Page 12 of 12 FirstFirst ... 2101112
Results 441 to 459 of 459
  1. #441
    Aug 04 2013
    Pennsylvania
    So the only accessory you'll have is alternator?
    Stretch belt?
  2. #442
    Established Member Three Rings canduchita's Avatar
    Jan 11 2017
    ypsilanti
    Quote Originally Posted by Mille Bornes View Post
    Stretch belt?
    Well I can't stretch it because it will hit the mount bolt
    But I remember somebody doing some type of tension are right in the middle but I can't remember where I saw it
  3. #443
    Established Member Three Rings Teck09's Avatar
    May 11 2017
    WA
    Quote Originally Posted by canduchita View Post
    Maybe I am missing something but why not just go from the alternator, over the tensioner, down around the crank pulley and then back to the alternator?
  4. #444
    Jan 11 2017
    ypsilanti
    Quote Originally Posted by Teck09 View Post
    Well if I was to do that how would I clear the bolt for the front mount
  5. #445
    Jan 11 2017
    ypsilanti
    1st idea was to do what you just said but it touches the bolt So I'm thinking if it could live without that bolt and I can just grind it down so it doesn't touch.
    The other thing is the belt will be on the tension or on the group side not the smooth part of the belt so I don't know if that will affect anything20180703_163024.jpeg20180703_163028.jpeg20180703_163031.jpeg
  6. #446
    Nov 02 2013
    01.5 S4 Avant 6MT, 02 A4 1.8 5MT, 04 A4 3.0 6MT, 08 Mustang GT, 03 Forester
    Weld up a bracket and mount an idler where the power steering pulley is.
    LDRXN
  7. #447
    May 11 2017
    WA
    The other thing is the belt will be on the tension or on the group side not the smooth part of the belt.....
    Both good points. Didn't think it through when I posted.
  8. #448
    Established Member Three Rings ReggieNoble's Avatar
    Dec 17 2016
    Fl
    Quote Originally Posted by dozer103 View Post
    Best fast solution right there
    Sent from my LM-Q710(FGN) using Audizine mobile app
  9. #449
    Jan 11 2017
    ypsilanti
    Just got a couple pictures from Justin on the blue reflection carbon fiber cluster, Still needs clear but I think it looks really good20180703_143803.jpg20180703_143841.jpg
  10. #450
    Veteran Member Three Rings VR6Bomber's Avatar
    May 13 2009
    car run?
  11. #451
    Jan 11 2017
    ypsilanti
    Quote Originally Posted by VR6Bomber View Post
    car run?
    Yes it does, working on the wiring harness and the power steering delete
  12. #452
    Senior Member Four Rings
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Side note, when you ditch the k03s, ditch that crank pulley as well. Stock is better than that, or go with one of the fancy new options.
  13. #453
    Jan 11 2017
    ypsilanti
    Quote Originally Posted by DieselElectric View Post
  14. #454
    Jan 11 2017
    ypsilanti
  15. #455
    Established Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    Audi EXO S4 built stage 3 plus
    car run?
    My thoughts exactly!
    Your installing and toying with the details, does this beast even run yet????
  16. #456
    Oct 11 2016
    Connecticut
    Never mind LOL
  17. #457
    Oct 11 2016
    Connecticut
    Same as I got. Itís perfect, it looks good, and it does the job they state.
    Lots of high power builds use that pulley here.
  18. #458
    Jan 11 2017
    ypsilanti
    Alright made some progress
  19. #459
    Jan 11 2017
    ypsilanti
