Page 13 of 21 FirstFirst ... 31112131415 ... LastLast
Results 481 to 520 of 909
Hybrid View
    Senior Member Three Rings akingzkid's Avatar
    Mar 04 2018
    2006 Audi A6 3.2, 2014 Mercedes E350
    Virginia
    Quote Originally Posted by back13a6 View Post
    here are some photos, I can not get the channel 98 to work. I can do the byte 15 no problem.
    - - - Updated - - -
    I attached some photos.
    This sounds silly but I will say it anyway. Are you clicking the "Read" button to the right of it? If not, you need to, if memory serves me correctly.
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    Yes i know traffic sign recognition since my euro car came equiped with it. Wasn't aware this wasn't an availible option for other countries and no idea if the kufatec coding works (afaik the image progressing camera software looks for the white round with red border signs, i suppose in the US it uses different signs but maybe the software can be recoded of opened to other regions and signs). It does work perfect....sadly our country decided to remove all 70km/h signs and one needs to fall back on other signs (leaving 'urban' signs or untill next crossing....). Nice move Belgium (rolls eyes). Luckly GPS info helps the system....
    S6 C7 avant '13 estoril | ceramics | DS1 OTS stage 2 | Lightvan | Milltek non-res X pipe | TS1 | 034 trans-diff mount | CETE ASC-EVC | FL tails & dynamic signals | Thermo ZO catless DP | SRM a2a | BC Forged 20" HCA162S | custom spoiler sideskirts | Maxton front lip & diffuser | Armor heatshield mani-turbo-dp | B&O led tweets (repli) | Forge boost hoses | FIS mmi gauges | R8GT steeringwheel | alcantara interior | SRM inlets | R8 exclusive seats | JXD driveshaft | Tial WG
    Feb 06 2020
    Helsinki / Finland
    Well well, today had some time to play with the coding and my results are following:
    - if i start the car and open the door, i get the nuclear alarm.
    - if i start the car, drive a bit and open the door, there is no alarm (engine running). If i step out of the vehicle, where i previously got the ”key not in vehicle” warning, the engine now shuts down.
    - interior lights work again 👍 This was done earlier but i only noticed it after trying to mute the alarm. Problem was that on OBDeleven, central electrics (09) long coding there is ”Background lightning” and ”interior lightning adaptation”... Interior lightning adaptation (even tho in the MMI its called background lightning) is the ”mood lightning” in the footwells/side panels, and background lightning just kills the interior lights.
    As a added bonus, i due to the magnificent feature of OBDeleven always returning to Byte 0 after programming, i successfully fucked up the long coding in comfort module 🤦 The person who came up with the phrase “If you want something done right, you better do it yourself” didn’t take in to account, that myself is a fucking idiot.
    Sep 07 2010
    Belgium
    Quote Originally Posted by Carl0s View Post
    Strange you still get the beep when you open the door with engine on. Was the car in P or N?
    Always make a backup of your module before making changes or blame yourself later on (i always forget to make backup too tough :p ).
    Hmm afaik my engine doesn't shuts down if i step out adn take keyfob with me, but it does give me the display warning. Might look it up again tomorrow with odb11, something tells me your did that instead of the doorbeep when engine is on...
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Sorry to hear this. Doesn't mean you're an idiot, it's a simple mistake. Although I understand the frustration. Perhaps open your OBDEleven app for the module you edited coding on, and see if it is listed in the history. Perhaps it is there and will fix your problem.
    Quote Originally Posted by Dasquade View Post
    This is one area where VCDS is really helpful IMO. Any time I work on a vehicle I haven't touched before, I run a full scan with VCDS and save the log. This provides the original long coding for every single module in a text file; so if I screw up any coding, I can immediately revert back to stock. OBDEleven has some sort of log to file function, but VCDS is so much simpler for this.
    18 S6
    Feb 06 2020
    Helsinki / Finland
    For the first start (selector at P) it beeps when i open the door. If to drive to local grocery store and throw the stick to P and then open the door, there is no beep and engine runs. Once i step out of the car, the engine dies. In any case if the shift selector is on D i get the roll away warning and bunch of beeps.
    I think its related to long coding Byte 0. After modifying the byte 98 it jumped to Byte 0, and i tried the above “enable bits 0 to 3”. I memorized the original configuration, but when after swiping “write” and realizing that I’m working on Byte 0 i paniced and forgot the original configuration.
