Results 1 to 15 of 15
    Established Member Two Rings JS4Avant's Avatar
    Dec 01 2014
    Hilo, Hawaii
    Rebuild complete
    Howzit guys, been awhile. My car has been slowly been rebuilt after 2 years... long story but Iíll cut to the chase. My car got its heads redone and piston rings replaced. I had heavy smoke from exhaust from decel. Rebuilt the heads, put back together, still smoking. Teared apart, replaced rings, put backed together. Car is not smoking as much, but still getting a puff of smoke after an aggressive decel. Iíve talked to a few audi shops and they said not to use breaking oil so I have not. Is this something that will resolve itself eventually after some mileage? Your feedback is greatly appreciated!
    Dec 01 2014
    Hilo, Hawaii
    Anyone have some ideas?
    Dec 01 2014
    Hilo, Hawaii
    Bump for ideas, suggestions. Thanks guys
    Dec 10 2013
    Pickering, Ontario, Canada
    Still smoke?
    Sent from my SM-G935W8 using Tapatalk
    03 Allroad 6-spd
    IG: 24_et
    MODS: C5 S6 4.2 Swap, Modified CSF Performance Rad, Dual 14" EFK, 4.11 Swap, 12lb TTV V8 Flywheel, B7 RS4 Clutch, Custom True Dual Exhaust
    RIP:
    Mar 12 2017
    Lincoln
    Did you replace the valve stem seals? What about the actual valve guides, dependant on mileage these could be worn. Did you hone the bores?
    Sent from my SM-G950F using Audizine mobile app
    Dec 01 2014
    Hilo, Hawaii
    Still smoke, took car to matrix integrated . They recommend a new short block. Car is hanged up for awhile till I figure it out. Anyone here live on the big island of Hawaii AVOID, getzinger motorwerks. My heads were from JHM, Hawaii shop said they were defective, BS. They misdiagnosed my car.
    Mar 12 2017
    Lincoln
    Smoke on decel would indicate top end not block. I would go with a head issue from what you have described so you might not want to call BS just yet. New heads could be defective, you need to check, if they replaced guides and seals or just seals. It could be a worn guide, or seal not seated properly.
    Dec 01 2014
    Hilo, Hawaii
    The head were received from JHM. No change once installed. Car was torn down and my old head were rebuilt using new parts and then re-installed again. Smoking less and oil consumption less. Donít see how heads could be bad twice. Upon inspection, spark plugs pulled. Oil on all plugs except cylinder 2. Took the car to work yesterday, still pulls strong and smooth
    Dec 01 2014
    Hilo, Hawaii
    At a lose right now, Iíll be pursuing ahead with a lawsuit. Hopefully it gets resolved.
    Mar 12 2017
    Lincoln
    Pcv system? I see your point about the heads being bad twice. Did you have the bores honed? How have you bedded the rings in?
    Dec 01 2014
    Hilo, Hawaii
    Changed the pcv, still same. Shop did hone cylinders before RE-ringing. Donít think it was done correctly which is why I need a shortblock
    Mar 12 2017
    Lincoln
    Possibly, that would likely show up on a compression test, of not it could be a damaged oil scraper,
    Dec 01 2014
    Hilo, Hawaii
    Thanks for the feedback BGB, Iíll keep posting with results.
    Established Member Two Rings RHawk's Avatar
    Feb 23 2018
    Marion, il
    Wondering if anyone knows a place to get replacement parts, such as rings and head gaskets relatively cheap. I am a tech, but on a budget (just had another kid) and I have the tools to do the job, but no where to purchase reasonably priced parts. Any suggestions?
    Sent from my HTC6535LVW using Audizine mobile app
    Dec 10 2013
    Alu-sil has specific honing techniques that must be used. The bores should remain a dull satin finish in stead of a tradition polished crosshatch.
    You should have also used break in oil, or at the very least conventional for the first 500-1k miles. Changed engine oil and then gone to 2k miles before changing oil again for a synthetic.
    03 Allroad 6-spd
    IG: 24_et
    RIP:
