Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 137
  1. #81
    Junior Member One Ring Jeong Seongshin's Avatar
    Feb 09 2021
    BUSAN
    The a6 c7 2016 2.0TDI Premium has the same stock calipers as the Q5 345mm caliper Brembo 4p.
    S.Korea A6 C6.5 3.0TFSI 2011y.
    JHMotosports Inlet Hose, Silicone, High-Flow .179mm Crank Pulley+57.06mm.
    (Expected)93Octan.Stage2 JHM (POWER CONNECT) ECU-TCU Flashing .
  2. #82
    May 09 2012
    Virginia
    Quote Originally Posted by fat View Post
    So the mill requirement is 4 mm @ the inside of caliper mounts.
    Few pics of the build I could find:
    Attachment 248711
    Attachment 248712
    Attachment 248713
    Attachment 248714
    Attachment 248715
    Attachment 248716
    Attachment 248717
    Attachment 248718
    Fab table notes:
    Attachment 248720
    Attachment 248721
    Will follow up with more specs shortly.
    Nice! OE A6 rotors (or at least same specs)?
  3. #83
    Established Member Two Rings fat's Avatar
    May 18 2018
    Raleigh NC
    OEM brake upgrade for 3.0T?
    Few of the pieces to make this work successfully.
    Calipers were off an ‘10 Q7, same can be sourced from the Cayenne
    Mount tabs have been milled 4mm at inside (Hamiltons)
    I media blasted and acid washed the calipers, then rebuilt the pistons
    Mounting hardware was 10.9 that I got frozen a local supplier. (Wilders - if you’re in Raleigh)
    Bolts were M14x45mm, w locknuts and washers.
    Sleeves are a M14-M16 x 15mm, these are sleeve bearings also called oilless bushings.
    Once bolted up, I trimmed the rotor shields a bit, rolled the edges and sanded smooth before some black spray.
    Pads I used a stock Brembo 17z ,I had to repurpose my ABS connectors.
    Brake lines are StopTech RS4 B7 they fit without any issues.
    Speed bleeders
    Rotors are A6 C6 347x30 Brembo’s
    Flush and fluids with Pentosine LV
    Bleed severe times, overall a noticeable improvement in stopping performance.
    Will need to find a Ceramic 17z pad option as the current pads give off a heavy dusting.
    These detail the parts to make this work:
    ‘11 A6 prestige - stg2+ cts DP/3.141, d/O methanol, milltek axleback - Brembo 18z BBK - eibach 50/40, koni yellow, h&r sway, S6 20’s - flat bottom, black out, dual camera @vornebrakingsystems
  4. #84
    Jul 27 2018
    2010 Audi A6 Avant 3.0T
    Coquitlam, BC
    Looks great, nice write-up :D
    Thanks for all the details
    Speed bleeders
  5. #85
    Oct 26 2021
    Burr Ridge Illinois
    So if I have a 2011 A6 C6.5 with stock 18 inch wheels, all I need is to get the Q5 calipers and brake lines? Will I need a different set of front pads?
  6. #86
    Veteran Member Three Rings DC Dawg's Avatar
    Dec 31 2018
    Chevy Chase MD
    Quote Originally Posted by grana95 View Post
    Yes pads match the calipers so you will need Q5 calipers or Macan Calipers with one will work. And your rotors are the stock 347mm C6 rotors.
    My parts list for reference.
    Rotors:
    **use stock size 347mm rotors for C6
    https://www.buybrakes.com/stoptech-1...-slotted-rotor
    Pads:
    **pads are for a Macan with 345mm rotors
    https://www.buybrakes.com/stoptech-3...-with-hardware
    Lines:
    **Lines are for a B8 Audi Q5 3.0T
    https://www.ecstuning.com/b-stoptech...950.33016~stp/
    Calipers
    **2015 Porsche Macan with 4 Piston calipers and 345mm rotors
    https://www.harperautoparts.com/oem-...per-95b615123f
    https://www.harperautoparts.com/oem-...per-95b615124f
    2009 A6 Avant 3.0T | Garnet Red / Black (1 of 9 in the US) Prestige | Cold
    EPL Stage 1 | Custom Exhaust w/ Quad Tips | ST Coilovers | H&R RSB | OEM 20" SQ5 Peelers | Porsche Macan Brakes | Roc-Euro | RS6ish Grill | C7 Shifter | EBay Puddle Lights | Euro Corner Markers | Ebay S6 Rear Valence | "AJ" Chrome Delete | OEM S6 seats | OEM S6 Door Blades | OEM S6 Grab Handles | OEM S6 Euro Sun Visors
  7. #87
    Oct 26 2021
    Burr Ridge Illinois
    Awesome I was able to source 2011 Q5 calipers for $85 per side. ill go and order lines and get that installed eventually
  8. #88
    Dec 31 2018
    Chevy Chase MD
    Good deal !
