Results 1 to 13 of 13
Thread: Key Replacement
    Junior Member Two Rings
    Mar 09 2014
    Key Replacement
    I did some searching but couldn't come across anything definitive.
    I'm looking for an extra keyfob for my b8.5. It has advanced key if that makes any difference.
    Dealer wants about 400 including programming which seems crazy.
    Is it possible to get a key from ebay and then get it programmed? Something like this
    http://www.ebay.com/itm/Keyless-Entr...5ZgiXM&vxp=mtr
    Or what about buying an S4 key from another car and reprogramming it?
    Thanks
    Veteran Member Four Rings DBFL's Avatar
    Jan 01 2016
    2016 S4, 2018 Ford F-150, 2022 Audi SQ5, 1982 Audi Coupe
    Tampa Bay
    Quote Originally Posted by godlyone View Post
    Thanks
    The key can only be programmed by the dealer.
    And the description on that ebay ad says that it wont work with advanced key.
    2016 S4 P+ | 6MT | Sports Diff. | Tech. Package
    S4 Build Thread
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    the price is really not that over priced. Most modern keys are in the$300 range
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Oct 13 2009
    MN
    Theres someone over in Poland who is an audi tech that could probably program it for you - you'll need to purchase a cable off of ebay to do it though (vag com will not work). Not sure what his prices would be though.
    Senior Member Three Rings engineerjet's Avatar
    Aug 02 2013
    Dont intend to revive an old thread but didnt want to start a new one and I have the same issue. I found two options but they dont say wont work with advanced key.
    https://www.ebay.com/itm/AUDI-UNCUT-...ZaIbvr&vxp=mtr
    or
    https://www.keylessentryremotefob.co...k0959754bb.htm
    The part number from ebay is 8k0959754F and the second link is 8k0959754bb. My key says 8k0959754bb so would that work or is there more to it than that?
    Nov 13 2017
    S4, Q5, ST3R
    Washington
    What about Vagtacho? No support for these cars?
    Established Member Two Rings XSKIER's Avatar
    Sep 07 2017
    Michigan
    I tried to add 8k0959754bb from the second link to cart and check out. No go, all it will do is sell me the battery and replacement plan.
    Sent from my SM-G930V using Tapatalk
    Established Member Two Rings Arn560's Avatar
    Aug 10 2015
    Toyota Sequoia SR5, VW Jetta
    Monroe, NJ
    www.labarslockshop.com
    609-894-2429
    2011 B8 S4 Prestige, Ibis White, B & O, Nav, Carista Mods, Sports Differential, Black hide & Alcantara, CF inlays, S4 rubber mats, 19" Peelers, Ziza interior LEDs Lubed with Mobil 1.
    Mar 10 2008
    18 A4, 14 S4
    Colorado
    I apologize for resurrecting an older thread, but how do you tell if you need an advanced key? I'm looking and seeing several on eBay and Amazon, and want to make sure I don't purchase one that won't work. Also, has anyone source the FOB that actually says "S4" on it? I purchased a used S4 and it only had one key.
    Thanks,
    Dub
    Mar 28 2016
    Quote Originally Posted by ColoradoB5 View Post
    Thanks,
    Dub
    Can you unlock the doors by touching the door handle?
    Mar 10 2008
    18 A4, 14 S4
    Colorado
    Yes! That is the advanced key, I assume.
    Mar 28 2016
    Correct.
    Mar 10 2008
    18 A4, 14 S4
    Colorado
    , thanks hilmar2k.
