Results 1 to 5 of 5
    Veteran Member Three Rings A4 Quattro Joe's Avatar
    Apr 09 2017
    2018 Honda Accord Sport 2.0. 2009 GMC Acadia. 2014 VW Passat, 2009 Audi A4 B8 Quattro, Built A4 B7 E
    Denver Killerado
    Audi A4 B7 Quattro Manual multiple cylinder missfire issues
    So I have installed the JHM big turbo kit works amazing from what I am able to push it to. My issue is that I am having multiple cylinder missfire issues. I have replaced everything I can think of nothing has helped.
    Done so far
    Ignition coils
    Low pressure fuel pump
    S3 injectors
    Bosch spark plugs
    APR high pressure fuel pump
    K&N drop in recently cleaned
    New manifold for injectors
    They thought it was an injector took it in drove around seemed to be backfiring pushed harder and was jolting and backfiring around 3rd gear 4k rpm (roughly). No codes have shown up but it is clearly misfiring. Any help would be greatly appreciated!
    Sent from my SM-G935P using Audizine mobile app
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    What's your spark plug gap?
    Apr 09 2017
    Denver Killerado
    Not sure the shop I take it to did them. It's a performance shop I did all my apr work there to 2+ and ran great!
    Senior Member Two Rings mecg's Avatar
    Apr 12 2016
    Readfield, Maine, USA
    I find it very strange that you are having such severe misfire issues but no CEL with misfire codes. Are you positive your issue isn't the computer pulling spark or fuel as part of traction control? Have you tried turning off traction control and seeing if that changes the symptoms?
    2013 Audi A4 quattro Prem, ZF8, APR Stage 2+ 93/E85 Tune + Cast Downpipe/HFC, R8 coils, aFe Dry Pro, Eurocode Intercooler pipe, Turbo Muffler Delete, Fitch Fuel Catalyst, RS Grille, Tinted windows, Audi logo puddle lights, Interior LEDs, VCDS tweaks, 18x8 Andros R9 Wheels w/ Michelin Pilot Super Sports
    2008 Saab 9-5 2.3T BCB², K&N, Fitch Fuel Catalyst, Interior LEDs
    Apr 09 2017
    Denver Killerado
    Actually I noticed when it's off it does ot alot more. When on not so much
