Hello Barry!!!
First of all I want to thank you for your B6 & B7 Android Google Nexus 7 2013 Tablet Install Guide, I’m working on this right now.
I’m no expert in this but want to give it a try and have a tablet as head Unit and keep the rest of the Bose system but I have a few questions that hopefully you can help me with…. here I go:
1. RADIO INTERFACE. Whats the function of this? is it possible to use only the cable adapter (without the interface)??
2. DAC. Is the audio from the tablet sent using the USB port in it?? Does this works as a mixer to receive all the inputs (BT, FM, TAB) and send them to the stock amp?
3. If #2 is true, is that the reason we need a Volume control interface??
4. I have read that there is an issue with signal level and/or ground sent to the stock amp. Does DAC solve this issue?? or does the radio interface do it??
I really appreciate any help and thank you in advance. (sorry for my bad english)
Best regards.
Mauricio
