Results 1 to 13 of 13
    Veteran Member Three Rings Strong Man's Avatar
    Jan 24 2017
    Steering issue - need help ASAP
    Hi Guys, I need your help ASAP
    Yesterday аfter the rain I took my son for a fun ride through the puddles.
    Today I've noticed the steering wheel has started to work much harder.
    It isn't hard in full cycle. When wheels are straight and I start to turn it's hard after small change it's become normal... continue and it's hard again. Like waves. No vibrations during driving, no noses.
    No leaks, vag-com - no codes.
    What should I look into ?
    2013 Audi S5 3.0T: Custom Audison with B&O, Quattro Sport Differential, ADS, 7-speed dual-clutch DL501
    Mods: ||ST2: Unitronic ECU + TCU + Ported SC & Throttle||Intake: ESC Kohlefaser Luft ||Exhaust: AWE Touring with Resonated DPs 102mm tips||Susp:CR15, Alu K, H&R OE, H&R R Sway Bar, ECS Drv Mnt Insert Kit ||H&R Spacers: 15F/20R || Brakes: ECS SS Lines, StopTech BBK Creo Slott Rotors F/R, HAWK 5.0 F/R, Motul 600 || etc.
    Veteran Member Three Rings Dnovakovic04's Avatar
    Feb 02 2016
    Thousand Oaks, CA
    "Like wives" Hahahaha
    I think you're good, wouldn't worry.
    2016 Glacier White SQ5 Prestige
    - AWE Touring Exhaust - IE Stage 2 Single Pulley - Roc Euro Intake - 034 Trans Mount - Alu Kreuz -
    Jan 24 2017
    Sorry for typo...fixed
    Feb 02 2016
    Thousand Oaks, CA
    Made more sense with the "wives" comment.
    Jan 24 2017
    Guys, any ideas?!
    Apr 30 2014
    Phoenix, AZ
    Did you get mud in your belly pan? Maybe something got wedged in there, I would check underneath and rule it out.
    Jan 24 2017
    Thank you for everyone. I found a core of the problem and fixed.
    Happy End :)))
    Veteran Member Three Rings chopz33's Avatar
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    Quote Originally Posted by Strong Man View Post
    Happy End :)))
    What was it
    2012 S4/ Prestige/ Black Optics Package/DSG/Red Leather/B&O sound
    KW HAS/RS4 grille/LED conversion/USP Intake/AWE Touring-resonated DP's/034 trans mount/Niche Stacatto 20x9/CF Stvbek front lip/Unitronic Stage 2 ECU/TCU/ECS CF diffuser/CR-15 Strut brace
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Quote Originally Posted by chopz33 View Post
    What was it
    Ditto! What was the fix?
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Jan 24 2017
    It was steering shaft joint under a car (not in a cabin). Cleaned with WD40 greased with Motul grease.
    Jul 18 2010
    NE Ohio
    Was it the universal joint at the bottom of the steering column's intermediate shaft that you cleaned and lubed? (Part # 6 in this pic) ...
    I just had this shaft replaced in my 2011 S4 recently, because it had developed a squeaking noise during low speed turns in either direction (e.g., turning into a parking spot, driveway, etc.). The dealer was initially going to lubricate it but felt the problem was just going to return. Since it was under warranty, they just replaced the shaft (which includes the universals at each end of it). The noise went away and the steering feel also improved - much like it was when the car was new.
    Jan 24 2017
    Quote Originally Posted by LYKUNO View Post
    Yes , exactly this one
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    Thanks for posting this..
    My friend had the same issue with his s4 and this made me think to check the steering knuckle 1st and saved me alot of time!
    Cheers
    Sent from my SM-G900W8 using Tapatalk