    In OBDeleven for IOS there is no backups or history. At first inscreenshotted the chamges, untill i realized that in coding / adaptation it wouldn’t show you the control module. Them you have 20 screenshots and no way to distinguish which is from what module...
    Most of the times, you can just counter do your steps, but if you are in byte 0 when you think you are still in 98 things get nasty.
    Btw, i noticed that in some of the modules, in adaptation there is function “Perform factory reset”. Anyone ever tried what it does? Return the original long coding / adaptations or?
    Jul 13 2017
    Ontario/ON/Canada
    NEW: VagCom VCDS Mod List for C7-C7.5
    Anybody figure out yet how to get the spoiler to come up at lower speed vs manual operation?
    Sep 07 2010
    Belgium
    Quote Originally Posted by S7 North.Style View Post
    No idea (no spoiler here)...but maybe it is ECU controled since it is speedo related? If so, maybe DS1 can unlock the 'spoiler' table and let you adjust it?
    *wild guess, since i noticed exhaust flaps can be adjusted in the DS1 tables (unless it are other flaps).
    Veteran Member Four Rings esemes's Avatar
    Jul 02 2019
    whirlpool cabrio washer and dryer
    clearwater florida
    Ive asked on this (Audi Doc) and the results are buried in code, if even readable in english. changing to kph units would achieve this?
    gotta be possible to set the threshold to the units that give you what you want.
    2016 S6 - sport - optx- atlas - AE nardo
    Sep 07 2010
    Belgium
    Quote Originally Posted by esemes View Post
    Meh, speculation on my side, but i assume it is bit simular to the exhaust flaps but instead of RMPS regulated by speed of vehicle. You might want to contact John Banks from Dyno spectrum, if he has a free moment, if he can find any folder linked too the spoiler. It is a wild guess, but if so...an other reason to consider getting DS1 :p.
    Feb 06 2020
    Helsinki / Finland
    Quote Originally Posted by Audisthesia View Post
    In iOS the history only shows errors and one-click-app changes:
    https://share.icloud.com/photos/002LIm1YqJ1strTdDVjA_tQUQ
    And in control module coding / adaptation there is nothing to indicate what module you’re working on:
    https://share.icloud.com/photos/0oJNXhveTzWCaiI_ytMKk8xrg
    Don’t get me wrong! I love the app. And i fully acknowledge that it’s still work in progress. But, i also can’t do nothing about my hasty behavior that can’t wait 5secs to write changes down before committing them :)
    Aug 14 2019
    Tampa
    Random unknown feature enabled.
    18 S6
    Jul 02 2019
    clearwater florida
    your batt looks like its covid'd...
    Sep 07 2010
    Belgium
    Got any more info...like how you enable this (coding), where can it be found (looks under car systems) and maybe most important what is it :p.
    Looks like battery charge volume?
    *planned to include battery charge status/volume on my FIS mmi screen as i find it often a must known item when working on the car that involves ignition on.
    Aug 14 2019
    Tampa
    I don't have a clue what it is. Sounds like a charge timer for e-tron.
    5F
    Adaptation
    Channel 60B - Car functions adaptations gen 2 - menu display battery management
    18 S6
    Sep 07 2010
    Belgium
    Quote Originally Posted by Gunmeister View Post
    I know my original coding I took a picture of before and after I ain't no chump lol. Anyone who performed the VCDS change that makes the buzzing noise go away should check and make sure this didn't happen to them. I honestly don't think it's that big of a deal.
    2016 A6 TDI*|*Mugello Blue, Pearl Effect Exterior | Alabastar White Interior | Audi Exclusive Line | Eucalyptus Natural Wood Decorative Inlays | Prestige Package | Comfort Seating Package | Driver Assistance Package | S Line Sport Package | 20" Black Optic Package | Cold Weather Package | Audi All Weather Mats*| 18% Ceramic Film Windows | 70% Ceramic Film Windshield | Thinkware Q800 Pro Dash Cam | iDatastart VWX CMVWXA0 Remote Start*| Auto Hold Activated | ESCORT Radar Max 360c*| 1 of 1 for 2016
    Hmm will check aswell this afternoon about the auto-lock.
