I was fighting the hoist the whole time. With my Allroad being immobile on my mid-rise lift it was hard to get the lift low enough, if you go too low it doesn’t want to come back up without a little running start, I learned this the hard way once, and the hoist high enough. The boom kept running into the hood or I’d run out of travel. I definitely need to shorten my chains, but I’ll have the modify the load leveler. I think that was killing my travel. I also think maybe running the hydraulic cylinder out so far may have popped a seal. Regardless, it’s out, I will game plan for install better now that I know what I’m working with, and now I get to clean clean clean!
I’m pretty sure HF sells a replacement ram/hydraulic unit. I’ll set everything down on blocks, replace the cylinder, and then lift her back up so I can remove the trans and place on an engine stand.
Sent from my iPhone using
Audizine Forum
