Results 1 to 6 of 6
    Veteran Member Three Rings ericbull's Avatar
    May 27 2015
    2003 Honda Shadow Spirit 750
    Philadelphia, PA
    CAI for a 3.0???
    I've searched high and low and can't seem to find any vendors who make a CAI for the 3.0 engine. Does anyone know of or run one on their 3.0? Thanks.
    -Eric
    '03 A4 Avant 3.0 Quattro 6spd MT (125k)
    -USP 18x8" wheels, hatch spoiler
    -B6S4 door blades, Alum mirror housings
    -Blauparts rear sport struts
    -TBD...
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    You mean a hot air intake? If you search a little more, no one makes one because the stock air box is already a cold air intake. It pulls air from the front edge of the car, so it won't real get colder than that. Most aftermarket solutions actually increased intake temps.
    Sent from my Pixel XL using Tapatalk
    Dec 01 2011
    Castro Valley/CA/ Bay Area
    Quote Originally Posted by imnuts View Post
    +1, best would be to do the Zingo/Zimbu airbox mod
    http://www.audizine.com/forum/showth...er-removal-3-0
    http://www.audizine.com/forum/showth...s-to-prove-it)
    '05 3.0 Quattro, Q5 Brembo Front Conversion, S4 Rear Brake Conversion, Bilstein PSS9 Coilovers, Milltek Catback Exhaust, RS4 Rear Sway, SPC Front Upper Control Arms, JHM Intake Spacers, Zimbu Intake Mod, Stage 1 ECU Tune.
    Junior Member Two Rings
    Dec 13 2022
    2020 Ram 2500 diesel
    Wa
    I made my own CAI. Sounds good and looks great. Just need to finish the heat shield and I’ll be good to go.69812638307__00EA262A-B8FB-4012-8082-50BD1553FC0C.jpg
    Junior Member One Ring
    Aug 29 2019
    niagara
    How and what did you make that out of? I'm going to be doing similar but I'm very curious How you did the inlet to the manifold!
    Dec 13 2022
    Wa
    So I ditched the factory elbow off the throttle body, and used a 3” 90 degree silicone coupler. The intake tubes I had laying around from previous projects. U will need (2) 3”x3.5” straight reducer hoses for the MAF. And I just went with a K&N Cone filter. I still need to fab up a heat shield to keep temps down further. I run the factory snorkel from the grill to over the filter; works awesome and intake air temps are hardly ever more than 10-15 warmer than ambient while moving.