    Feb 06 2020
    Helsinki / Finland
    Well, i can confirm that it doesn’t automatically lock 👍
    Could this locking have something to do with the automatic re-locking that occurs if the doors are get unlocked, but no door is opened within 30 seconds?
    Btw, could someone whit similar options vehicle share their Comfort module long coding from Byte 0 ? I'm having this DTC in Central electronics "Comfort system central control module 2 - No signal/Communication" that I think came from me fucking up the coding in Byte 0.
    I have low spec vehcile:
    - 2015 Avant
    - Low RMC
    - 2.0 TDI S-tronic
    - FWD
    - Electric sport seats (driver side with memory)
    - Electric tailgate
    And thats about it. No Matrix Led, HUD or anything fancy....
    Sep 07 2010
    Belgium
    Here my car also doesn't lock automaticly...
    S6C7 avant 2013.
    I was not able to alter the long coding byte 15 bite 0 but i dought this is auto lock feature.
    In a way i'm interested to know where the auto lock feature is, at least that is if we could only auto lock if keys aren't in the car!
    Veteran Member Three Rings Gunmeister's Avatar
    Feb 03 2019
    Spokane, WA
    Well I'm glad you guys aren't experiencing this auto lock thing. Anyone with a c7.5 have this issue?
    2016 A6 TDI | Mugello Blue, Pearl Effect Exterior | Alabastar White Interior | Audi Exclusive Line | Eucalyptus Natural Wood Decorative Inlays | Prestige Package | Comfort Seating Package | Driver Assistance Package | S Line Sport Package | 20" Black Optic Package | Cold Weather Package | 18% Ceramic Film Windows | 70% Ceramic Film Windshield | Thinkware Q800 Pro Dash Cam | Audi All Weather Mats |1 of 1 for 2016|
    Aug 14 2019
    Tampa
    AFAIK standard VAG behavior for auto locking is as follows..
    If you unlock the vehicle but do not open any doors, it will relock after a time period. I can confirm this behavior on 2012 Passat, 2017 Passat, 2018 S6, and 2016 A6.
    It behaves in this manner as a safety feature. In case you unknowingly unlock the vehicle with the fob (like you sat on it in your pocket) but never open the door (because you sat on it and weren't getting into the vehicle), it auto relock.
    18 S6
    Aug 24 2014
    Newport Beach, CA
    ^ Can confirm the unlock but not opening doors triggers it to lock again. However, if a door was opened or I leave the car unlocked after driving, it does not lock itself until I lock it. This is a C7.5.
    2024 M3 Comp xDrive
    Mar 24 2015
    Arizona
    Quote Originally Posted by christianb5s4 View Post
    I've actually wondered this same thing. If I drive my car, park it and walk away, I would think it would auto-lock after some set increment of time (was 30sec/adjustable on my Jeep I believe?).
    2017 Audi S6 Prestige
    Aug 14 2019
    Tampa
    Correct.
    Quote Originally Posted by TechSavvy View Post
    Yeah, would be nice if VW/Audi did that.
    18 S6
    Feb 03 2019
    Spokane, WA
    I can confirm if I open a door or leave the car unlocked it will lock itself within minutes. It didn't happen until this change. Even if I leave the key in the car.
    First change made the buzzing noise mute when ignition is on.
    Second change made buzzing noise mute when driver door is open car is on and in park
    I dunno what would be different that mine does this.
    Senior Member Three Rings Welterweight's Avatar
    Sep 22 2017
    Boston
    Ok rookie question. Just unpacked my Ross Tech V2. I had my Check Engine light pop on yesterday and was hoping I could see what the issue was and potentially clear the code. Is this possible? I was able to do this easily with my Cobb Tuner on my BMW. Also do I need to purchase software from Ross Tech on top of the cable? Thanks and sorry for dumb questions
    14’ Black S6
    Aug 14 2019
    Tampa
    Quote Originally Posted by Welterweight View Post
    14’ Black S6
    The software is a free download.
    First run a full scan and save the results to file. Trust me. DO THIS FIRST. That way you have all of your original codings.
    The full scan will also show you all the faults.
    18 S6
    Sep 22 2017
    Boston
    Thank you!!!!
