africa
    There is such.
    ? please elaborate
  26. #826
    Jun 08 2015
    Montreal, QC
    Go to wiki and developer resources and look at the wiring diagrams.
    Knowing what you have to remove,
    Remove them.
    Connect free red wire near main plug which is acc.
    Then the device would start acc on only.
    To sum up,
    Among free wires B+ yellow, ground black, ACC Red.
    Remove canbus lines.
    This, however, out of warranty mod as people often short wires and screw everything.
    Daniel Kim
    2012 A7 C7
  27. #827
    Jun 08 2015
    Montreal, QC
    I want to note that VCDS cannot be error free unless you put original AUDI LCD back and our device removed. I just want to clarify otherwise i will be bombarded with emails how to make vcds look clean.
    Also, Audi technicians does not use VCDS, but ODIS.
    Finally, I have to tell that your case is an isolated case where majority of people do not have parking brake issue, and only two out of 300+ were reported.
    Please do not generalize as if pbc issue is common.
    I would say parking guideline malfunction is common, but not to your case.
    I have still doubt that your parking brake controller may be defective.
    Once I had someone complains alternator noise since installation of our device, i warned him possible pcv valve issue, but he ignored and then his timing jumped with pcv valve failure along with the tensioner failure.
    Daniel Kim
    2012 A7 C7
  28. #828
    Dec 30 2011
    South Africa
    Remove them.
    To sum up,
    There is no wiring diagrams under the developer resources link on your wiki?
    Also sent you a mail in regards to purchasing a replacement cable to try that first.
  29. #829
    Jun 08 2015
    Montreal, QC
    It's technial readings, actually, sorry for that.
    I got your email tommie, but it's 6am in the morning. Yes, that's still available. I will email you later about the detail.
    Guys, I am a bit exhausted as I am getting bombarded with emails recently and I am getting weaker and weaker. I am trying to set a parameter that I work only 8 hours per day, no response in weekends.
    So please do not expect al most real time response like before for some of you might expect.
    Daniel Kim
    2012 A7 C7
  30. #830
    Dec 30 2011
    South Africa
    No problem Daniel, I don't bug you everyday to reply to my emails directly I understand this. You need to understand that the more units you selling the more people will be bombarding you with e-mails that is business...
    Never have I said that your product is terrible and its a common problem and how bad it is. I am trying to solve my problems by interacting with you, the supplier the support etc.
    If I was being unreasonable for just trying to sort out my problems then I feel very disappointing that you think this way.
    Since day one I have been open with you explaining that I am a technician (System Engineer) and I work on cars as well (customer cars, my second business), so I'm not shooting from the hip every time I try and discuss something. I'm trying to be factual...
    I believe in this product and I also try and help out on the wiki where I can with suggestions and help out on the forums, I expect the same and not a finger pointing to other problems. Only reason why I haven't been promoting your product in South Africa is because if I can't even get good support from you with my problem. How would I be able to assist my customers?
    Anyway, when you have time lets talk about the cable and it doesn't have to be NOW (I just expect a response at some stage instead of having to ask in a weeks time again)
  31. #831
    Senior Member Two Rings djsp00kyk's Avatar
    Jul 25 2009
    B9 Sq5, B7 A4, 2.5l swapped NC miata, LS swapped Jeep TJ
    Mississippi
    Dash camera question, does anyone know the quality of the hidden dash cam, and the functionality. Does it start recording when you start the car?
    Sent from my SM-G950U using Tapatalk
    2018 SQ5
    2012 Brilliant Red S4 DSG / Sport Diff / RS4 Grille / CF Supercharged Emblems / Resonated X-pipe, Muffler delete / epl stage1
    2006 A4 (CVT to 6 speed swap)
    Past Rides: E46 ///M3 Topaz Blue Metallic, Eclipse GS-T, Dodge Colt (4g63t)
  32. #832
    Feb 26 2018
    Kuala Lumpur
    Anyone have any clues or suggestion how to change the carinfo to RHT? And how to get it full function? So far only shown doors open and close with wrong direction. Thanks
  33. #833
    Sep 22 2017
    Greece
    disable auto unzip from safari browser :)
    Open Safari
    Click Preferences
    Under the General tab, uncheck the option Open “safe” files after downloading
  34. #834
    Feb 15 2018
    Quote Originally Posted by konan View Post
    Open Safari
    Click Preferences
    Okey, did not know about that option. Thank you.
  35. #835
    Jun 08 2015
    Montreal, QC
    Good to know about this bug... we will fix it later.
    Daniel Kim
    2012 A7 C7
  36. #836
    Nov 12 2011
    Singapore
    Is carinfo built-in to the RSNAV? Or download from PlayStore and what’s the app name - carinfo?
    Sent from my iPhone using Tapatalk Pro
  37. #837
    Jan 03 2013
    Baltimore
    So this is a new bug for me. Started the car and it went through the boot. Screen was blank except for the time and such in the upper right. About five minutes later the screen came on. Anyone else have this happen?
  38. #838
    Established Member Two Rings Sharkonholiday3's Avatar
    Dec 26 2017
    Italy
    Android's fault, it can happen
    once it happened to me too
    but since the last upgrade, I did not do it anymore ... or last hard reset
  39. #839
    Dec 26 2017
    Italy
    Daniel for the future ....
    I have a bi-area climate.
    the temperature is only visible to me and not to passengers.
    while speed and position ... yes.
    thank's for your job
  40. #840
    Feb 26 2018
    Kuala Lumpur
    Quote Originally Posted by soundwave View Post
    Build-in :)
