Results 1 to 16 of 16
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    Fan control module
    Does the fan control module control both fans? Im trying to find what component would cause both fans to be inop at high temp and with the ac on. Just started to day both electric fans wont come on tested all the fuses under the dash.. there is power going to fan wires next to power steering res. Also old posts aren't very helpful in finsing the relays for these fans, are there two different ones?
    Sent from my SM-G920V using Tapatalk
    Veteran Member Four Rings Cgoon009's Avatar
    Mar 02 2013
    I have a garage? Do tell...
    DC
    Quote Originally Posted by cjt671 View Post
    if by both fans you mean the two electric ones, then yes. the FCM powers both
    Eurosport Tuning at it's Finest
    Dec 14 2014
    PNW
    Quote Originally Posted by Cgoon009 View Post
    Yes electric ones.. is that the only component tied to power both the fans? Or is the relay for power of the control module too. Just jumped both fans to the battery and the both work. Do you know of a way to test fan module?
    Dec 14 2014
    PNW
    I got around 10 volts coming from the wiring that comes from the fan module.. is that normal
    Mar 02 2013
    DC
    which wires? you should have a power supply plug and a control plug. then you should have two out put plugs for power.
    If you FCM isnt bad, then it may be a relay or sensor. But my money is on the FCM.
    - - - Updated - - -
    that seems odd. you aren't using a auto ranging meter are you?
    Dec 14 2014
    PNW
    - - - Updated - - -
    Brown and black connectors coming off the fcm
    Ill double check, it isn't an auto ranging meter.
    Dec 14 2014
    PNW
    I tested what I believe tp be the fan relay and its good so I guess fcm it is
    Mar 02 2013
    DC
    http://www.audizine.com/forum/showth...-so-I-did-this
    checkout that diagram first. worth poking shit a bit since its free.
    Go with a unit from FCP Euro, it may be a few dollars more, but they will replace it whenever no questions asked. I get all my sensors and other electrical parts from them so they are covered.
    Dec 14 2014
    PNW
    Did enough troubleshooting I believe to point me towards fcm. But you will not fucking believe this..
    I just ordered the fcm from europa parts, went to move the car to put it on ramps to pull old one off and both fans kicked on and off woth the ac like they should lmfao gonna let the car get up to temp to make sure they come on with hot coolant too. This is insane lol
    Veteran Member Four Rings Meow's Avatar
    Mar 08 2012
    MI
    FYI there are three fans :)
    Pusher out front too!
    RIP Daz, you will be missed.
    Dec 14 2014
    PNW
    Quote Originally Posted by Meow View Post
    My concerns are the oem electric fans, ive got an aftermarket efk in place of the clutch fan
    Dec 14 2014
    PNW
    One thing I did do was jump what I believe was the fan relay, heard it click and assumed it was good, so I ended up ordering the fcm..
    Mar 02 2013
    DC
    yeah if they came on, I would re check the relay. Thats pretty funny
    Dec 14 2014
    PNW
    I wonder if its intermittent.. I think Im gonna hold off on the fcm and if it does it again swap relays
    Apr 04 2007
    2001.5 S4 Stage 3+, 2001.5 A4, 2000 Porsche Boxster S, 1969 MG CGT, 1974 MG Midget
    Orlando, Florida
    You need to check the output from the FCM with an osciliscope. The FCM outputs a variable square wave. I had a fan that would work intermittently in the car but worked great with 12V, figured shit the fan is good and bought a used FCM. Same thing happened with the replacement FCM. Got pissed and did more research and finally broke out the oscilliscope. Sure enought both controllers were good. Replaced the fan and haven't had an issue since then.
    Dec 14 2014
    PNW
    Appears FCM was the culprit this time, fans are working as they should. Thanks fellas