    14’ Black S6
    Feb 03 2019
    Spokane, WA
    Last night when I got in my car the seat moved like I had adjusted it but I didn't. Now it doesn't auto lock anymore. So maybe my car was glitching out but worked itself out lol.
    When I bought my cable from Rosstech they had options to buy the software with the cord mine was for 3 vins. You should look at see what you purchased. But yes you can check engine codes with it.
    Senior Member Three Rings Nosferatu's Avatar
    Aug 19 2019
    C7.5 RS7 Performance, McLaren 720S Spider, Tesla Model S Plaid
    Tampa, FL
    Stupid question, when I take the car in for yearly service (I have Audi Care from previous owner) will anything they update to ECU during their service alter or delete the adaptations that were set via VCDS/OBDEleven?
    2018 Audi RS7 Performance in Mythos Black with DS1 Stage 1, Milltek (non-resonated) Catback, Uniden R7 Blendmount, Viofo A129 Duo
    10.8 @ 128.7 MPH
    Other Toys:
    2019 McLaren 720S Performance Spider Keeping the ICE dream alive!
    2021 Tesla Model S PLAID the Silent ICE killer
    9.33 @ 150.2 MPH
    Established Member Two Rings Four rings fan's Avatar
    Sep 10 2016
    Florida
    I've had three Audi's and the dealer has never reset or mentioned anything about my VCDS/OBD11 mods. All my cars were there either for general maintenance, TSB fixes and minor warranty work (A4 trunk would open in heavy rain, S6 fuel door actuator failed and a trans software update to my A5). Your safe unless your a complete dick to the service dept.
    2018 S6 Mythos Black Prestige
    Aug 14 2019
    Tampa
    Quote Originally Posted by Nosferatu View Post
    Only if you modded the ECU. Which unless you have a tune, pretty sure that's a no. But, if you're super paranoid, run a full vcds scan and save to file before taking in, then run another full scan when it comes back and comapre.
    18 S6
    Aug 19 2019
    Tampa, FL
    Okay thanks. Yeah I'm on stock ECU. Just curious because I bought the car in August, did the yearly maintenance, did all the VCDS/OBDEleven stuff once I got the car back, and it's coming up soon for it's yearly maintenance again and just trying to plan ahead.
    10.8 @ 128.7 MPH
    Other Toys:
    9.33 @ 150.2 MPH
    Jul 02 2019
    clearwater florida
    my only add to this is that all the VCDS customization that Audisthesia performed on my car lasted the APR stage 2 ECU tune and their TCU tune.
    Aug 14 2019
    Tampa
    Yeah, each mod is in specific modules. any ECU tune or updates shouldn't affect any mods folks do as we aren't doing anything in the ECU.
    18 S6
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Please let me know which post # gives the link to the most recent list of VCDS mods. The links at the start of this thread no longer work. Thanks.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Aug 14 2019
    Tampa
    Quote Originally Posted by Alabama View Post
    Try THIS
    18 S6
    Jul 02 2019
    clearwater florida
    Try THIS
    has the door chime mute been successful, and if so, hook me up!!??
    Veteran Member Three Rings MTV10's Avatar
    Apr 29 2020
    Montreal
    Anybody know how to code to achieve ESC OFF on a 2018 S6???
    Sep 07 2010
    Belgium
    Quote Originally Posted by MTV10 View Post
    Not sure if you could code it out, but if you really want it out...
    You could make a small T harnass that plugs into the ESP button. It contains 6 wires, the purple/brown wire you need to make a split wire and if you short feed that with +12V it will trigger the esp button and disable esp. Basicly you could install an "one pulse relais" (if that exists) on the ignintion fuse so it triggers the esp button every time you start the car. It would still allow you to manually turn esp on in that way.
    Don't know why you would want to do this as ESP is a safety feature and in most case i'm glad i have it.
    WhatsApp Image 2020-06-05 at 22.49.33.jpgWhatsApp Image 2020-06-05 at 22.50.20.jpg
    *Warning: do not put - ground on it, well you can but then you will blow a fuse (don't ask how i know :p) at least my r8 wheel now has working flaps...
    Apr 29 2020
    Montreal
    Hmmm, interesting. When I press the button it only goes into 'Sport' mode. Holding it for 5+ seconds does not turn it off like the pre-2015 C7 S6's....
    Will this method simply put it in 'Sport'? Or turn it off completely?
