Page 13 of 22 FirstFirst ... 31112131415 ... LastLast
Results 481 to 520 of 857
  1. #481
    Senior Member Three Rings panman142's Avatar
    Jun 21 2015
    CRV
    Akron, OH
    Quote Originally Posted by Denio24 View Post
    See, the good thing here is that you're ironing out the bugs and learning a hell of a lot of things. Definitely looking forward to this thread. Also, why didn't you just remove the quench pads? Was the head really that banged up?
    When you finally get it running make sure to prelube not by cranking but by sending oil under pressure through the oil sender port. I didn't do this the first time and I noticed I have grooves in my new cylinder head bearings; it's not bad, but it could have been avoided.
    Welp its probably too late for that lol. Also I believe quench pad removal is going to be the way to go. Busted out ye ol dremel to see what can be done and its not cleaning up that bad. Im interested in more info on that priming technique. Also I got some rings off the Mahle p/n you had recommended in a different thread since they are on backorder at ECS. Summit Racing for the win! I really really really am hoping this head will clean up since everything I have seen thats used looks a bit rough
    2006 6MT, PTE 5557, Fully built engine, too many extras to list
  2. #482
    Mar 24 2013
    Oakdale, CT
    I've never primed any of my engines like that and haven't had issues. I do use assembly lube rather liberally though.
    -Adam
    '07 DTM A4 2.0T|6MT|EFR 7163 Twin Scroll|DoTuning|Built Motor|Meth and other go fast stuffÖ
    '06 A4 2.0T Quattro - RIP (Best ľ mile pass 13.634 @ 103.30)
  3. #483
    Jun 21 2015
    CRV
    Akron, OH
  4. #484
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Quote Originally Posted by panman142 View Post
    Make sure to deburr the faces of those rings. Dont chamfer, just a light deburr with a couple passes of fine file or sand paper. And double check those ring gaps.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
  5. #485
    Jun 21 2015
    CRV
    Akron, OH
    What gap did you decide to run? Also just a light pass on both sides of the ring? My last two sets of Mahles I did not deburr. I think Adam and I gapped the last set to .020 and .018 I think.
  6. #486
    Jan 24 2013
    Chicago
    I'm running CP and I just gapped mine to .019-.020 1st, and .023-.024 2nd.
  7. #487
    Jun 21 2015
    CRV
    Akron, OH
    What turbo are you running and any idea what boost level?
  8. #488
    Jan 24 2013
    Chicago
    For now just a k03 with the JHM tune but until I get some time to fab I'll probably slap on an EFR. I've been wanting to for a long, long time. IMO it's really not worth it to just get a k04-r and be done with it. Sure, it's peppy but if you're going to drop 1.5-2k for a turbo might as well just go bigger.
  9. #489
    Established Member Three Rings B7S3wannabi's Avatar
    Mar 27 2017
    2005 ZCP Competition M3
    Burke, VA
    Or go with the K04-R, enjoy your peppy ride until you get your BT, then sell the K04-R to recover some costs.
    2006 Sline A4 Quattro 2.0T|JHM K04R|JHM Tuning|JHM HPFP, S3 Injectors, RS4 Fuel Controller|R8 Ignition Coils|APR Carbonio|AWE FMIC|Golf R Cam|JHM LTWCP|JHM Clutch w/ RS4 PP & LTFW|JHM SS w/Linkage|034 High Flow Converter, Europaparts Catback|RS4 F&R Brakes w/ JHM LTW Rotors|Stern Adjustable UCAs|STX Coilovers w/Hypercoil Springs|034 Spherical FSBL|034 Solid RSB w/ Spherical SBL|B6 Recaros|Silver Reflections CF Trim|Xtrons 8.0, ES165KX2, IDQ4, JL 900/5 HD|CF Relak Skirts|S5 Rotors|
  10. #490
    Jun 21 2015
    CRV
    Akron, OH
    Small update:
    Third and final block should be making its way back from the machine shop Friday. New rings came in the mail today to go along with a bunch of little odds and ends from ECS (bearings, gaskets, bolts, etc). Going to finish cylinder head repair tomorrow and have maybe a thousandth or two of an inch taken off for good measure on Friday when I snag the block back... Dont worry, clearances will definitely be measured this time... From there all components are going up to the shop and they will be doing the full assembly of the engine and car for me due to some time constraints (I like to take on too many projects at once, its a great bad habit). While its up there its getting trans and diff fluid changed and a small exhaust rattle fixed. Shooting to get them all the components this weekend and he said turn around time should be about a week.
    A final light at the end of the tunnel is slowly appearing after months of daily driving a shitbox. I am confident this one will run.
  11. #491
    Jan 24 2013
    Chicago
    I am confident as well. It's all about taking all the variables away in a build that requires tight tolerances.
  12. #492
    Feb 10 2012
    parts
    Napanee, ON
    At the end of this summer you could convince me to change turbos and buy my EFR 6758. Iíd gladly jump to something I havenít yet tried.
  13. #493
    Jun 21 2015
    CRV
    Akron, OH
    Quote Originally Posted by canadianA4B7 View Post
    You mine as well just hang onto that efr and run it in something. Itís been for sale as long as I can remember... but my memory has seen better days... lmao
  14. #494
    Feb 10 2012
    parts
    Napanee, ON
    Running one now, Malone is tuning.... just like someone else.....
