Results 41 to 80 of 101
  1. #41
    Jan 24 2013
    Quote Originally Posted by DOCEVG View Post
    For clarity, does an MIL = a CEL? My guess is no. I'm on my first tank of gas (dealer supplied) and have an MIL. Called dealer who, after confirming it was yellow, rather than red, told me not to worry and that it would likely clear itself soon.
    Obviously, am subscribed to thread.
    Yep same thing these days. There used to be a distinction years ago.
    Malfunction Indicator Light = Check Engine Light
    Email: [email protected]
    Call or Text: 914-243-1993
  2. #42
    Established Member Two Rings Krillien's Avatar
    Aug 16 2017
    Calgary, AB
    Quote Originally Posted by skylineguv View Post
    Just got a check engine light on the way home and a quick read with an OBD scanner (would have used ODBEleven, but it's so damned finicky connection wise) came up with the P21F5 code as noted in the diagnostics printout earlier in the thread.
    Guess I'll be harassing the dealership when I get back from site
    Which dealer was working this for you Krillien? Not that it should matter if it's a known issue with Audi Canada.
    Royal oak Audi.
    2018 Mythos Black Audi RS3 (SOLD)
    2019 Nardo Grey Audi RS3
    https://www.instagram.com/yyc_rs3/
  3. #43
    Aug 16 2017
    Calgary, AB
    Quote Originally Posted by fastolsen View Post
    Hi,
    I know there's an update available for this fault codes: P21F500, P218700 and P21F800 all saying something about the fuel mixture too lean/Rich.. Ask Your dealer about a TPI :)
    Hey thanks for the info, I just called my dealer to setup an appointment to see if the update can be applied to my car. Apparently updates like this aren’t available to all countries at the same time. Fingers crossed I can get this fixed though.
  4. #44
    Oct 02 2010
    Calgary, AB
    Quote Originally Posted by Krillien View Post
    Royal oak Audi.
    Who did you deal with there Krillien? I bought my Q7 off Vince Tran and found Royal Oak’s Customer Service to be way better than Glenmore Audi’s.
  5. #45
    Aug 16 2017
    Calgary, AB
    Quote Originally Posted by Ducs_Of_Hazzard View Post
    Yep, Vince is the man! He sold me an S3 and then my RS3. Awesome guy.
  6. #46
    Aug 16 2017
    Calgary, AB
    So I got an update from Royal Oak Audi - Canada does not have the update for fixing fault code P21F500.
  7. #47
    Jan 24 2013
    Did they give any reason for the DTC? Im hoping its strictly a coding/software issue on their end. Has this been addressed with an update outside of Canada ?
  8. #48
    Aug 16 2017
    Calgary, AB
    Quote Originally Posted by allset View Post
    Nothing more than their suspicion that the ECU isn't tuned correctly for north america, and given that I live in a high altitude (Calgary) it could throw AFR off. Nothing concrete.
    It does look like an update is already available in Europe, based on fastolsen's post. Had to look up what TPI(technical product information) meant in North America, which is basically our version of the TSB.
  9. #49
    Jun 29 2015
    I'm hoping this was the cause of the port hold in Germany for the RS3 and TT RS produced in the last couple months. I hope there is a guy running around the lot updating the ECU so they can load my damn car. lol
  10. #50
    Jan 24 2013
    Interesting. I range from sea level to 500 feet and have gotten this dtc several times over 3000 miles. Gah. Well as long as it’s a soft code for now I can deal with it until they sort it out.
  11. #51
    Jan 24 2013
    Going in Friday for P21F5 bank 1 too rich off idle. See if there is a SW update.
  12. #52
    May 10 2017
    Lewisberry PA
    In general they are used interchangeably, however MIL is more accurate since the code could come from the transmission as well. Either way that is a BS answer. At minimum they should scan it so they know what it is. I think this is the first MIL in the US.
    2017 Ara Blue RS3
  13. #53
    May 29 2012
    Evergreen, CO
    Quote Originally Posted by nesbit View Post
    Dunno whether to be crushed or proud. My SA is researching issue; will report back with answer.
    As I live at, and car is at, 7500 feet in elevation, I wonder if that is contributing to issue.
  14. #54
    Aug 16 2017
    Calgary, AB
    At this point my dealer has reset my MIL 3 times already while we're waiting for a proper fix, I'm able to reproduce this code under the following circumstances:
    - sport mode
    - light throttle (<= 20%)
    - approx. 3k rpm
    My drive select is set to individual with all under Dynamic except Steering on Auto.
  15. #55
    Jan 24 2013
    - sport mode
    - approx. 3k rpm
    So your throwing the too rich off idle code with a MIL?
  16. #56
    Jan 24 2013
    I’m rarely over 300 feet and I get the code but no MIL.
  17. #57
    May 10 2017
    Lewisberry PA
    That usually means it's a pending code that will become a full code if the ECU confirms it. If can self clear before causing a live code.
    2017 Ara Blue RS3
  18. #58
    Aug 16 2017
    Calgary, AB
    Yep
  19. #59
    Jan 24 2013
    I did get a MIL once with the code right after I picked the car up. Since then it’s been a soft code.
    I gotta remember to check the fault frequency and reset counter before audi clears it to see what that says as a reference
  20. #60
    Oct 30 2017
    GT4
    Boston/MA
    Sadly my car is at the dealer for mil codes a well, sadly mine even went into limp mode. The dealer is saying fuel pump and it's of course not in stock! They are expecting part availability in 7-10 business days maybe from Germany. However I am still suspecting crap 93 has or they say it's 93. My car has 1034 miles on it.