  9. #89
    Oct 26 2021
    Burr Ridge Illinois
    Was there a non brembo option on the Q5? Not too sure if I got the correct ones now since there wasn’t photos up or a description. I assumed a 2011 Q5 was all I needed.
  10. #90
    Jul 27 2018
    Coquitlam, BC
    I think so; i was also looking up q5 calipers and most of the cheap ones i found on ebay looked like they only had the one big piston.
    Somebody would have to confirm exactly.
  11. #91
    Dec 31 2018
    Chevy Chase MD
    For the 2.0T Q5 there is also 320mm rotor , those are not the Brembo calipers. 2011 I think was the 1st year of the 2.0T - you want 3.0T brakes I’m pretty sure.
  12. #92
    Oct 26 2021
    Burr Ridge Illinois
    The ones i ordered from Ebay were 4 piston brembo q5 calipers but were off the 2.0T saying 320mm? I wasn't aware that there was a different setup for the 2.0 and 3.0.
    Part numbers: 8R0-615-106-BN
    :8R0-615-105-BN
  13. #93
    May 09 2012
    Virginia
    :8R0-615-105-BN
    There are different part numbers. You will most certainly need the calipers from a 3.0T Q5. Part numbers below.
    8R0615108G
    8R0615107G
  14. #94
    Veteran Member Three Rings a1dan_87's Avatar
    Mar 07 2018
    Utah
    It has to be from a 2016+ Q5 3.0T if I remember correctly
    Sent from my PH-1 using Audizine Forum mobile app
  15. #95
    Oct 26 2021
    Burr Ridge Illinois
    So I finally got around to installing the calipers only to find out that they do not fit. They are the brembo calipers but the label did say from a 2.0T. What is the year make model that will have the correct crossover as well as the part number?
    Do you guys think that if I remove the dust sheilds it will have clearance? or are these calipers useless at this point?
  16. #96
    Oct 26 2021
    Burr Ridge Illinois
    Audi calipers VS Porsche caliper
    I was looking at OEM cost on calipers and am surprised to see such a huge difference in price. Any one have any ideas why this may be?
  17. #97
    May 09 2012
    Virginia
    Quote Originally Posted by jbain2 View Post
    8R0615108G
    8R0615107G
    See my post above. Those are the part numbers for the calipers from the Q5 with the 3.0T. The calipers from the 2.0T will not fit and even if they did, the rotors are also smaller than the stock rotors on the A6.
  18. #98
    Oct 26 2021
    Burr Ridge Illinois
    Will the Porsche ones fit? Because they are a fraction of the cost
  19. #99
    Dec 31 2018
    Chevy Chase MD
    Yes. I gave you the entire parts list about 10 posts above. My recommendation is you follow that.
  20. #100
    Oct 26 2021
    Burr Ridge Illinois
    Quote Originally Posted by DC Dawg View Post
    Will I need to remove the dust shields?
  21. #101
    Dec 31 2018
    Chevy Chase MD
    Yeah you can trim them to fit if you want but I didn’t bother
  22. #102
    Oct 26 2021
    Burr Ridge Illinois
    Brake pads
    What’s the difference between
    95B-698-151-H
    95B-698-151-G
    The only difference I saw is that one says 17 and other says 18.
  23. #103
    Feb 09 2021
    BUSAN
    I have a question. Are there any points to note when installing the brake line?
  24. #104
    Dec 31 2018
    Chevy Chase MD
    Brake pads
    95B-698-151-H
    95B-698-151-G
    Almost positive they are same, as long as they are macan pads for 350mm rotors you are good.
  25. #105
    Jan 07 2022
    Sofia/Bulgaria
    Hello everyone!
    I am looking for brake calipers from Audi Q5/Porsche Macan 345mm, 4 pot Brembo, but they are extremely rare. So I found that calipers with the same OE numbers 8R0 615 108(107)G are mounted in Audi A7 2015-2018 Sportback. I may be able to get those from an Audi A7. I just have to be sure that 17" wheels 7,5J ET28 will fit! Everything will be mounted in Audi A6 C6 2010 3.0TDI with 347mm OE brakes. Is there anyone with similar set?
  26. #106
    Jul 27 2018
    Coquitlam, BC
    I was under the impression that they wouldn't fit over 17" since I figure the caliper body is bigger... but i have no facts to back that up...