  15. #495
    Established Member Four Rings
    May 20 2017
    New Hampshire
    A K04 isnít a small upgrade so I canít say I really agree with you. It will never be a truly fast car at the drag strip but a quick spooling car thatís fun to drive on the street that can do 13.5 or 13 flat when tuned right with every bolt on has its benefits.
    I could have gone big turbo when I put in my K04 but the K04 suits my needs and driving style plenty.
    Just another way to look at it.
  16. #496
    May 20 2017
    New Hampshire
    I still canít believe how fast Malone gets back to you...and with a new file ready and everything. 😂
  17. #497
    Jun 21 2015
    CRV
    Akron, OH
    So the oiling ring is a 3 piece design on these rings. Are these definitely the ones you are running? MKV GTI is a confirmed fit for them, so I am sure it will all be fine but just want to be sure.
  18. #498
    Jun 21 2015
    CRV
    Akron, OH
    just build another car to put it in! I have a couple spare blocks.... lol
  19. #499
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~20 Road Bikes, Piper Aztec, Grumman AA1
    Indiana
    panman142 I've been following this since day one. Man, you desserve some kind of award. Greatly admire your determination in the face of so many setbacks. More power to ya!
  20. #500
    Jun 21 2015
    CRV
    Akron, OH
    Quote Originally Posted by Brillo View Post
    Hey thanks! Does that award come with compensation for the thousands of dollars Ive lost? lol! Anyways I appreciate the kind words. Ill be honest, I was very veryyyyy close to saying fuckit and just buying a B8 S4 and being done with this cursed car. All in all this should be the cheaper option, just keep your fingers crossed everything goes well this time.
  21. #501
    Jun 21 2015
    CRV
    Akron, OH
    Hey check it out! B7 base model CF trunk spoiler is now live for purchase.. look at that beautiful car in the pictures....
    https://www.ecstuning.com/b-ecs-part...021809ecs01~a/
  22. #502
    May 20 2017
    New Hampshire
    Panman go fund me account. Iím in for 20.
  23. #503
    Jun 21 2015
    CRV
    Akron, OH
    Yusssss. hahaha. any other takers?
  24. #504
    Feb 10 2012
    parts
    Napanee, ON
    Believe it I can get tune revisions within days, You guys will likely never see a solution.
    I am looking for a boat anchor? Any of these blocks capable of being this for me.... (donít hate mate you gotta break shit to learn right!)
    I canít get into another audipit. 2 trucks, 1 car is enough. A block for a table would be nice weld connecting rods w Pistons 1 on each corner then put a sheet of glass on top. But maybe when I finish lifting, engine/trans swapping, gutting upgrades from truck 1 to truck 2 and completing a bit of a 1 off suspension upgrade (full flex 8-11Ē at shock) on my Sierra with some big old prerunner shocks (king, F-O-A, FOX), Iíll pick up a block to do a table build! It will need some carbon though to lighten it up!
  25. #505
    Nov 21 2014
    Montreal
    That is nice, Iíd buy it if it adds atleast 50hp!
    May as well invest in a turbo kit at that price
  26. #506
    Veteran Member Four Rings klrider44's Avatar
    Aug 20 2014
    Doylestown PA
    Hell yes
  27. #507
    Jun 21 2015
    CRV
    Akron, OH
    Looks pretty similar to one on the first page of this thread...
  28. #508
    Jun 21 2015
    CRV
    Akron, OH
    Block is back. Dropped the head off, many leaking valves but thinking I just got shit on the seats from grinding the quench pads before the cams were out (couple spots were close and I needed to open/close things to check shit) hopefully he takes it apart and nothings bent and just needs cleaned or even seats cleaned up. He (machine shop) said he should get to it Monday for me.
  29. #509
    Jun 21 2015
    CRV
    Akron, OH
    Head is back. Seats just had a bunch of crap on em from grinding the damage out. He took .00025 off to have a nice fresh surface on it. Whole engine is back to the shop as of Wednesday and I should have it back in about a week, which would hopefully be just in time to do a shake down and clean it up to take it to cars and coffee at ECS this Saturday. Hopefully everything works out, getting excited again..
  30. #510
    Jun 21 2015
    CRV
    Akron, OH
    Shop is making progress. Will keep you guys posted on eta for completion
  31. #511
    May 20 2017
    New Hampshire
    I really hope this is the one buddy.
  32. #512
    Jun 21 2015
    CRV
    Akron, OH
    It will be, I have full confidence... for some reason...
  33. #513
    Jun 21 2015
    CRV
    Akron, OH
  34. #514
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Almost there been following this for a long time.. you have more patience than I have.
    Sent from my SM-G935U using Tapatalk
    98.5 A4 1.8T
  35. #515
    May 20 2017
    New Hampshire
    First start tonight or is that happening tomorrow?
  36. #516
    Jun 21 2015
    CRV
    Akron, OH
    He said tomorrow should be ready by around 7.
  37. #517
    Mar 27 2017
    Burke, VA
    Excited for you man
  38. #518
    Jun 21 2015
    CRV
    Akron, OH
    Quote Originally Posted by B7S3wannabi View Post
    Excited for you man
    Iím keeping my fingers crossed. Planning for worst hoping for best at this point lmao
  39. #519
    Jun 21 2015
    CRV
    Akron, OH
    Better pic
  40. #520
    Senior Member Four Rings tloft4's Avatar
    May 15 2016
    Lock Haven, PA
    already have a line on a new head?
    glgl