    Sent from my Pixel 2 XL using Audizine mobile app
  21. #61
    Jan 24 2013
    Quote Originally Posted by anthony0303 View Post
    For fucks sake. We’re you throwing the same too rich off idle code as everyone else?
  22. #62
    Oct 30 2017
    GT4
    Boston/MA
    I actually was lazy and didn't check the codes since the car is so new. I ran into this thread last night
  23. #63
    Jan 24 2013
    Audi will have that info. If you could find out and post when you get her back that would be great.
  24. #64
    Oct 30 2017
    GT4
    Boston/MA
    Sure when I speak to them next. This has me a little irritated since now I'm worried what next and if doing anything to the car will allow them to void the warranty
  25. #65
    Jan 24 2013
    Well it’s not uncommon for there to be issues on a “new” platform. Even though the RS3 is based on MQB the engine revisions on the new 5 are significant.
    The DTC issue could just be a software bug and your bad fuel pump just a faulty part although VAG has a history for shitty fuel pumps. I don’t think there’s any reason to panic yet. Personally I won’t tune a new car until after at least 10,000 miles to give things time to work out. Something new like this maybe longer depending on what others in our community are experiencing.
  26. #66
    Jan 24 2013
    Went to audi. The code cleared itself. They had no info on an update. Wait and see I guess.
    In other news this dealership is looking to tune APR in the next year. This place has been open for a month and I’m told it’s the largest dealership in the country right now. It’s really nice. Super customer focused. Hawthorne audi in Westchester County ny.
  27. #67
    Active Member One Ring jaro12's Avatar
    Nov 06 2017
    2016 BMW M3
    Regina Sask
    Took the Car to Audi dealer for the third time to clear fault code P21F500, (2058 kilometer on the car) this time dealer changed my oil and filter due to fuel in the oil, I wonder if anybody have the same issue, SA claims there was gas odor coming from the oil, this is very troubling gas in the oil, this can be very bad for the motor and the turbo.
  28. #68
    Jan 24 2013
    Quote Originally Posted by jaro12 View Post
    Did they give any possible causes? Rings, bad injector, fuel pressure?
    Gas in oil and too rich code isn’t good.
  29. #69
    Apr 07 2017
    Baltimore, MD
    I'm wondering if one of your injectors failed and is dumping fuel in your cylinder.
    2019 S5 Sportback Prestige
    (SOLD) 2018 RS3 - Daytona Gray Pearl w/ Alu-optics (Tech,Driver-Assist,Dynamic)
  30. #70
    Jan 24 2013
    Quote Originally Posted by BaltimoreCaesar View Post
    Yeah I had an issue on my mk6 gti with the injector being stuck open. It was pretty blatant, misfires and a bunch of codes. Could even smell the gas in the cabin. If this is happening to a less obvious extent here it could be worse if undiagnosed due to thinning engine oil.
  31. #71
    Nov 06 2017
    2016 BMW M3
    Regina Sask
    Car runs good no other coder beside P21F500, dealer run all kind of tests, check spark plugs and cylinder walls for ware no issue there, thy open TAC with Audi and told me to drive the car.
  32. #72
    Jan 24 2013
    Ok that’s good news. Please post any additional info.
  33. #73
    Established Member Two Rings RezaWrex's Avatar
    Apr 21 2017
    Edmonton
    I have the exact same issue. Audi has had the car since yesterday and are saying it's good to go now. They changed oil and filter too saying there was fuel in the oil as well as the too rich trim code. Another Canadian here.
    2018 RS3 - Nardo Grey
    2013 RS5 - Misano Red - Sold
  34. #74
    Nov 06 2017
    2016 BMW M3
    Regina Sask
    Did the dealer open TAC with Audi for your car? This is not normal for all this cars having this kind of issues from new. (Fuel in the oil) I wonder how many other cars with P21F500 code have fuel in the oil.
  35. #75
    Nov 06 2017
    Vancouver
    I would have to see a report of an actual fuel dilution problem before I would be concerned. Sniffing the oil doesn't mean anything. In order for fuel to get into the crankcase, passing all the rings you would have a serious rough running issue and/or serious mechanical problem, which nobody seems to have.
  36. #76
    Oct 02 2017
    ive fueled up my oil in 4mins of free revving on a brand new motor. I was running too rich/too much ignition advance. It's possible to very quickly mess dump fuel into the crank case via idle.
    A secondary check would be to change your oil again after 500 miles or ASAP when the code appears again.
  37. #77
    Nov 06 2017
    Vancouver
    Quote Originally Posted by OE2 View Post
    On a modern fuel injected vehicle, it's really not, unless there is something mechanically broken, which would lead to heaps of other issues depending on what it is.
    Did the tech with the 'smell test' mention if the oil was overfilled?
  38. #78
    Apr 21 2017
    Edmonton
    My dealer did open a case with Audi Canada who is well aware of the issue apparently. My dealer had 2 other cars in at the same time for the same issue (both RS3 and TTRS). They have seen multiple other vehicles with the same issue as well. They say the instructions from Audi Canada are to clear the fault and if it returns they will replace the injectors (1-2 week wait as they have to order from Germany).
  39. #79
    Veteran Member Three Rings IceAero's Avatar
    Apr 27 2012
    Boston MA USA
    I wonder if this will become a TSB.
    It sounds like the type of thing that could effect all of us...
    I'm tempted to run it by the dealer just to see if a pending code is present.
    2017 RS3 | 2022 Q5 TFSI e
  40. #80
    Jan 24 2013
    Quote Originally Posted by IceAero View Post
    Mine cleared last week. Just checked again and now it’s pending.