    Hopefully somebody can drop some facts and clarify.
    If they do fit then I can upgrade my brakes sooner; since they will work for my 17" winters :P
    EDIT: kingDL ? i think on the first page said he will test with his 17" winters. dont know if he ever got to it.
    Quote Originally Posted by Gangbango View Post
    Hello everyone!
  27. #107
    Jan 07 2022
    Sofia/Bulgaria
    I will give some info today, because I am going to measure all dimensions needed from the 4pot calipers and compare them with OE calipers of A6 C6 3.0TDI 2010.
  28. #108
    Jan 07 2022
    Sofia/Bulgaria
    Unfortunately, the calipers were taken from Audi A7, but the 320mm version. So if I want them, I have two options - downgrading from 347mm to 320mm rotors, or adding a custom steel bracket with new caliper mounting points. I am not sure about either. Still, I took some dimensions which have importance to the fitment of my 17" winter wheels. I measured 60mm +-2mm from outer face of brake disk to caliper's face and 110mm +-2mm from the caliper's mounting axis to it's outer edge. I think it can be useful to someone.
  29. #109
    Dec 31 2018
    Chevy Chase MD
    Hello everyone!
    They arent the least bit rare. The link to buy them new has been posted multiple times.
  30. #110
    Jan 07 2022
    Sofia/Bulgaria
    Found the calipers I was looking for. From Q5 8R 3.0TDI Quattro. OEN 8R0615105(106)CA. I swapped the calipers just to see if everything is OK. The brake rotor is OEM 347mm for A6 C6. Those wheels are 17" from Audi A5 - 7,5J ET28. There is enough space between the caliper and the wheel.
  31. #111
    Jul 27 2018
    Coquitlam, BC
    is that a 4 pot?
    i would've thought the outside 2 pistons would be more distinct looking in the caliper housing.
  32. #112
    Jan 07 2022
    Sofia/Bulgaria
    Yes, it is a 4 pot Brembo caliper. The pistons are only visible on the back of the housing. The front is very simple and does not have the aggressive Brembo style. I am impressed by the caliper's weight. Much much lighter than the OE A6 C6 347mm calipers.
  33. #113
    May 14 2011
    A bunch of strollers, bicycles and other kid's stuff...
    Ottawa
    Bumping this thread because there’s lots of good info (and many people asking the same question over again).
    Question for you 3.0t guys: what are you doing in the rear for upgrades? I may have bought an avant that needs rear brakes and lines, so I’m thinking I might as well upgrade. The front Q5/Macan calipers are definitely also on my list.
    Thanks to [mention]DC Dawg [/mention] for posting the PNs!
    __________________________________________________ __________________________________________________ ___________________
    13 Ibis White Q5 3.0T - Kid hauler
    06 Quartz Grey B7 A4 3.2 Avant - Work truck
    17 Midnight Blue Golf Alltrack - Wife mobile
  34. #114
    Oct 04 2018
    Europe
    Rear disks are 330mm the same size is for S6 which has 385mm for the front.
    Therefore I would say that rears can stay. I personally put in front 390mm rotors (from AP Racing) and 6 pot brake calipers from RS6 C6. After ~ 15000 km no issues.
    For the rears I've changed the lines with metal ones from HEL. Rotors and pads are OEM.
    Anyway if you would like to upgrade the rear you have to get RS6 C6 (can't confirm if they will fit) rotor size is 356mm but the price including rotors is insane.
    Even more you have to import the brake calipers from UK or Europe since RS6 C6 wasn't available in north America.
  35. #115
    May 14 2011
    Ottawa
    Quote Originally Posted by PPETKOV View Post
    Do you (or anyone) know if the rears are the same as the C7s, also 330mm?
  36. #116
    Oct 04 2018
    Europe
    Quick answer: No they are different.
    The overall height of the rotors is different:
    C7 330x22mm overall height 36mm
    C6 330x22mm overall height 49.4mm
  37. #117
    May 14 2011
    Ottawa
    - thanks for the info!
  38. #118
    Apr 11 2022
    UK
    I have an A6 C6 2.0 tdi 170. I’ve come across C6 S6 brakes for cheap. I’ve read I’d need bigger spindles to accommodate, what is a spindle? Is it the wheel bearing hub or the arm which takes the hub and why do I need it?
    Thank you,
    Any information would be much appreciated.
    Kind regards,
    J.
  39. #119
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    The S6 rears are not 330mm they are 356mm. I’m not sure where that information came from. I have them on my b8.5 S4
  40. #120
    Jul 02 2004
    FL
