Page 4 of 81 FirstFirst ... 234561454 ... LastLast
Results 121 to 160 of 3212
  1. #121
    Stage 2 Banner Advertiser Four Rings Sean@TAG's Avatar
    Jun 27 2014
    Seafox Boat, Jetta, F150, Travel trailer
    San Diego
    Quote Originally Posted by King James View Post
    Any thoughts on Rotiform IND in 19x10 et35 with 255 rubber? Seems a bit on the aggressive side from what I’ve seen.
    Will be lowered a reasonable amount on KW HAS but not really wanting any rubbing. The 8.5 alternative seems the other end as not aggressive enough.
    Here is a setup we ran in a 10" believe it or not. It came out amazing! In fact, this set is for sale at an unheard of price!
    TAG MOTORSPORTS
    (866) 748-4388
    SITE: www.TAGMotorsports.com
    EMAIL: [email protected]
  2. #122
    Registered User Four Rings EmmanueleDesign's Avatar
    Feb 11 2014
    2000 Audi S4, 1995 Audi S6
    Anaheim, CA
    Our B9 S4 with DPE Flowform 20x9.5 ET35. Running a 3mm spacer in front to clear the brake caliper. Lowered on eMMOTION lowering springs.
    https://www.emmanueledesign.com/coll...nt=37478616330
    Sent from my Pixel XL using Tapatalk
  3. #123
    Dec 29 2017
    London
    Quote Originally Posted by Sean@TAG View Post
    Hi thanks for the offer not looking for that style. And they look like 20’s? What tyre size? Any rubbing? What is it lowered with?
  4. #124
    Jun 27 2014
    San Diego
    Got it. Just wanted to show you a 10" width mostly. It is in fact a 20" and it is lowered on KW V3.
    TAG MOTORSPORTS
    (866) 748-4388
  5. #125
    Jul 30 2017
    Memphis tin
    B9 S4 Wheel Gallery
    Lowered on ED springs 19x9.5 ET 38 BCForged RS40 In brushed black with 265/35/19 continental DWS06
  6. #126
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by Joncoulson View Post
    They look fantastic! And those specs are dead-on. I'm 19x9.5 ET40/37 on 265. BC brushed black has changed a lot since I ran BC's on my A5.
    IMG_2010 by Nemesis Autosport, on Flickr
  7. #127
    Jul 30 2017
    Memphis tin
    Thanks they are awesome as the finish is the dark brushed black they offer 2 shades.
  8. #128
    Jul 30 2017
    Memphis tin
  9. #129
    Nice! Have you experienced rubbing with the 265s? Also, are you running spacers with your set up?
  10. #130
    Jul 30 2017
    Memphis tin
    Quote Originally Posted by yumsauce View Post
    Only light rubbing in rear with a passenger some running on passenger front while turning of I hit a bump no spacers these wheels are custom made to my car. Hubcentric and use OEM lugbolts.
  11. #131
    Senior Member Two Rings millerns's Avatar
    Jan 13 2010
    Fitment question for the group... Vossen is having a closeout sale right now and I'm looking at the CVT's in 19x10, offset +55. Square set all the way around, stock suspension with no plans to lower it for quite some time. I'm not familiar enough with offset and if this would poke outside the fenders. Probably would run 255s, possibly 265s.
    Rubbing issues? Bad fit? Anything?
    **Edit: Pretty certain this offset is no good.
    DD: 2018 S4
    SOLD: 2012 Monsoon Gray S-Line A4 2.0T, 19''x 9.5'' Hyper Silver Avant Garde M310; 2004 Nogaro Blue S4, 6-Speed Manual w/ 41k miles.
  12. #132
    Jun 27 2014
    San Diego
    Quote Originally Posted by millerns View Post
    Your real problem here is inboard. It will not clear the suspension components unfortuantely. We can certainly help put with a proper wheel set however!
    TAG MOTORSPORTS
    (866) 748-4388
  13. #133
    Sep 28 2010
    NW NC / DE
    Bumping this guy.
    20x9 ET38 CI-R in satin black, with 3mm front and 5mm rear spacers, wrapped in 255/30 rubbers.
  14. #134
    Dec 29 2017
    London
    ^looks great Mops - the 19" BBS sold yet?
    Any thoughts on Avant Garde M510 19x9.5ET40 clearing the front brakes?
  15. #135
    Veteran Member Four Rings BrockDM's Avatar
    Jan 21 2018
    Orland Park, IL
    Not the prettiest but here is my winter set up. A nice and flush fitment compared to stock.
    Wheels:
    18x9 et 32 - TRmotorsport C4
    Tires:
    245/40/18 - Michelin X-ICE XI3
  16. #136
    Sep 28 2010
    NW NC / DE
    Thanks! Sold them lol. And yes, the 19's sold a couple of weeks ago. They're going on an Ara RS3 😎
    I can certainly find out. Also look at the 19x9.5 V-FF 101 if you want to save some weight. 👊🏻
  17. #137
    Jun 27 2014
    San Diego
    We ran a 20x10 ET40 from AG, and we had to run a 5mm spacer for them to clear (not to mention it did add quite a bit of poke.) That said, I would suggest a 9.5 ET37 for a no hassle fitment.
    TAG MOTORSPORTS
    (866) 748-4388
  18. #138
    May 24 2017
    San Diego, CA
    Some recent S4 Fitments we have done.
    VOSSEN VPS ML-X3 20x10 (For Sale BTW)
    Also, this beauty sitting on 20x10 AG M580 Satin Silver
    TAG MOTORSPORTS
    (866) 748-4388
  19. #139
    Veteran Member Three Rings S4_Pedro's Avatar
    Sep 17 2012
    Union
    Quote Originally Posted by TAGMotorsports View Post
    Damn which grill is that on the lower picture that looks really good!
  20. #140
    Dec 29 2017
    London
    That’d be great 👍🏻
    As in 9.5 ET37 from AG wouldn’t require a spacer?
  21. #141
    Jun 27 2014
    San Diego
    That’d be great 👍🏻
    Correct, no spacer.
    TAG MOTORSPORTS
    (866) 748-4388
  22. #142
    Sep 28 2010
    NW NC / DE
    Just in from AG...
    No they do not, B9 S4 calipers are bigger so you will need 8mm spacer to clear them, and will be aggressive. 👍🏼
  23. #143
    Junior Member Two Rings CT_S4's Avatar
    Jan 29 2018
    Las Vegas, NV
    I have an inquiry; I am debating between two wheels:
    My first option is the HRE FF04 20x9 +25 and will be dropped on HR lowering springs. Basically the set from TAG but does this setup require spacers?
    My other option is to have a custom set built Work Emotiom CR ultimate 2 piece; 20x10 +30-35?. I want to have the deepest concave wheel with no spacers or rubbing issues when lowered. Any insight is greatly appreciated.
  24. #144
    Sep 28 2010
    NW NC / DE
    The 20x9 et25 doesn’t need spacers. In fact that spec forces you to run 245 instead of the optimal 255.
    The CR would be badass.
    Mops On The Move
  25. #145
    Jan 29 2018
    Las Vegas, NV
    Mops On The Move
    What spec for the 20x9 would allow me to run 255? +35?
    And what offset for the CRs? I don’t want to order them and then have issues as it’s a lot of money. ...
  26. #146
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by CT_S4 View Post
    ET30 would. Here is 20x9 ET33 front, ET31 rear.
    For the CR, if you must run 10", you'd be stretching a 255 to get them to work. With a 10", I'd say ET42 is the number. I did a 10" ET42 on a B8 S4, and the customer had to run a 245. Work would have to tell us what the options are. And they would ensure the fit is correct without issue.
    Happy to assist. 👍🏼
  27. #147
    Jan 29 2018
    Las Vegas, NV
    Happy to assist. 👍🏼
    Thanks. For the CR could I run 20x9.5 +35 with 255 tires you think? Thanks for all the help I really want the best drivability with no issues and that concave look.
  28. #148
    Sep 28 2010
    NW NC / DE
    Yep, that is actually the perfect fit I think. I have some 19x9.5 ET35 TE37 coming, and I'll be running 255. Here is 19x9.5 ET32...
  29. #149
    Jan 29 2018
    Las Vegas, NV
    Thank you for the advice. I’m thinking I’m going to go with the CRs as it will be different.
    That setup looks sick btw ^^^^
  30. #150
    Sep 28 2010
    NW NC / DE
    Happy to help! And I fully support going CR :)
  31. #151
    Jan 29 2018
    Las Vegas, NV
    After speaking with Work they recommended 20x9+25 R disk. So I don’t know because I can’t deem to find a picture of the CR2P in that size and similar size doesn’t have much of a concave look to them. So kind of bummed.
  32. #152
    Sep 28 2010
    NW NC / DE
    Did they provide other fit options? Like 9.5 ET35? And they should be able to show you what the profile will look like.
    Any interest in BC? Mine shipped yesterday...
  33. #153
    Jan 29 2018
    Las Vegas, NV
    Those look sick. Hmmmm.
    But I was told no point in going to 9.5 as I couldn’t run the 265 tires and their flicker account I was given has hundreds of photos but couldn’t find the 9.0 R disk in +25 so idk.
    But those look nice how much is a set ?
  34. #154
    Sep 28 2010
    NW NC / DE
    Around $3,200 shipped for 19x9.5 including brushed finishes.
    And I ran 265 on my 9.5 BBS, and I'll be running 265 on this 9.5 ET40. Some simply don't know what they're talking about ;)
  35. #155
    Jan 29 2018
    Las Vegas, NV
    Very interested. I will prob go with these or rs43. What do you recommend as far as fitment and offsets thanks
  36. #156
    Sep 28 2010
    NW NC / DE
    I'll be more than happy to get you set up. And yea, they have several very nice looking monos. And they're extremely lightweight too.
    For fitment, it sounds like you want a full looking tire fitment, and some concave. So 9.5 for sure. 9.5 ET40 is pretty perfect, but you could push it and go ET38 as well.
    Let me know what I can do. And we can take this to [email protected] if you like. 👍🏼
  37. #157
    Jan 13 2010
    Quote Originally Posted by VMRWheels View Post
    No spacers.
    19x8.5 ET35 with 255/35-19 tire!
    I have a set of V710’s from my old B8 A4), 19x9.5 and I believe et40...any chance if you know they’ll clear the front brakes? I like the wheels but not sure they’ll fit with the bigger brakes than the old A4.
  38. #158
    Jan 08 2018
    Melbourne Australia
    My BC Forged 19x9 were manufactured last week. Only issue is my S4 Avant delivery has been delayed two months. Car does not arrive until end of May. It was meant to be next week. Not happy.
  39. #159
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by Mel Bourne View Post
    Very nice! That rear profile looks extra nice :)
  40. #160
    Dec 27 2017
    New York, NY
    I'm looking at a set of AG M510s (19x8.5 +35). Do you guys think it will clear my b9 s4 brakes? All stock
